Garmin 430 vs 196 questions
Old November 27th 05, 11:30 PM posted to rec.aviation.piloting
Default Garmin 430 vs 196 questions
Does the 430 have extended runway depictions like the 196 and other
handhelds have?
Does the 430 have the VNAV profile for descents like the 196 and other
handhelds have?
Old November 27th 05, 11:34 PM posted to rec.aviation.piloting
No, and yes, in that order.
On Sun, 27 Nov 2005 18:30:44 -0500, "John Doe"
handhelds have?
handhelds have?
Old November 28th 05, 03:30 AM posted to rec.aviation.piloting
Bill, as a user of a GNS430 who has never seen the extended runway
depictions feature of a 196 before, I am curious what that feature is.
Could you describe it?
I am able to get an extended runway centerline to almost any airport with
an instrument approach by choosing "Vectors to Final" procedure option on
the GNS430, but apparently that is not what the OP desires?
Thanks for any insight.
Peter
Old November 28th 05, 03:38 AM posted to rec.aviation.piloting
Extended runway on the 196 includes all runways, and not just the one
you have VTF to. Sort of a mini localizer icon extending out from all
runwayson the airport.
On Sun, 27 Nov 2005 22:30:15 -0500, "Peter R."
Old November 28th 05, 05:16 PM posted to rec.aviation.piloting
Ahhh, thanks.
Peter
Old November 28th 05, 06:35 PM posted to rec.aviation.piloting
"Peter R." wrote in message
Ahhh, thanks.
Peter
...and if the extensions on the 196 bother you, you can turn them off.
Old November 28th 05, 08:00 AM posted to rec.aviation.piloting
Peter,
A feature used on many handhelds to keep the pilot's eyes inside the
cockpit at a crucial time when they should be outside gd&r
Thomas Borchert (EDDH)
Old November 28th 05, 10:13 PM posted to rec.aviation.piloting
Ah, but you can setup same with the Direct button, scroll (twist) down to
course & put in your approach course. When you return to the map page, the
intercept course will be there. With an A/P, you use the heading bug to
intercept and arm the Nav/Approach. When you capture, the plane turns
inbound. The same technique works when intercepting an airway.
( I'm sure I skipped a step. )
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
"Bill Zaleski" wrote in message
handhelds have?
handhelds have?
Old November 28th 05, 10:18 PM posted to rec.aviation.piloting
Doesn't that take you to the airport reference point, though? Or doesn't
the difference between the ARP and the landing runway matter when you are
many miles from the airport?
Peter
Old November 28th 05, 10:29 PM posted to rec.aviation.piloting
It has been my experience that the procedure takes you to the end of the
runway. Perhaps it's the IFR nature of the product or the reference point
so close enough to the centerline that it's not apparent.
Although, when nav'ing Direct to the airport, I believe the GPS points to
the airport reference point. But at that point I'm entering the pattern VFR
anyway.
Thx, {|;-)
Peter
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
