Piper Archer - Headphones drains the battery ?
Old November 5th 05, 01:04 PM
Roy Page
Default Piper Archer - Headphones drains the battery ?
When we bought our Piper Archer 2 years ago the previous owner cautioned
about leaving headphones plugged in in the rear seats.
He reckoned that with the headphones plugged in the battery would be slowly
drained.
I dismissed this caution as it did not seem to make any sense from an
electrical point of view.
When I came to start the engine yesterday, the cranking was very slow and
seemed like the battery was right down.
We have a new battery fitted a few months ago, so I doubt that as the
problem.
After flying for a couple of hours the engine cranking was back to its
normal speed.
I took a good look at the alternator and belt and nothing obvious was
noticed.
However, I noticed that a pair of unused headphones was plugged into a set
of the rear seat jack sockets.
They had been plugged in for about 2 weeks.
Now I wonder if they caused a slow drain on the battery while the bird sat
in the hanger for a couple of weeks ?
The aircraft has a SP400 intercom and an avionics master switch which is
always switched off when the engine is shut down.
The avionic line up is:-
KMA20, 2 x KX170's, KT76, KR86 and Flybuddy 820.
Maybe the old owner was correct ?
But what would cause the phones to take current off the battery ?
What does this knowledge base think ?
Roy
N5804F Piper Archer
"I have had some bad landings but I have never missed the runway"
Old November 5th 05, 01:43 PM
Tauno Voipio
drained.
problem.
normal speed.
noticed.
If there is a microphone (for intercom) the
headphones can use a little of current, provided
the intercom is on. IMHO, it is miswired if
it gets power when the battery relay (and switch)
is off.
In many airplanes, the clock gets power even with
the main switch off.
To verify, you need to switch the battery switch
off and measure the battery current with a suitable
ammeter - the built-in one is far too coarse for this.
HTH
Tauno Voipio
tauno voipio (at) iki fi
Old November 5th 05, 02:34 PM
Darrel Toepfer
Tauno Voipio wrote:
cautioned about leaving headphones plugged in in the rear seats.
slowly drained.
is off.
Can you talk over the intercom with the master off? What about the rear
seats?
Old November 5th 05, 02:31 PM
Jim Burns
We once had an Archer II at the flight school that had a weird problem with
the clock circuit. The circuit was drawing wayyyyy more than it should and
would kill the battery overnight. The A&Ps never did find the problem, so
the fuse, located behind the baggage compartment bulkhead, was pulled.
Old November 5th 05, 05:55 PM
mikem
Unearth the aircraft battery, look to see if there are any connections
to the positive pole upstream from the master relay. You might find
one: the clock keep-alive circuit which should have a 1A cartridge
fuse in series with it. If there are any other connections upstream of
the master relay, you need to trace them to see where they go.
I have a SP400 intercom in my Pacer, and it is powered through its own
circuit breaker from the main avionics bus. With the master off, it is
unpowered, and it would not matter if headsets were plugged in or not.
It supplies the mic current to the backseat headsets, so if it is off,
they are off too. Sounds like some dumb**** who didn't have a clue
installed the intercom!
A common problem with older electrically-powered self-winding aircraft
clocks is that the winding solenoid intermitently sticks on, which will
run down your battery is short order.
As the clock spring runs down, a switch closes, applying power to a
solenoid, which is supposed to "wind UP" the spring, causing the switch
contact to open again. If the switch stays on, the solenoid remains
powered... Best fix is to chuck the mechanical clock and replace it
with a LCD pure electronic version...
Old November 5th 05, 06:20 PM
RST Engineering
"mikem" wrote in message
I believe the certification regs allow up to a 5 amp breaker/fuse directly
from the battery for "keep alive".
Amen to the dumb**** comment. The easy way to tell if this is a ds problem
is to get an aircraft mic plug (0.206" diameter) into the back seat mic
jack(s) and see if there is voltage with respect to airframe ground on
either of the two hot leads (ring or tip) with the master switch off. If
there is voltage present, read the paragraph above, especially the last
sentence. While I cannot conceive of voltage being on the aircraft phones
plug, just to satisfy the curious, do the same test on the hot lead of a
phones plug (0.250" diameter) plugged into the back seat jack(s)
Many of the Target/K-Mart "travel alarm clocks" can be gutted and installed
into an old mechanical clock housing. They run from a single AA cell that
can be clipped to the back of the case. Change the battery every annual and
you don't have to have a keep-alive breaker/fuse installed at all.
Old November 5th 05, 08:57 PM
Roy Page
The fountain of knowledge won out again.
I just checked the mike sockets, they are all Live with the master switch
off. !
Well the bird is going into the shop this coming week to have some other
poor wiring put back to standard so that is now on the list as well.
A previous installer really made a mess of the wiring when he put in the
wing strobes.
I won't go into details but the result was a toggle switch, poorly placed
next to the engine tach which controlled Nav lights and Strobes individually
on and off.
We are putting in the normal split switch to control beacon and strobes, and
returning the nav lights to the normal switch / dimmer control wheel.
Thanks for all the pointers and, as is often the case, Jim was on the money
once again.
Roy
N5804F Piper Archer
"RST Engineering" wrote in message
problem is to get an aircraft mic plug (0.206" diameter) into the back
seat mic jack(s) and see if there is voltage with respect to airframe
ground on either of the two hot leads (ring or tip) with the master switch
off. If there is voltage present, read the paragraph above, especially
the last sentence. While I cannot conceive of voltage being on the
aircraft phones plug, just to satisfy the curious, do the same test on the
hot lead of a phones plug (0.250" diameter) plugged into the back seat
jack(s)
installed into an old mechanical clock housing. They run from a single AA
cell that can be clipped to the back of the case. Change the battery
every annual and you don't have to have a keep-alive breaker/fuse
installed at all.
Old November 6th 05, 03:28 AM
Darrel Toepfer
off. !
Just turn the intercom off for the time being when you aren't flying...
Old November 6th 05, 03:35 AM
George Patterson
*If* the power on the headset lines is coming through the intercom. It could be
coming from elsewhere; for example, from the radio "keep-alive" line. No telling
where Joe Fumblefingers crossed the wires up.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old November 6th 05, 02:45 AM
George Patterson
If he is, then something isn't wired properly. The first thing I would do is get
a schematic for the intercom wiring harness and check the power line for power
with the avionics master off.
George Patterson
Front articulating seats for Piper Archer II - Supplier needed Roy Page Owning 5 June 19th 11 03:15 AM
piper archer ,help !! D O'Reilly Simulators 1 September 12th 04 04:04 PM
Battery Chargers Mike Rapoport Owning 11 December 2nd 03 11:55 PM
Charity Auction - Flight in a Piper Archer over Cambridge Charlie General Aviation 0 October 8th 03 09:50 AM
Piper Archer III or Cessna 172SP Dale Harwell Owning 10 July 15th 03 04:01 AM
