Helicopter Question
Old November 30th 05, 11:55 PM posted to rec.aviation.piloting
Default Helicopter Question
As we were flying over to Newton, IA today, we started discussing icing and
snow -- something that we must constantly worry about in these parts for at
least the next 4 months.
As we were talking, we heard a "Flight for Life" 'copter on Unicom, which
got us to wondering how it is that these guys seem to fly in ANY weather.
Which got us to wondering further: How do helicopters handle ice? Are the
main rotor blades heated? Does the centrifugal force on those huge blades
prevent ice build up? What about the rest of the fuselage? How do they
de-ice themselves?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 1st 05, 01:46 AM posted to rec.aviation.piloting
Well, I can tell you that helis are not free from ice worry. I know
Apaches have heaters in their blades allowing them to de-ice. Sadly,
they can not use them because it causes problems with blade
delamination. Which really means the cure is worse than ice. Hehe.
Go figure. For $24Mil per Longbow, surely you didn't really expect an
all weather bird!
Long story short, if they fly in icing weather, I imagine are they have
some form of heating in their blades.
Old December 1st 05, 02:00 AM posted to rec.aviation.piloting
de-ice themselves?
Thanks!
Jumping in here -
Having worked for a medevac operator where most of the helicopters were
VFR only, my guess is this - they don't fly in IMC, let alone IMC with
the possibility of icing.
I asked our helicopter pilots and mechanics about this time after time,
and their reply was always the same - "Flying in the clouds, running
into ice, and shooting approaches are dangerous. I can't believe you do
it in an airplane."
I'm sure there's more to it, but I never got a good answer.
Old December 1st 05, 06:24 AM posted to rec.aviation.piloting
VFR only, my guess is this - they don't fly in IMC, let alone IMC with the
Of course, what's their definition of "IMC"?
Don't helicopters have a lower threshold for IMC than we fixed wing folks?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 1st 05, 04:05 PM posted to rec.aviation.piloting
It's a lower VFR ceiling and visibility limit, about half of
what the rest of us are held to. I guess we could call it an IMC
threshold. Helicopters can move forward slowly when the viz is bad, and
thereby avoid the cumulogranite.
But IMC and ice are two different hazards. I have heard of a
helicopter that runs hot bleed air through the rotors to deice them. I
don't know if that also applies to the tail rotor, or if it might be
electrically heated like a prop.
Dan
Old December 1st 05, 04:18 PM posted to rec.aviation.piloting
We can request "special VFR" that'll even allow for near "no vis" opt
IIRC.
Old December 1st 05, 08:05 PM posted to rec.aviation.piloting
"Flyingmonk" wrote in message
IIRC.
Special VFR still requires a minimum of 1 mile visibility.
Old December 1st 05, 04:17 PM posted to rec.aviation.piloting
Yes, IIRC, "special VFR"
Old December 1st 05, 08:55 PM posted to rec.aviation.piloting
It's not SVFR. Note the (c) and (d) paragraphs in our Canadian
Law:
602.115 Minimum Visual Meteorological Conditions for VFR Flight in
Uncontrolled Airspace
602.115 No person shall operate an aircraft in VFR flight within
uncontrolled airspace unless
(a) the aircraft is operated with visual reference to the surface;
(b) where the aircraft is operated at or above 1,000 feet AGL
(i) during the day, flight visibility is not less than one mile,
(ii) during the night, flight visibility is not less than three
miles, and
(iii) in either case, the distance of the aircraft from cloud is not
less than 500 feet vertically and 2,000 feet horizontally;
(c) where the aircraft is not a helicopter and is operated at less than
1,000 feet AGL
(i) during the day, flight visibility is not less than two miles,
except if otherwise authorized in an air operator certificate or a
private operator certificate,
miles, and
(iii) in either case, the aircraft is operated clear of cloud; and
(d) where the aircraft is a helicopter and is operated at less than
1,000 feet AGL
flight training unit operator certificate - helicopter,
miles, and
(iii) in either case, the aircraft is operated clear of cloud.
Dan
Old December 1st 05, 08:15 PM posted to rec.aviation.piloting
"Jay Honeck" wrote in message
news:XNvjf.611926$xm3.441724@attbi_s21...
Yes. See FAR 91.155 and 91.157. For all practical purposes, helicopters
can fly in arbitrarily low visibility. 91.155 grants them this right in
Class G airspace, and 91.157 grants them this right elsewhere (with a
Special VFR clearance).
Since a pilot can get a Special VFR clearance pretty much anywhere that
there *isn't* Class G airspace near the surface (generally below 700 or 1200
feet, depending), this means that as long as the helicopter pilot can see
well enough to avoid obstacles, the visibility is defined as being
sufficient, no matter how low it actually is.
Pete
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Lockheed wins Presidential helicopter contract Tiger Naval Aviation 0 January 29th 05 06:24 AM
aero-domains for helicopter pilots and helicopter companies secura Rotorcraft 0 June 26th 04 08:33 AM
