I'm possibly having to replace a set of plugs; what are the pros/cons
of using fine wire types? I know they are more expensive, but what do you get in return for the cost? |
![]() Quote:
OTOH, they don't seem to do as well as traditional plugs if your piston rings leak or burn a lot of oil, since they'll foul more easily. overall, if your engine is in good condition, they seem to be a "better deal" than massive electrode plugs since they seem to have a lower cost per hour. francois |
clipclip wrote:
Paul kgyy Wrote: I'm possibly having to replace a set of plugs; what are the pros/cons of using fine wire types? I know they are more expensive, but what do you get in return for the cost? i've had the same fine wire plugs on my TwinCo's IO320's for over 1300 hours with no visible electrode erosion. they also seem to have a wider heat range than regular plugs, an important feature for turbonormalised engines which tend to run hotter than normal in summer. OTOH, they don't seem to do as well as traditional plugs if your piston rings leak or burn a lot of oil, since they'll foul more easily. overall, if your engine is in good condition, they seem to be a "better deal" than massive electrode plugs since they seem to have a lower cost per hour. francois Good response. Fine wires are a good investment in a good engine. On the other hand, they are a wates of money (and in fact foul more easily) in some engines, like the old Continental E series. Rip |
Longer wear and easier starts on my cabureted Lycoming 0360.
I"ve not noticed much difference. One of my Finewire plus died within 6
months. Could just have been bad luck but didn't make me feel good about spending extra for it. -Robert IO-360-A3B6 |
I'll stick my neck out....
During our annual in July, many of our plugs showed signs of wear... oval center electrodes and excessive gaps. We debated about what to do... replace the worst ones with massive electrode plugs, replace all of them with massives, or replace all of them with fine wire. We talked it over with a couple GA A&P/IA's and a couple of our A&P/IA's in the crop dusting business. The GA mechanics said save the $$ and go with massives, rotate and clean them often, we always have them in stock, we'd have to order the fine wires. The aerial applicator mechanics said go with the Iridium fine wires and you'll have less fouling, the gap will never change, keep them rotated, they'll be the last plugs you ever buy. They run them in all of their piston engines, very rairly foul them, and normally only change them at overhauls. They also buy them in bulk and sold us a set of 24 for less than 1/2 the normally advertised price. Sold. Iridium's installed, saved and cleaned the best of the massives. Jim "Paul kgyy" wrote in message oups.com... I'm possibly having to replace a set of plugs; what are the pros/cons of using fine wire types? I know they are more expensive, but what do you get in return for the cost? |
Much longer life. I expect mine to last until the overhaul and hopefully
longer. I have 500 hours on mine with no noticeable wear. Less chance of fowling since more of the ceramic is exposed. I have had one bridge with lead once. At the very least try fine wires on the bottom and massive on the top. I really hurts when you drop one though. A lot of money in the trash can. Michelle (12 fine wires in my engine) Paul kgyy wrote: I'm possibly having to replace a set of plugs; what are the pros/cons of using fine wire types? I know they are more expensive, but what do you get in return for the cost? |
Cleaning Spark Plugs is a Simple Job... | Jay Honeck | Owning | 62 | October 6th 05 03:05 AM |
Spark plug question: Massive electrode or fine wire? | Peter R. | Owning | 9 | February 4th 05 02:03 AM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 05:11 PM |
Wire for homebuilts. | clare @ snyder.on .ca | Home Built | 9 | March 25th 04 05:51 PM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
