Folks -
I know that if I get someone to sit inside and hold the flat Tinnerman fastener, I can screw in a machine screw from beneath the a/c. This is not the type of fasterner that clips on to the edge of the metal. For one person trying to either install or remove a screw from the afore mentioned fastener, is there a trick for holding it in place? - Mike |
On Sat, 12 Jul 2003 13:28:33 -0400, Michael Horowitz
wrote: Folks - I know that if I get someone to sit inside and hold the flat Tinnerman fastener, I can screw in a machine screw from beneath the a/c. This is not the type of fasterner that clips on to the edge of the metal. For one person trying to either install or remove a screw from the afore mentioned fastener, is there a trick for holding it in place? - Mike A dab of RTV a few days before you need to remove it? |
Wouldn't a wellnut be a better choice for this application? as
it already has rubber on it and you can place it from the outside in. clare, @, snyder.on, .ca wrote: On Sat, 12 Jul 2003 13:28:33 -0400, Michael Horowitz wrote: Folks - I know that if I get someone to sit inside and hold the flat Tinnerman fastener, I can screw in a machine screw from beneath the a/c. This is not the type of fasterner that clips on to the edge of the metal. For one person trying to either install or remove a screw from the afore mentioned fastener, is there a trick for holding it in place? - Mike A dab of RTV a few days before you need to remove it? |
Yes I know what it is:
http://www.aaronspushnuts.com/images...p210Wx130H.gif that's why I wonder why you wouldn't be better off using a wellnut: http://www.ondrives.com/code/product...=146&recid=725 clare, @, snyder.on, .ca wrote: On Sat, 12 Jul 2003 13:28:33 -0400, Michael Horowitz wrote: Folks - I know that if I get someone to sit inside and hold the flat Tinnerman fastener, I can screw in a machine screw from beneath the a/c. This is not the type of fasterner that clips on to the edge of the metal. For one person trying to either install or remove a screw from the afore mentioned fastener, is there a trick for holding it in place? - Mike A dab of RTV a few days before you need to remove it? |
afore mentioned fastener, is there a trick for holding it in place? - Mike Double stick foam tape - like is used to hold on auto trim. It also helps dampen vibration and protects the paint/finish from the sharp edges of the "nut". |
Michael Horowitz wrote in message . ..
Folks - I know that if I get someone to sit inside and hold the flat Tinnerman fastener, I can screw in a machine screw from beneath the a/c. This is not the type of fasterner that clips on to the edge of the metal. For one person trying to either install or remove a screw from the afore mentioned fastener, is there a trick for holding it in place? - Mike Tape one edge.... Craig C. |
Not a good idea to use any type of foam or paper tape like this.
Moisture may be a problem with paper tape and some foam tape. That's why I specified auto trim tape. The auto industry started using it not only to make application quicker but to reduce corosion. Quality foam tape is not hygroscopic and will hold less moisture than what will be retained in the thin air gap under a Tinnerman nut due to condensation. Long term degradation could still be a problem with the foam tapes. I have seen no evidance that they will last more than 15 to 20 years. Also if the Tinnerman nut is placed on a painted/plated/anodized surface the eventual rub through is going to be more of a corrosion/crack problem. 70's model VW bugs would rust from the inside out due to the foam filler used for sound deadning retaining water........all foam is not created equal. If you still worried about the foam part simply substitute some of the trim "tape" that is 100% adhesive. |
