Does anyone know how a stormscope is able to sense the distance to the
lightning ... |
Roland wrote On 11/18/05 16:27,:
Does anyone know how a stormscope is able to sense the distance to the lightning ... It counts the difference between the flash and the cracking sound. No, kidding, sorry. Lightning generates radio frequency energy, just like any electrical current does. So the location solution can be found just like they find a radio transmitter, by using directional antennas and paralax. |
"Roland" wrote in message
... Does anyone know how a stormscope is able to sense the distance to the lightning ... You will probably find some useful information about this subject by Googling for lightning sferics. Jon |
lightning ... The booklet that came with ours used the term "pseudo range." Ryan (the inventor) measured the strength (amplitude) of a number of lightning strokes, and calculated the average. The stormscope assumes that every lightning strike is of "average" intensity, and it calculates the distance from the signal strength. A strike that is stronger than average will seem to be closer than it actually is; a weak one will seem to be farther away. Hence "pseudo." But it's good enough to provide safe guidance to the pilot. vince norris |
On Sat, 19 Nov 2005 01:27:20 +0100, "Roland" wrote:
Does anyone know how a stormscope is able to sense the distance to the lightning ... It uses an algorithm based on the intensity of the strike signal. A strong strike signal will therefore appear to be closer than it really is, and a weak one further away. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Roland wrote:
Does anyone know how a stormscope is able to sense the distance to the lightning ... I don't know for sure as they don't publish their algorithms, but most folks use dispersion of the signal to estimate distance as different frequency components of the signal travel at slightly different speeds through the air. The farther they travel the more dispersed the signal. Matt |
Roland wrote:
Does anyone know how a stormscope is able to sense the distance to the lightning ... The explanation I got seems better: The atmosphere attenuates some radio frequencies more than other (I believe high frequencies are attenuated more than low, but it may be way more complex.) A lighting flash is an impulse and thus, has all frequencies present at the same level. The distance sensor can measure the level of 2 frequencies and derive the distance. In practice I've heard that 6 frequencies are used but that implies 36 amplitude ratios are being used. Take your pick. |
Stubby wrote:
The explanation I got seems better: The atmosphere attenuates some radio frequencies more than other (I believe high frequencies are attenuated more than low, but it may be way more complex.) A lighting flash is an impulse and thus, has all frequencies present at the same level. The distance sensor can measure the level of 2 frequencies and derive the distance. In practice I've heard that 6 frequencies are used but that implies 36 amplitude ratios are being used. Ding ding ding ding ding ding! Finally someone responded with the correct answer. Dave |
Dong, dong, dong, dong, dong...
Perhaps the current Stormscope uses this method; Ryan's original work used a spot frequency (50 kHz) and amplitude discrimination. And Ryan didn't "invent" it. The seminal work was done by Smythe Research Associates in San Diego on a field trip to the South Pacific. Strikefinder was the first to use multiple frequencies across a rather broad bandwidth. Jim "Dave Butler" wrote in message news:1132589727.740244@sj-nntpcache-3... Stubby wrote: The explanation I got seems better: The atmosphere attenuates some radio frequencies more than other (I believe high frequencies are attenuated more than low, but it may be way more complex.) A lighting flash is an impulse and thus, has all frequencies present at the same level. The distance sensor can measure the level of 2 frequencies and derive the distance. In practice I've heard that 6 frequencies are used but that implies 36 amplitude ratios are being used. Ding ding ding ding ding ding! Finally someone responded with the correct answer. Dave |
Just for clarity, using multiple frequencies is not the key to its
working. A pair (2) will suffice. Using multiple frequency (ratios) will probably increase the accuracy, however. Hats off to whoever invented it. Very clever. RST Engineering wrote: Dong, dong, dong, dong, dong... Perhaps the current Stormscope uses this method; Ryan's original work used a spot frequency (50 kHz) and amplitude discrimination. And Ryan didn't "invent" it. The seminal work was done by Smythe Research Associates in San Diego on a field trip to the South Pacific. Strikefinder was the first to use multiple frequencies across a rather broad bandwidth. Jim "Dave Butler" wrote in message news:1132589727.740244@sj-nntpcache-3... Stubby wrote: The explanation I got seems better: The atmosphere attenuates some radio frequencies more than other (I believe high frequencies are attenuated more than low, but it may be way more complex.) A lighting flash is an impulse and thus, has all frequencies present at the same level. The distance sensor can measure the level of 2 frequencies and derive the distance. In practice I've heard that 6 frequencies are used but that implies 36 amplitude ratios are being used. Ding ding ding ding ding ding! Finally someone responded with the correct answer. Dave |
Pinout for StormScope WX-900 | epotenziani | Products | 0 | August 22nd 05 08:32 PM |
Shops for Stormscope Install - Madison WI | Jim Burns | Owning | 3 | February 6th 05 06:48 PM |
ADF vs. StormScope antenna | David Megginson | Instrument Flight Rules | 0 | September 6th 03 10:03 PM |
WX1000 Stormscope battery | D. J. Gooding | Owning | 2 | August 9th 03 02:25 AM |
FS: WX-1000E Stormscope | Lenny Sawyer | Owning | 0 | July 1st 03 02:29 AM |
