Flying into NYC for Thanksgiving Day Parade
Old November 21st 05, 12:03 AM posted to rec.aviation.piloting
Default Flying into NYC for Thanksgiving Day Parade
Hello all,
I was thinking about flying the family up to NYC to see the Thanksgiving Day
Parade.
Anyone recommend an airport to fly in to?
I would rather not rent a car, just get into town somehow and then the walk
or cab it while in the city.
Flight would be flown IFR from Norfolk (ORF) to wherever near NYC. Any
preferred routes/arrivals would be appreciated as well.
Thanks.
Old November 21st 05, 02:43 AM posted to rec.aviation.piloting
Parade.
Teterboro (KTEB) is probably the closest in terms of commuting into
Manhattan. I commuted there weekly during the summer of 2004 for business
on the Island.
Car service from the airport to midtown is about US $80 to $100 one way.
You could also take the train or the bus. Millionare, the FBO where I
parked, provided free transportation to the train or bus stop. Both were
about 5 minutes away from the FBO, both stops were outdoors, and both were
not places at which I felt comfortable standing alone after dark. The bus
takes you to Port Authority bus terminal snd the train takes you to Penn
Station.
In terms of cost, the train was about $6.00 per person and the bus was
about $2.50 from their stops near TEB. In the end, I opted for the bus
since it was faster, even during rush hour. You can get both schedules
online.
The bus is the New Jersey Transit bus #165. Here is the schedule:
http://www.njtransit.com/pdf/bus/T0165.pdf
The train is the New Jersey transit, Pascack Valley line, transferring in
Secaucus Station. You need to fill in some information to see your
schedule, he
http://www.njtransit.com/sf_tr_schedules.shtml#
Peter
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old November 21st 05, 01:42 PM posted to rec.aviation.piloting
Parade.
IFR or VFR?
If you're coming in VFR, it's nice to pick an airport on the same side
of the class B as you are, all other things being equal. I come from
the north, so it's trivially easy to get into Teterboro (KTEB) or
Caldwell (KCDW) VFR. IFR, you can get some funky routings no matter
what you do. You'll be coming from the south, so I don't know what
would work best. Linden? (I've never tried it).
I've found that Republic (KFRG), Caldwell, and Teterboro all have
similar costs for tie-down and fuel. From Republic, you get a lift in
the FBO van to the LIRR station and take the train into Penn Station;
from Teterboro, you take an expensive taxi/limo ride or a cheap bus to
the Port Authority. From Caldwell, an expensive car/taxi is
pretty-much your only realistic choice.
Personally, I plan to stick with Teterboro from now on, because I fly
in from Canada, and Teterboro has customs onsite at Atlantic Aviation
(so I don't have to make an extra stop in Massena). It's on the wrong
side of the class B for you, though.
Best of luck,
David
Old November 21st 05, 05:17 PM posted to rec.aviation.piloting
Linden is an interesting little airport, almost like a country airport but
shoved under an 800' shelf of a class B.
That has consequences. First, if you're not comfortable flying near a class
B, you won't like it. And I do mean *near*. If you're 1" too high in the
pattern, you're in class B.
You can get into Linden w/o talking to ATC, but I'm the chatty type. One
trick people use is to follow the GPS approach. Follow it (laterally and
vertically) and you'll stay out of the class B.
Another consequence it that it's not a busy airport with multiple 24x7 FBOs.
If you're there during business hours, you can get a cab easily enough. I
don't happen to know if there's even a payphone or a board listing taxi
companies if you're there off-hours, though.
You can get a taxi to the local NJTransit stop.
TEB is probably easiest in terms of no-rental-car transit into the city. At
CDW, transit options are pretty poor. The Mac Dan FBO, though, rents cars
on the field (for which I'd recommend calling ahead).
- Andrew
Old November 21st 05, 10:48 PM posted to rec.aviation.piloting
"David Megginson" wrote in message
Day
Parade.
IFR or VFR?
Republic sounds tempting vs TEB. How long is the train ride to Penn
Station?
Old November 22nd 05, 01:25 AM posted to rec.aviation.piloting
Station?
It's about an hour. Trains run roughly every hour, but I understand
that during evening rush hour, it's a longer wait to get into the city.
So figure more than two hours from landing to midtown. It's a nice,
quiet little town, though, with a mall right beside the airport (I
didn't go inside).
Someone else wrote about liking to talk to ATC. I like to talk to ATC
as well -- I fly out of what would be a class B airport in the U.S. --
but when you call NY approach from the north flying into KCDW or KTEB,
they'll just tell you to descend and remain clear of class B anyway.
All the best,
David
Old November 22nd 05, 03:36 AM posted to rec.aviation.piloting
Station?
didn't go inside).
Am I reading the chart right, As far as the class B airspace goes, if I come
right up the coast and stay below 1500' can I thread the airspace between
jfk and newark and fly right over 'ground zero' on my way to TEB?
Is the NYC ADIZ no longer in effect?
Old November 22nd 05, 04:16 AM posted to rec.aviation.piloting
Nope, fortunately it went away within months of the 9/11 terrorism act.
Peter
Old November 22nd 05, 04:40 AM posted to rec.aviation.piloting
Not exactly. The class-B floor dips to 1100' over NY harbor, so you need to
watch out for that. As for the rest, you have to maintain clearance from
buildings and such, so you can't safely fly "right over" anything except the
harbor, the rivers and the bridges unless you get clearance into the B.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
Old November 22nd 05, 03:44 AM posted to rec.aviation.piloting
Station?
didn't go inside).
If I'm trying to get to TEB from the south, my direct flight takes me right
over the top of Newark (yea right). How painful is it going to be to get
around Newark and into TEB from the south?
Passing of Richard Miller [email protected] Soaring 5 April 5th 05 01:54 AM
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 [email protected] Piloting 0 April 3rd 05 08:48 PM
Ten Years of Flying Jay Honeck Piloting 20 February 19th 05 02:05 PM
F/A-22 to make appearance at U.S. Air Force Academy parade Otis Willie Military Aviation 14 June 5th 04 11:11 PM
ADV: CPA Mountain Flying Course 2004 Dates [email protected] Piloting 0 February 13th 04 04:30 AM
