"red oxide primer is a plus"
Old November 17th 05, 04:03 PM posted to rec.aviation.homebuilt
Default "red oxide primer is a plus"
I was working with an A&P while he did a pre-purchase for me.
He looked at the inside and remarked that 'red oxide primer is a plus".
Can someone elaborate? what's it better than?- Mike
Old November 18th 05, 12:13 AM posted to rec.aviation.homebuilt
Red oxide primer on what? On steel, its a plus. It's kind of "pre-rust",
and helps to protect steel parts from further corrosion, to a limited
extent. On aluminum (or magnesium, God forbid)it will promote corrosion
(do a Web search on the galvanic series), and is a definite no-no.
Rip
Old November 18th 05, 01:19 AM posted to rec.aviation.homebuilt
On Fri, 18 Nov 2005 00:13:25 GMT, Rip
Rip
Rip - 4130 - Mike
Old November 19th 05, 12:11 AM posted to rec.aviation.homebuilt
Rip
Rip - 4130 - Mike
4130, no harm, no foul.
Rip
Old November 18th 05, 12:26 PM posted to rec.aviation.homebuilt
I've seen red oxide on aluminum and wondered wth put it on there.
Zinc chromate is the aircraft builder's and owner's best bet for
aluminum, magnesium, or chromoly.
If I were welding up a fuselage of 4130, I'd powdercoat it. The old
ones I see which are well-preserved are painted with zinc chromate and
then injected with boiled linseed oil.
I agree with this writer:
http://www.paintcenter.org/rj/feb05d.cfm
Old November 27th 05, 09:17 AM posted to rec.aviation.homebuilt
JLS - powdercoating. I've seen several comments discouraging use of
powdercoating as it hides cracks.YMMV - Mike
Old November 27th 05, 05:23 PM posted to rec.aviation.homebuilt
"mhorowit" wrote in message
Depends. Here in the land of over-regulation, powdercoating isn't allowed
unless it can be proved to crack when the surface of the underlying material
cracks. Having tested several types, I'm pretty much convinced that the
hard polyester powder coats are fine. So are our CAA, who permit them on
aircraft structures, engine mounts etc.
The nylon ones definitely aren't OK though. I'm pretty sure that cheap
nylon podercoat is what's used on domestic garden goods, the sort where rust
bubbles up under the coat after a few years.
Lubricating the primer shaft Michael Horowitz Home Built 9 November 20th 03 12:26 AM
seeking info on self etching primer gromit Restoration 1 July 11th 03 01:02 AM
