I'm currently flying VFR in a vfr equipped plane. What would be the lowest
cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit |
tom pettit tompetatpeak wrote:
I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? Maybe something in the Apollo GX50/55/60/65 series? You'll find, though, that the cost of installation is a big part of making it IFR, so if you're going to spend a lot on installation, it seems a shame to waste it on a cheap unit. |
Dave Butler wrote On 11/18/05 13:57,:
tom pettit tompetatpeak wrote: I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? Maybe something in the Apollo GX50/55/60/65 series? You'll find, though, that the cost of installation is a big part of making it IFR, so if you're going to spend a lot on installation, it seems a shame to waste it on a cheap unit. I went through this calculation way back in 2000 or so. I even had the advantage of having a loran that would have had an upgradable pinout to the Apollo. I went 430 and am happy with that decision. I doubt it would have saved any real money in any case. |
![]() Quote:
the king 90B (or 89B) comes with a generic STC - so you can save yourself the cost of the LSTC. there's usually a few of those for sale on e-bay as well. an IFR certified installation probably can't be done much under $3,500 by the time you add labour, paperwork, and required accessories such as a CDI or annunciator. i hope that helps, francois |
On 11/18/2005 13:28, tom pettit tompetatpeak wrote:
I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit Keep in mind that it takes a specific unit (a TSO one forty something rather than the TSO 129... I'm not sure I have those number correct) for the GPS unit to be used as the sole means of IFR navigation. I mention this, because you said your plane is not currently IFR capable. In order to use one of the TSO 129 certified GPS units for IFR flight, the plane must still have the navigation equipment on board for the ground based navigation aids along the route of flight. Does any of this apply to you? If not, sorry if I misunderstood your situation. -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
I don't currently have any navigation equipment. I was hoping that a
single, certified, gps unit could be used as primary, with an uncertified unit as back up. I was hoping I didn't need anything else. Reading the FARS it isn't very specific, or more likely, I just don't know enough about this stuff yet. thanks, tom "Mark Hansen" wrote in message ... On 11/18/2005 13:28, tom pettit tompetatpeak wrote: I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit Keep in mind that it takes a specific unit (a TSO one forty something rather than the TSO 129... I'm not sure I have those number correct) for the GPS unit to be used as the sole means of IFR navigation. I mention this, because you said your plane is not currently IFR capable. In order to use one of the TSO 129 certified GPS units for IFR flight, the plane must still have the navigation equipment on board for the ground based navigation aids along the route of flight. Does any of this apply to you? If not, sorry if I misunderstood your situation. -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
![]() tom pettit tompetatpeak wrote: I don't currently have any navigation equipment. I was hoping that a single, certified, gps unit could be used as primary, with an uncertified unit as back up. I was hoping I didn't need anything else. Reading the FARS it isn't very specific, or more likely, I just don't know enough about this stuff yet. Any real IFR work without a navcomm isn't practical. |
On 11/18/2005 3:43 PM, tom pettit tompetatpeak wrote:
I don't currently have any navigation equipment. I was hoping that a single, certified, gps unit could be used as primary, with an uncertified unit as back up. I was hoping I didn't need anything else. Reading the FARS it isn't very specific, or more likely, I just don't know enough about this stuff yet. thanks, tom Well, start with FAR 91.205. Specifically, 91.205 (d), and 91.205 (d) (2), where it state: "...navigational equipment appropriate to the ground facilities to be used". Then, have a look at the AIM, in the section on Navigational Aids (section 1), specifically, 1-1-19 (d) (1), which talks about Authorization to conduct any GPS operation under IFR, and later it talks about the requirements for alternate navigation equipment. Basically, what this all boils down to, is this: If you have a IFR-certified GPS system (TSO-129 certified), like the Garmin GNS 430, you can use it for IFR operations, but the plane needs to be equipped with the typical IFR navigation radios anyway. There are some exceptions, but this should get you thinking in the right direction. I would expect that the GPS systems that can be used without any other nav equipment on board would be more expensive than a TSO-129 system + standard nav gear anyway. I hope this helps, "Mark Hansen" wrote in message ... On 11/18/2005 13:28, tom pettit tompetatpeak wrote: I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit Keep in mind that it takes a specific unit (a TSO one forty something rather than the TSO 129... I'm not sure I have those number correct) for the GPS unit to be used as the sole means of IFR navigation. I mention this, because you said your plane is not currently IFR capable. In order to use one of the TSO 129 certified GPS units for IFR flight, the plane must still have the navigation equipment on board for the ground based navigation aids along the route of flight. Does any of this apply to you? If not, sorry if I misunderstood your situation. -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
So how come I can't just use the gps alone? It seems like it is much more
flexible, and then I wouldn't be as dependent on what ground based stuff was available. tom Basically, what this all boils down to, is this: If you have a IFR-certified GPS system (TSO-129 certified), like the Garmin GNS 430, you can use it for IFR operations, but the plane needs to be equipped with the typical IFR navigation radios anyway. |
Because a GPS failure or outage can affect an entire REGION, while if a
single ground based navaid goes on the fritz, other stuff nearby will likely still work. Truth is, right now, the best approach minimums are with ground based ILS equipment. Unless you have baro-VNAV capability (which is not in the cheaper GPS equipment) the GPS approach may leave you in the clouds while the "antiquated" precision approach equipment can get you to 200 feet and a mile. Get some instrument training.. not the whole rating.. but some.. and see what is out there. (I am presuming you dont have one, but that is just a hunch) Also, if you dont have a rating yet, and plan to train in your own plane, you will need to be equipped for the checkride to perform 1 type of precision approach and 2 types of non-precision approaches (unless things have changed and I missed the memo). Having a "cheap ifr GPS" may not even have approach capability. Those that currently do are likely only LNAV (no glideslope, thus non-precision approach). Unless you have a Precision Approach Radar site, or a VNAV (baro aided or WAAS) you will need an ILS to meet the checkride requirements in that plane Dave tom pettit peak wrote: So how come I can't just use the gps alone? It seems like it is much more flexible, and then I wouldn't be as dependent on what ground based stuff was available. tom Basically, what this all boils down to, is this: If you have a IFR-certified GPS system (TSO-129 certified), like the Garmin GNS 430, you can use it for IFR operations, but the plane needs to be equipped with the typical IFR navigation radios anyway. |
The frustrating economics of aviation | C J Campbell | Piloting | 96 | July 21st 04 04:41 PM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Lowest Cost GPS Tracking System on the Market | Johann Blake | Soaring | 1 | November 19th 03 04:50 PM |
Lowest Cost GPS Tracking System on the Market | Johann Blake | Piloting | 0 | November 19th 03 04:06 PM |
Lowest cost per mile flown motor- 2 stroke | Bruce A. Frank | Home Built | 0 | July 2nd 03 06:25 AM |
