While cruising through Wal-Mart this evening, I saw a couple of those 12
volt electric coolers designed for use in a car and I started wondering if anyone has used one in your plane? If so, how good/bad did it work? Any issues with the plane's electrical system? Was it worth not having to deal with ice? Thanks! -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
On Wed, 02 Nov 2005 21:37:42 -0800, Jack Allison
wrote: While cruising through Wal-Mart this evening, I saw a couple of those 12 volt electric coolers designed for use in a car and I started wondering if anyone has used one in your plane? If so, how good/bad did it work? Any issues with the plane's electrical system? Was it worth not having to deal with ice? I used one in my Warrior once or twice. This was a Koolatron. As nearly as I could tell, it worked just as well in the air as it did in a car. Strapped it down in the baggage compartment and threaded the cord up front to the lighter socket. You just need to make sure the vents are clear so it can get cooling air. It doesn't appear to make any electrical noise that might constitute a hazard to radio navigation. DC current flows through the semiconductor thermoelectric device and the small electric fan is very quiet, both electrically and audibly. There appear to be no problems at all. If there's an AC converter then it will keep your stuff cool (or warm, if it's reversible) indefinitely while in a hotel room. No extra weight for ice or water. No pouring off water or spilling water all over everything. No water dripping from whatever you take out of it. No chasing around looking for replacement ice. It works better if it's pre-cooled though and it can take quite a while for it to cool down a load of room-temperature sodas, but if they're already cold it'll do fine keeping them that way. That's where the AC converter can help, you can start it cooling down the night before you leave. This assumes that the electrical system is 12 volt. For a 24 volt airplane you'd probably have to work something out. I suppose if the lighter socket is already powering a computer or GPS then that might also be an issue. RK Henry |
wrote: While cruising through Wal-Mart this evening, I saw a couple of those 12 volt electric coolers designed for use in a car and I started wondering if anyone has used one in your plane? If so, how good/bad did it work? Any issues with the plane's electrical system? Was it worth not having to deal with ice? I would check the current draw on the cooler. Coleman lists their PowerChill40 at 4 amps @ 12V. Most cig lighters on light GA have ~ a 5 amp circuit breaker, so not much margin. Also, I have spent some time messing with peltier coolers. The unit that I had required about 50% higher current than steady state during initial temperature ramp. -Nathan |
How many cans of beer do you consume per hour of flight?
In article . com,
"Paul kgyy" wrote: How many cans of beer do you consume per hour of flight? I was going to say it doesn't keep the six pack of beer cold enough. ;-) |
john smith wrote:
I was going to say it doesn't keep the six pack of beer cold enough. ;-) When compared to MontBlack's PMC, *nothing* keeps beverages of any sort cold enough. So, Paul...care to enlighten us on PMC v2.0? Wheels? Hinged lid? Padded seat on the top? All of the above? :-) -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
("Jack Allison" wrote)
When compared to MontBlack's PMC, *nothing* keeps beverages of any sort cold enough. So, Paul...care to enlighten us on PMC v2.0? Wheels? Hinged lid? Padded seat on the top? All of the above? :-) Padded seat is a must. PMC used too often as a table - then you have to move everything ... Wheels are also a must. I've given in, a drain will be added too. PMC will be white next year. Hinged lid? If I can do it without ruining 'the casket's' Fred Flintstone lines, sure. Now, about PMC v2.0 ...Think composites - oops, I've said too much. Montblack |
Don't limit your imagination, oh king of the garage sale!!! pickup an old battery powered wheel chair or one of those dreaded electric scooter then make the PMC a mobile party pack! Jim |
A drain...nice touch. As this is an aviation event related cooler, I'm
assuming it would be a "quick drain". Thought of another one: bottle opener mounted to the side. Heck, this sub-thread could be a post of it's own...something along the lines of "Hey gang, what features for PMC v2.0?" Nice to see we can keep you busy with a winter project. Hehe, I like the composite idea. -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Like the boaters, just hang a mesh bag full of soda out your window.
You can secure it to your seat with some rope, about 20-30 feet should be enough to dangle the drinks beneath and below your aircraft for wind maximum cooling. Don't forget to retract it before landing or any heavy maneuvering, otherwise adverse reactions may occur. Ben Hallert PP-ASEL |
| Thread Tools | |
| Display Modes | |
| Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 8th 05 12:17 AM |
| Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 01:06 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
