337 for interior plastic
Old November 15th 05, 09:11 PM posted to rec.aviation.owning
Default 337 for interior plastic
So, I sent off for new interior plastic. The pieces are not PMA'd so
the dealer is telling me I need to do a 337. Reading part 43 I see
preventative maint says..
(9) Refinishing decorative coating of fuselage, balloon baskets,
wings tail^
M
group surfaces (excluding balanced control surfaces), fairings,
cowlings,^M
landing gear, cabin, or cockpit interior when removal or disassembly
of any^M
primary structure or operating system is not required.^M
This makes me think I can replace my cabin vent covers myself. Does
that means I can also sign the 337? Do I need to pay an A&P a minimum 1
hour labor to sign the 337?
-Robert
Old November 15th 05, 10:43 PM posted to rec.aviation.owning
The dealer is nuts. What part 43 is telling you, is that you do NOT need a
337, in fact the FSDO inspector will deny your 337 because it is not a major
repair or alteration. All you need to do is install it and make a log book
entry under your name and cert #.
"Robert M. Gary" wrote in message
wings tail^
M
cowlings,^M
of any^M
-Robert
Old November 16th 05, 04:16 AM posted to rec.aviation.owning
Part 43 tells you that replacing these items is preventative maintenance, *not*
a major repair or alteration. No 337 is required.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
Old November 16th 05, 08:04 AM posted to rec.aviation.owning
C'mon folks. This clown has been in these ngs for a month now railing on
these plastic parts. He is either trolling or paranoid.
In either case, let him deal with it himself or pay a thousand dollars to
one of my colleagues for a logbook signature.
(BTW, I'm available for the logbook signature if he is {;-) )
Old November 16th 05, 11:32 PM posted to rec.aviation.owning
Of course when I posted the first time I was asking about needing a 337
because it is not PMA'd. This post was asking if a 337 was necessary if
I could sign it since the work itself seems to fall under preventative
maintenance.
Old November 17th 05, 04:04 AM posted to rec.aviation.owning
Again, you are a troll or paranoid. Pick one and tell us which it is.
maintenance.
Old November 17th 05, 06:30 AM posted to rec.aviation.owning
I know what I am, sounds like you need to pick.
I'm asking if there is a reasonable way to replace my vent covers with
full FAA approval. If you aren't interested in aviation, FAA
regulations or the maintenance of aircraft, I suggest you find another
newsgroup to read.Meanwhile, let the rest of us enjoy our aircraft and
do our best to keep the FAA happy.
-Robert
Old November 17th 05, 12:34 PM posted to rec.aviation.owning
maintenance.
The need for a 337 and the fact that these lack a PMA (or other
authority) and hence may be unapproved parts are unrelated items.
Old November 17th 05, 05:00 PM posted to rec.aviation.owning
Thanks Ron! 337's have always confused me. Its never been clear to me
when I need one, when they must be signed by the FAA etc.
Old November 17th 05, 02:57 PM posted to rec.aviation.owning
Robert,
The only flag I see is the fact that it's not an approved part and could
be interpretted as not meeting the type certificate.
Now having said that, I've replaced/repaired/repainted interior plastic
parts on several planes I've owned and didn't even make a log entry.
Shame on me.
For the ones you're not replacing go buy some S.E.M. paint for
flexible surfaces. Works great. Available at auto body stores.
OW
wings tail^
M
cowlings,^M
of any^M
-Robert
