We will be flying (hopefully) to Bremerton, WA (KPWT) on Wednesday and the
weather in the PNW does not look very good either now or in the forecast (widespread fog, vis 1/8sm). Are there any local fog effects at Bremerton? Are there airports in the area that are not as likely to have fog? Which ones? Thanks! Mike MU-2 |
Usually Boeing Field (KBFI) has the best weather when there is a big foggy
high in the area, like right now. Bremerton does make it's own weather, but not with widespread low IFR conditions like the past week. It usually makes IFR conditions when EVERYWHERE else is VFR. There doesn't seem to be much relief coming. These conditions come every year and stay for a couple of weeks at a time. Karl "Curator" N185KG "Mike Rapoport" wrote in message ink.net... We will be flying (hopefully) to Bremerton, WA (KPWT) on Wednesday and the weather in the PNW does not look very good either now or in the forecast (widespread fog, vis 1/8sm). Are there any local fog effects at Bremerton? Are there airports in the area that are not as likely to have fog? Which ones? Thanks! Mike MU-2 |
ink.net... We will be flying (hopefully) to Bremerton, WA (KPWT) on Wednesday and the weather in the PNW does not look very good either now or in the forecast (widespread fog, vis 1/8sm). Are there any local fog effects at Bremerton? Are there airports in the area that are not as likely to have fog? Which ones? Thanks! As Karl says, the current weather pattern is one of widespread fog. You're unlikely to find significantly different conditions at Bremerton than elsewhere. However, on some days the fog burns off an hour or so before sunset, and the distribution of this can be somewhat variable. So toward the end of the daylight hours, some places may still be fogged in while other places may not be. As far as alternates go, I'd disagree with the claim that Boeing Field is reliably the best weather when conditions are foggy. It often is, but it really depends on the nature of the fog. If the fog has a little bit of elevation to it, then Boeing Field, being so close to sea level, can be landable (at least IFR). This is the current situation. But if the fog is right down to the water, then KBFI will be fogged in, while some of the airports at higher elevators may actually be fog-free, or at least will have the fog burn off earlier in the day. This would include Sea-Tac Airport and Paine Field (Snohomish County Airport). Also, getting away from the water can sometimes improve things. So (for example) Arlington Airport could have better conditions than Paine Field. But we don't really have that many airports far enough away from the water to help. All that said, unless you have Cat II or Cat III capabilities, you should anticipate that on this Wednesday, you might not be able to land anywhere in or around Puget Sound, including Bremerton. Make sure you've got a good alternate somewhere else (and just getting on the other side of the Cascades might not be sufficient...at this particular instant, it would be good enough -- though still not good VFR -- but it can get just as foggy over there sometimes). On top of all this, forecasts for when the fog will dissipate cannot be trusted. The fog could clear hours before they say it will, or it could not clear at all. It's important to know the forecasts (and of course current conditions), but I'd say that around here, fog-related forecasts are about as unreliable as weather forecasts get (other than "there will be fog" ![]() and that's saying something. Sorry to not have better news. Hopefully, Boeing Field will remain a good alternate. On the bright side, if you wind up landing in Seattle, you can easily take a ferry from there to Bremerton. That's always fun. ![]() Pete |
Thanks Peter and Karl Hopefully things will be OK on Wednesday. It is
only an hour flight so I guess we could come back here if it doesn't work out. Driving isn't much better with Snoqualmie pass only one lane each way. At least if a drive, I could cart more stuff back from the Beoing Surplus store! Mike MU-2 "Peter Duniho" wrote in message ... "Mike Rapoport" wrote in message ink.net... We will be flying (hopefully) to Bremerton, WA (KPWT) on Wednesday and the weather in the PNW does not look very good either now or in the forecast (widespread fog, vis 1/8sm). Are there any local fog effects at Bremerton? Are there airports in the area that are not as likely to have fog? Which ones? Thanks! As Karl says, the current weather pattern is one of widespread fog. You're unlikely to find significantly different conditions at Bremerton than elsewhere. However, on some days the fog burns off an hour or so before sunset, and the distribution of this can be somewhat variable. So toward the end of the daylight hours, some places may still be fogged in while other places may not be. As far as alternates go, I'd disagree with the claim that Boeing Field is reliably the best weather when conditions are foggy. It often is, but it really depends on the nature of the fog. If the fog has a little bit of elevation to it, then Boeing Field, being so close to sea level, can be landable (at least IFR). This is the current situation. But if the fog is right down to the water, then KBFI will be fogged in, while some of the airports at higher elevators may actually be fog-free, or at least will have the fog burn off earlier in the day. This would include Sea-Tac Airport and Paine Field (Snohomish County Airport). Also, getting away from the water can sometimes improve things. So (for example) Arlington Airport could have better conditions than Paine Field. But we don't really have that many airports far enough away from the water to help. All that said, unless you have Cat II or Cat III capabilities, you should anticipate that on this Wednesday, you might not be able to land anywhere in or around Puget Sound, including Bremerton. Make sure you've got a good alternate somewhere else (and just getting on the other side of the Cascades might not be sufficient...at this particular instant, it would be good enough -- though still not good VFR -- but it can get just as foggy over there sometimes). On top of all this, forecasts for when the fog will dissipate cannot be trusted. The fog could clear hours before they say it will, or it could not clear at all. It's important to know the forecasts (and of course current conditions), but I'd say that around here, fog-related forecasts are about as unreliable as weather forecasts get (other than "there will be fog" ![]() Sorry to not have better news. Hopefully, Boeing Field will remain a good alternate. On the bright side, if you wind up landing in Seattle, you can easily take a ferry from there to Bremerton. That's always fun. ![]() Pete |
On 2005-11-21, Mike Rapoport wrote:
We will be flying (hopefully) to Bremerton, WA (KPWT) on Wednesday One thing it does have is a drive-in theater right next door. I felt like a chump when I figured this out on my second trip through the pattern on my commercial night VFR XC. Tacoma Narrows is probably your second choice in bad weather, and it's better than PWT right now: KTIW 211653Z 00000KT 8SM OVC003 06/04 A3033 RMK AO2 SLP275 T00560044 KPWT 211635Z AUTO 01004KT M1/4SM OVC001 06/04 A3037 RMK AO1 KOLM 211646Z AUTO 08003KT 3SM BR OVC001 06/04 A3034 RMK AO2 Olympia (OLM) usually has the worst weather along my route when I fly from the Portland area up to Seattle, but I don't usually check as far NW as PWT. -- Ben Jackson http://www.ben.com/ |
Bremerton, WA | Mike Rapoport | Piloting | 4 | November 21st 05 05:10 PM |
