![]() Warrior Windows. A few weeks ago I asked if anyone has had any experience polishing out damage to plexiglas windows caused by a sloppy painter who got paint stripper on the plastic. No one has so I will answer my own question. No, the penetration is deep enough that the remedy will be enough to cause distortion. With that new information I ordered a new set of glass from Great Lakes Aero and went to work. The AP installed the windscreen and I tackled the sides. The job is straightforward enough without inherent problems. Great Lakes plexaglas fitted perfectly without any alteration. There were only three problems. First I tried to cheat the system and do the job without removing the seats. Contorting over the seats probably doubled the time necessary to do the job. second the #4 screws holding the bracket retainers had corroded or worn the screwholes enough to prevent the threads from engaging. This is easily remedied but a nusiance. It is also a nuisance to reinstall using the #4 screws. Next time I will have a handful of #6 screws. The third problem was not of my making. I opened a new tube of GE "Kitchen and Bath" silicone. The first several feet of the silicone was of noticably lower viscosity. The problem cleared up as I went along. Bad mistake. The low viscosity material never set up, it is still tacky, semifluid. I called GE to ask if I should give it more time or start over. The lady listened to my story and opined that if it had not set in a week it was not going to and that I should clean it up and go at it again. I could almost see her shrug when she said that it must have been a bad batch. Total time for the job would be about 6 to 10 hours. |
The learning curve is not too steep - if I remove the seats and have
plenty of new screws I believe I can do all 6 in 6 hours. I don't want a job. Leo |
MSDOS FS 5.1 runnable under Windows 2000/XP? | Bill Wolff | Simulators | 12 | January 13th 04 08:05 PM |
FS2002 failing with Windows XP - HELP !! | Jim Kilpatrick | Simulators | 2 | September 28th 03 01:33 PM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
Notebook PC Configuration for MSFS2004 | Paul H. | Simulators | 0 | July 18th 03 11:21 PM |
