I have heard it said that there are two types of tailwheel pilots: those
that have ground looped and those that will. A week ago, I graduated from the latter category into the former category. There was no shirt ripping ceremony for this milestone. Fortunately, there was also no torn flesh or bent metal. I post the story here so others can share my lessons learned. The background: My Piper PA-16 Clipper has been down since April for an engine overhaul (a story in itself). I had flown the plane about three hours since the overhaul, including four landings, all into a strong wind directly down the runway. I took some advice to change my landing technique and carry some power through the flare instead of cutting power as soon as I had the runway made. This had worked pretty well for those four landings. I needed to fly the airplane to an airport near my parent's in order to store it in my father's hangar for the winter. That airport has an East/West runway, and we had been having strong Southerly winds lately, so I waited for a day with more favorable winds to make the trip. Finally, the winds were 15 mph from the west, so I went for it. The airport has a 2600 ft asphalt runway with obstuctions at each end. My usual airstrip is 1800 ft with obstructions, so I didn't consider the runway marginal. My 9 yr old son wanted to come along since he hadn't had a chance to fly with me all year. The sequence: The ceiling was lowering as we got closer. It wasn't quite bad enough to turn around, but I was glad to get to the destination. Some of my worst landings have come with the "glad to finally be here" mindset, which should have been a warning. I didn't get slowed to pattern airspeed until downwind leg. On final, I noticed I was about 10 mph faster than target and made a mental note to get the speed down. About the same time, I noticed that I had a significant crab angle indicating a crosswind from the left. I focused my attention on setting up a slip to correct for the crosswind. I made a wheel landing close to the intended spot, left wheel first. So far, so good. I focused my attention on keeping it pointed straight and waited to start braking until my right wheel came down, which seemed to take longer than expected. I also decided that I needed to get the tailwheel down so I would have tailwheel steering to help with the crosswind. When I started to brake, the plane got squirelly in a hurry. Some dancing on the pedals kept it on the pavement. Suddenly, I realized that I might not have space to get stopped before the end of the runway. Just off that end of the runway is a busy road. I decided to take my chances with the weeds off the left side of the runway. I picked a spot between two runway lights and headed for the side. It turned much sharper than I would have chosen and I ended up going between a different set of runway lights than planned. As I slowed down in the weeds, I gave it some throttle to avoid coming to a stop and steered back onto the runway. My son thought the whole thing was pretty cool and loves to tell everyone we know all about it. I hated to end my flying season with a landing like that, but there was no way I was going around the pattern until I had a chance to thoroughly inspect for any damage. The only things I found out of place were some weeds in places that weeds don't grow. This wasn't the usual "loss of directional control" ground loop scenario, although directional control was marginal at points. I classify it as a ground loop because once I started toward the edge of the runway, the turn accelerated on its own. When I replay the sequence in my head, I don't have any trouble coming up with a list of mistakes I made along the way: 1) I should have anticipated the crosswind and not been surprised by it on final. The wind was 250 at 15mph which is not exactly west. Runway 29 is not exactly west either. Put those together and there is a pretty good crosswind component. I had computed the crosswind component with wishful thinking as opposed to trigonometry. 2) Obviously, airspeed control was an issue. I wasn't at pattern speed before entering the pattern and I never quite caught up. After I noticed the speed was high on final, I got distracted by the crosswind and didn't get it corrected. 3) Did I pull the power to idle after touchdown? I don't specifically remember doing that. It is such an automatic thing that I might not specifically remember it. The fact that the plane did not slow down like it usually would makes me suspicious that I was still carrying some power. Since I had to jockey the throttle around to get out of the weeds, I couldn't look at the tach afterwards to tell. 4) I didn't recognize the potential for an overrun in time to make a go-around. Once I touched down at the correct point and knew the runway was long enough, I presumed I was ok. Since it was a wheel landing, touching down did not imply normal touchdown speed. I was too focused on directional control to notice the speed issue in a timely manner. This incident reminds me of the trouble I had with crosswind landings as a student pilot. I never screwed up the crosswind correction itself, but it seemed to distract me from something else and I would botch the landing some other way. The only thing I have found to pat myself on the back for is the fact that I never allowed myself to become a passenger. I kept flying the airplane until I got it stopped on the runway (facing the wrong way and with a load of weeds, but on the runway). |
On Mon, 28 Nov 2005 21:34:12 -0500, "Reid & Julie Baldwin"
wrote: I took some advice to change my landing technique and carry some power through the flare instead of cutting power as soon as I had the runway made. Thanks for the story. I hope you're re-thinking the above advice at this point. Carrying power into the flare isn't necessary, extends your landing distance, and can get you in trouble as you found out. Also in x-wind conditions like you describe, a three point landing is a better idea in my opinion. You talked about wanting to get the tail wheel down so you had steering. If you did a full stall landing, you would have had the controllability you were looking for as soon as you touched the ground, as well as having better control of the airplane while it was flying. You also would have been slower than what's needed for a wheel landing which may have allowed you to avoid the problems you had completely. It's great you stuck with it and I'm glad it all worked out. Hope its a mild winter so you get to exercise the bird some. z |
"zatatime" wrote in message ... On Mon, 28 Nov 2005 21:34:12 -0500, "Reid & Julie Baldwin" wrote: I took some advice to change my landing technique and carry some power through the flare instead of cutting power as soon as I had the runway made. Thanks for the story. I hope you're re-thinking the above advice at this point. Carrying power into the flare isn't necessary, extends your landing distance, and can get you in trouble as you found out. Also in x-wind conditions like you describe, a three point landing is a better idea in my opinion. You talked about wanting to get the tail wheel down so you had steering. If you did a full stall landing, you would have had the controllability you were looking for as soon as you touched the ground, as well as having better control of the airplane while it was flying. You also would have been slower than what's needed for a wheel landing which may have allowed you to avoid the problems you had completely. It's great you stuck with it and I'm glad it all worked out. Hope its a mild winter so you get to exercise the bird some. z I think I see the three point vs. wheelie thread coming around again, which is ok by me as it is usually a good one. I just did a Goggle groups search on +"three point" +wheel and got 2,700 hits. The fourth hit listed was http://groups.google.ca/group/rec.av...46c09d7c32c538 which was a post by our once frequent poster highflyer which pretty much said everything I would want to say but better than I would. He even comments on holding a bit of power into the flair. I will comment that none of my better tailwheel instructors were fans of wheel landings (for light aircraft) and the best of them refused to teach wheelies at all. They agreed that wheelies usually meant too fast, with too much energy, needing too much rollout and with too little authority. The tail has to come down sooner or later, and a pilot's best friend is a firmly planted steerable tailwheel. The only time I have ever felt that I was just along for the ride was on my second (ever) solo (no instructor in backseat = more forward CG) landing (PA18) where I got caught with full flaps (shadowed rudder) and the tailwheel not fully planted. A blast of power helped and I did not ground loop but did talk with alligators, and had to explain how I got mud on the underside of the wings (no wheel pants). Happy landings, |
On 2005-11-29, Private wrote:
I think I see the three point vs. wheelie thread coming around again, which is ok by me as it is usually a good one. My take on it from plenty of time with light taildraggers such as the Cessna 140 is that wheel landings are best for gusty *headwinds*, where there is a chance that after touching down and starting to slow in the 3-point attitude, a strong gust will make you airborne again (and when the gust ends, without proper flying speed, leading to more trouble). You can 'stick it on' and with the low angle of attack, the gusts won't get you airborne again. Once you are slowed enough that the gusts can't make the plane airborne, you land the tail. Other than that, I always use 3-point landings. A steerable tailwheel can be both a blessing and a curse in a strong crosswind - just before you touch down in a strong crosswind, the tailwheel will *not* be centred because you'll have a bootful of rudder. This can result in a swerve if you're not ready for it, and you can't really take the rudder out... On the other hand, the Auster I fly from time to time has a free castoring tailwheel and is almost impossible to taxi on a hard surface in a quartering tailwind - the only steering you have then is the brakes, and those tiny little drum brakes are really awful. Given the choice I'd much rather have a steerable tailwheel. -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
On Tue, 29 Nov 2005 05:42:14 GMT, "Private"
wrote: I will comment that none of my better tailwheel instructors were fans of wheel landings (for light aircraft) and the best of them refused to teach wheelies at all. Gosh, why do they even bother to teach flying at all? If flying rates a 5 in the scheme of things, taildragger flying rates 7.5 and wheelies a 10. When I have to do a stall-down landing, I feel as dejected and worthless as if my father had taken the car away from me. -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
"Private" wrote in message
news:WSRif.649892$tl2.12997@pd7tw3no... "zatatime" wrote in message ... On Mon, 28 Nov 2005 21:34:12 -0500, "Reid & Julie Baldwin" wrote: I took some advice to change my landing technique and carry some power through the flare instead of cutting power as soon as I had the runway made. Thanks for the story. I hope you're re-thinking the above advice at this point. Carrying power into the flare isn't necessary, extends your landing distance, and can get you in trouble as you found out. Also in x-wind conditions like you describe, a three point landing is a better idea in my opinion. You talked about wanting to get the tail Depends on the airplane, depends on the brakes. I think I see the three point vs. wheelie thread coming around again, which is ok by me as it is usually a good one. Ok, here we go! I will comment that none of my better tailwheel instructors were fans of wheel landings (for light aircraft) and the best of them refused to teach wheelies at all. They agreed that wheelies usually meant too fast, with too much energy, needing too much rollout and with too little authority. The tail has to come down sooner or later, and a pilot's best friend is a firmly planted steerable tailwheel. Depending on the airplane, and depending on the brakes, this is either 100% Gospel or 100% B.S. or somewhere inbetween. I learned to fly in a C-120 with Cleveland toe brakes - and nearly always did wheelies because they were so much easier and I had so much more control before and after touchdown. I've put it into narrow paved strips with crosswinds strong enough to make the windsock look like it was made of iron. The trick was to come down hot and get the mains solidly planted on the ground. None of that floating around at low speeds with mushy controls trying to not get blown off the runway stuff. Then, with the mains planted (a good nudge forward on the wheel, eh?) you had all the control you could ever want with the toe brakes. Set the tail down whenever - it's not like the tailwheel had enough "power" to keep things straight on a blustery day anyhow. Too much rollout? Nah. ALWAYS made the first turn off beause I never found myself floating down the runway waiting for a three point to happen. :-) I was told, by a source that I consider reliable, that the way to make the absolute shortest landing possible in a DC-3 is to wheel it on, push the wheel _way_ forward to get the tail up and put a lot of force on the mains so they don't lock up when you stand on the brakes, and to generate lots of drag from the wing generating "negitive" lift. Never had a chance to try it myself though :-( The only time I have ever felt that I was just along for the ride was on my second (ever) solo (no instructor in backseat = more forward CG) landing (PA18) where I got caught with full flaps (shadowed rudder) and the tailwheel not fully planted. A blast of power helped and I did not ground loop but did talk with alligators, and had to explain how I got mud on the underside of the wings (no wheel pants). Different airplane, different brakes. YMMV. -- Capt. Geoffrey Thorpe The Sea Hawk At WowWay D0t Com |
On Tue, 29 Nov 2005 18:09:02 -0500, "Capt. Geoffrey Thorpe" The Sea
Hawk at wowway d0t com wrote: Depends on the airplane, depends on the brakes. Yep. This is about a Clipper. z |
Reid & Julie Baldwin wrote: I have heard it said that there are two types of tailwheel pilots: those that have ground looped and those that will. A week ago, I graduated from the latter category into the former category. There was no shirt ripping ceremony for this milestone. Fortunately, there was also no torn flesh or bent metal. I post the story here so others can share my lessons learned. *********************** It appears you learned more in that experience than 15 years of ho-hum flying and take offs/landings! Good for you that you learned so much from it. I doubt you'll repeat the mistakes. Using your power and wheel landings is nearly a whole new art form these days but is a technique we used in crop dusting for years and seldom ever went much past a short field landing roll. For us, time was money and we didn't make any sitting on the ground! If you can find an old ag pilot who is also a CFI, or is willing to fly with you and try to show you some of the tricks that we learn in countless landings it would be worthwhile. You certainly sound like a mature and level headed pilot so I'm sure you have already given something similar some good thought? Geeez I haven't flown a Clipper since...hmmm lemme see now.....must be close to 40 years or so? 1967-68? Cheers and Happy Holidays Ol Shy & Bashful The background: My Piper PA-16 Clipper has been down since April for an engine overhaul (a story in itself). I had flown the plane about three hours since the overhaul, including four landings, all into a strong wind directly down the runway. I took some advice to change my landing technique and carry some power through the flare instead of cutting power as soon as I had the runway made. This had worked pretty well for those four landings. I needed to fly the airplane to an airport near my parent's in order to store it in my father's hangar for the winter. That airport has an East/West runway, and we had been having strong Southerly winds lately, so I waited for a day with more favorable winds to make the trip. Finally, the winds were 15 mph from the west, so I went for it. The airport has a 2600 ft asphalt runway with obstuctions at each end. My usual airstrip is 1800 ft with obstructions, so I didn't consider the runway marginal. My 9 yr old son wanted to come along since he hadn't had a chance to fly with me all year. The sequence: The ceiling was lowering as we got closer. It wasn't quite bad enough to turn around, but I was glad to get to the destination. Some of my worst landings have come with the "glad to finally be here" mindset, which should have been a warning. I didn't get slowed to pattern airspeed until downwind leg. On final, I noticed I was about 10 mph faster than target and made a mental note to get the speed down. About the same time, I noticed that I had a significant crab angle indicating a crosswind from the left. I focused my attention on setting up a slip to correct for the crosswind. I made a wheel landing close to the intended spot, left wheel first. So far, so good. I focused my attention on keeping it pointed straight and waited to start braking until my right wheel came down, which seemed to take longer than expected. I also decided that I needed to get the tailwheel down so I would have tailwheel steering to help with the crosswind. When I started to brake, the plane got squirelly in a hurry. Some dancing on the pedals kept it on the pavement. Suddenly, I realized that I might not have space to get stopped before the end of the runway. Just off that end of the runway is a busy road. I decided to take my chances with the weeds off the left side of the runway. I picked a spot between two runway lights and headed for the side. It turned much sharper than I would have chosen and I ended up going between a different set of runway lights than planned. As I slowed down in the weeds, I gave it some throttle to avoid coming to a stop and steered back onto the runway. My son thought the whole thing was pretty cool and loves to tell everyone we know all about it. I hated to end my flying season with a landing like that, but there was no way I was going around the pattern until I had a chance to thoroughly inspect for any damage. The only things I found out of place were some weeds in places that weeds don't grow. This wasn't the usual "loss of directional control" ground loop scenario, although directional control was marginal at points. I classify it as a ground loop because once I started toward the edge of the runway, the turn accelerated on its own. When I replay the sequence in my head, I don't have any trouble coming up with a list of mistakes I made along the way: 1) I should have anticipated the crosswind and not been surprised by it on final. The wind was 250 at 15mph which is not exactly west. Runway 29 is not exactly west either. Put those together and there is a pretty good crosswind component. I had computed the crosswind component with wishful thinking as opposed to trigonometry. 2) Obviously, airspeed control was an issue. I wasn't at pattern speed before entering the pattern and I never quite caught up. After I noticed the speed was high on final, I got distracted by the crosswind and didn't get it corrected. 3) Did I pull the power to idle after touchdown? I don't specifically remember doing that. It is such an automatic thing that I might not specifically remember it. The fact that the plane did not slow down like it usually would makes me suspicious that I was still carrying some power. Since I had to jockey the throttle around to get out of the weeds, I couldn't look at the tach afterwards to tell. 4) I didn't recognize the potential for an overrun in time to make a go-around. Once I touched down at the correct point and knew the runway was long enough, I presumed I was ok. Since it was a wheel landing, touching down did not imply normal touchdown speed. I was too focused on directional control to notice the speed issue in a timely manner. This incident reminds me of the trouble I had with crosswind landings as a student pilot. I never screwed up the crosswind correction itself, but it seemed to distract me from something else and I would botch the landing some other way. The only thing I have found to pat myself on the back for is the fact that I never allowed myself to become a passenger. I kept flying the airplane until I got it stopped on the runway (facing the wrong way and with a load of weeds, but on the runway). |
I've probably mentioned this before, but my first "trip into the weeds" was
my graduation when getting my tailwheel endorsement from our long time ag pilot friend and mentor. He'd been putting me in ever increasing difficult situations with the SuperCub, culminating with severe crosswind landings... and I mean severe. 29 knots 90 degrees to the runway. Most people couldn't believe we were out in those winds, but I had several witnesses. If you think your primary instructor ever told you to use "more right rudder" you should have heard my instructor scream about getting that wing down and to plant that wheel on the ground... all the rudder and brake you need, then get this thing pointed into the wind as we slow to a stop!! 10 degrees F out, 29knot winds, and I was sweating so bad I wished I'd left my coat at home. Well... after two or three successful landings, it was off to the races. Didn't get the upwind wing low enough, too much speed, not enough rudder, not enough toe brake, a milli-second later we weather veined into the wind and exited the runway between two runway lights. 4" of snow helped slow us down and I got it going straight again, then hit the power and we were back in the air after a bit. After we came around and landed on an upwind runway, we talked over what happened and he told me that I'd now seen most things that can happen when flying a taildragger so he'd sign me off. We then took off for home, climbed up to 3000 feet, did some slow flight and he let me fly backwards for the first time. The next day I got some pretty good ribbing from my friends who'd seen the huge plume of snow and a little red and white SuperCub emerge from the cloud in a 45 degree crab. They said it looked like something out of a crazy movie and the airport manager who'd seen the tracks wondered if somebody with an ATV had been out playing in the snow. Jim |
wrote If you can find an old ag pilot who is also a CFI, or is willing to fly with you and try to show you some of the tricks that we learn in countless landings it would be worthwhile. You certainly sound like a mature and level headed pilot so I'm sure you have already given something similar some good thought? Geeez I haven't flown a Clipper since...hmmm lemme see now.....must be close to 40 years or so? 1967-68? Cheers and Happy Holidays Geez, that is as shameless an attempt to get a ride in someone's airplane as I have ever heard! That is what it is, isn't it? g -- Jim in NC |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Got my ground instructor ratings | Yossarian | Piloting | 7 | July 6th 05 03:21 AM |
| Switching to ground.... | David Rind | Piloting | 85 | April 16th 04 07:53 PM |
| ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 05:30 AM |
| What is a ground loop? | Mike | Piloting | 34 | July 30th 03 07:19 PM |
