Of course, we have a new squawk shortly after coming out of the shop.
Perhaps someone here can point me in the right direction? Here's the scenario with our 1974 Piper Cherokee Pathfinder, with a 530 hour, normally aspirated Lycoming O-540-B4B5 engine: 1) Flying to Janesville, WI today. Extremely cold -- around 15 degrees Fahrenheit on the surface, near zero at altitude. The first real cold snap of the year. 2) In steady-state flight, both of us hear a "woo--woo--woo..." softly in the headphones. It sounds just like strobes that aren't grounded properly. 3) The noise slows down -- or speeds up -- in synch with the prop RPM. At 2300 RPM, it's going a bit faster than once per second -- maybe around three times every two seconds. 4) I switch our digital voltage/amperage meter to AMPs, and watch as it oscillates in time with the noise. It's alternating from 5 amps to 10-11 amps, in time with the "woo--woo--woo"... Voltage appears to be pretty steady at around 13.8-ish volts. 5) Adding load to the system (landing lights, fuel pump, etc.) makes the noise louder. Adding load to the system and then suddenly turning everything off makes the noise and amperage oscillation go away -- for about 30 seconds. It then returns. 6) Turning the alternator side of the split master switch ALSO makes the noise go away. It sometimes stays away when I turn the alternator back on. Sometimes it doesn't. 7) The battery is new this past summer. So, we've got a noise and amperage indication that can be corrected by adding load to the system -- and then suddenly taking it away. The noise is also fixed -- sometimes -- by cycling the alternator off and on. The service last week was having the impulse couplings serviced (per service bulletin), so electrical things have been tinkered with since our last flight. (This is ALWAYS when some new squawk seems to crop up.) Any ideas? Loose ground wire somewhere? Alternator failing? Any and all input is welcomed! Thanks! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Of course, we have a new squawk shortly after coming out of the shop. Perhaps someone here can point me in the right direction? Alternator problem. Possibly a filter, but my guess is a diode is going bad. 3) The noise slows down -- or speeds up -- in synch with the prop RPM. At 2300 RPM, it's going a bit faster than once per second -- maybe around three times every two seconds. Alternator speed depends on engine speed. 5) Adding load to the system (landing lights, fuel pump, etc.) makes the noise louder. Adding load to the system and then suddenly turning everything off makes the noise and amperage oscillation go away -- for about 30 seconds. It then returns. Adding load makes the alternator work harder. Cutting it all out lets it loaf until the battery charge drops a bit, then the alternator has to work again. George Patterson If a tank is out of ammunition, what you have is a sixty ton portable radio. |
I'd say George is dead on. I also thought filter, but the fact that the
amps oscillate makes me think diode. I've never heard of a bad filter causing an ammeter oscillation, the filters that have failed for me just complain loudly. Jim |
Could it be a very loose alternator belt ? The symptoms don't all jib
though. |
I third the thought. I have a capacitor filter across the output of the
alternator and ground. I have also cooked an alternator in the summer . The fan on the back was not enough forced air for a high load when it is hot. I added a blast tube form the front of the cowling to the "Blast adapter" on the back on the Alternator. The hole in my cowling just below the engine air intake is for the alternator. Works great. No more over heating problems. Michelle George Patterson wrote: Jay Honeck wrote: Of course, we have a new squawk shortly after coming out of the shop. Perhaps someone here can point me in the right direction? Alternator problem. Possibly a filter, but my guess is a diode is going bad. 3) The noise slows down -- or speeds up -- in synch with the prop RPM. At 2300 RPM, it's going a bit faster than once per second -- maybe around three times every two seconds. Alternator speed depends on engine speed. 5) Adding load to the system (landing lights, fuel pump, etc.) makes the noise louder. Adding load to the system and then suddenly turning everything off makes the noise and amperage oscillation go away -- for about 30 seconds. It then returns. Adding load makes the alternator work harder. Cutting it all out lets it loaf until the battery charge drops a bit, then the alternator has to work again. George Patterson If a tank is out of ammunition, what you have is a sixty ton portable radio. |
"George Patterson" wrote in message news:Q%7ff.60$N44.3@trndny08... snip Alternator problem. Possibly a filter, but my guess is a diode is going bad. snip Diodes are solid state devices which either work, are open (most common failure), or are shorted out (less common failure). They don't suffer from "going bad" or "getting weak". They either work or they don't. If they are intermittant, it's a connection, not the diode itself. DB (Many years of Electronics experience) |
"Doodybutch" writes:
Diodes are solid state devices which either work, are open (most common failure), or are shorted out (less common failure). They don't suffer from "going bad" or "getting weak". They either work or they don't. If they are intermittant, it's a connection, not the diode itself. Well, maybe... I have had some larger power diodes whose *internal* bonds would open when the diode got hot. When it cooled again, guess what. I also had a matrix of small-signal glass diodes that tested just fine with an ohmmeter, but in operation.... turns out some would "zener" when tested with the 12v that was used in the circuit. But I really doubt that Jay's issue is alternator diodes.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
See: http://www.sacskyranch.com/altnoise.htm
Awesome source -- thanks! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
See: http://www.sacskyranch.com/altnoise.htm Awesome source -- thanks! And located just down the road from me! -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
| NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 11:33 AM |
| Logging time on a PCATD | [email protected] | Instrument Flight Rules | 3 | December 18th 04 06:25 PM |
| FAA Application -- kinds of time | Gary Drescher | Instrument Flight Rules | 5 | November 23rd 04 03:33 PM |
| FS9 Time Zone Files in BETA Test | DDT | Simulators | 3 | April 5th 04 07:06 PM |
| Retroactive correction of logbook errors | Marty Ross | Piloting | 10 | July 31st 03 07:44 AM |
