Is this a Complex Plane?
Old November 18th 05, 09:12 PM posted to rec.aviation.piloting
Default Is this a Complex Plane?
Greetings,
I looking at a Lancair ES kit plane. I know the plane is high
performance (210 or 310 hp engines) but is it also complex? The plane
has fixed landing gear, standard or slotted flaps and a constant speed
prop.. The real question boils down to this, does a plane have to have
all three elements (flaps, retractable landing gear AND a constant
speed prop.) or if it has just one (retractable langing gear OR a
constant speed prop.), does that make it complex?
I searched the group(s) and everyone has an opinion but nobody seems to
have a definition for "complex" that gives a yes or no answer to the
question of "is this a complex aircraft"
Hopefully I'm not looking for a simplex answer to an infinitely
difficult question. Thanks in advance,
David.
Old November 18th 05, 09:19 PM posted to rec.aviation.piloting
61.31 (e) (1)
....and...
You need all three for it to be complex.
Jose
He who laughs, lasts.
Old November 19th 05, 11:26 PM posted to rec.aviation.piloting
On Fri, 18 Nov 2005 21:19:40 GMT, Jose
61.31 (e) (1)
...and...
Wasn't that changed in the not too distant past?
Seems like when I started flying it only took two of the three.
www.rogerhalstead.com
Jose
Old November 19th 05, 11:42 PM posted to rec.aviation.piloting
I meant three wheels. Not three wiggles.
Jose
Old November 20th 05, 04:14 AM posted to rec.aviation.piloting
That is to say (sheesh, doesn't Jose snip properly!)...
You need all three wiggles, but only one wheel needs to wiggle.
Jose
Old November 20th 05, 06:31 AM posted to rec.aviation.piloting
On Sat, 19 Nov 2005 23:42:01 GMT, Jose
I meant Constant speed prop, Electric flaps, and retract.:-))
Didn't it used to be only two of the three required for complex?
Jose
Old November 20th 05, 03:07 PM posted to rec.aviation.piloting
For seaplanes, retractable gear is not necessary. However as long as I
remember it was all three wiggles for land planes.
Jose
Old November 19th 05, 08:44 PM posted to rec.aviation.piloting
Sylvain
Comment????
If you just retracted the nose gear like a Vari-eze would that meet
the requirements for a retractable gear?
Big John
don't search the newsgroups, but look at the regulations; in
particular 14 CFR 61.31(e)(1); it has to have a retractable
landing gear, flaps and controllable pitch propeller except
in the case of a seaplane (where only flaps and a controllable
pitch propeller);
so the aircraft you described is not complex.
to tie this one into other discussions in this newsgroup,
always refer to the scriptures!
--Sylvain
Old November 19th 05, 08:59 PM posted to rec.aviation.piloting
I would say yes. The requirements say retractable gear; they do not say
the absence of fixed gear.
And as for "things that wiggle that the pilot has to keep track of", one
is as good as three.
Jose
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
Navy sues man for plane he recovered in swamp marc Owning 6 March 29th 04 12:06 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
