Water Ballast Upgrade
Old December 2nd 05, 08:07 PM posted to rec.aviation.soaring
Default Water Ballast Upgrade
Happy holidays all:
A project for me this Winter is to upgrade my ballast system on my
PIK-20. I have two questions and would appreciate any assistance.
(1) One of my bags has a single pinhole leak and I wonder if this can be
repaired in a reliable manner. The material seems to be a thick rubber
impregnated synthetic fabric and if it matters, is orange in color and
is the original factory PIK bag. If it is rubber, would a tire patch
material be reliable? If a repair would be deemed unsafe, who sells new
bags these days.
(2) Who do I contact to purchase the Nixon type dump valve.
Regards and many thanks,
Paul
Old December 2nd 05, 08:44 PM posted to rec.aviation.soaring
1)Tire patch kit material usually works with these bags.
2 Contact John Murray at Eastern Sailplane phone 513-897-5667
UH
Old December 3rd 05, 01:29 AM posted to rec.aviation.soaring
"P.Corbett " wrote in
ink.net:
Happy holidays all:
bags these days.
Paul
The original orange PIK ballast tanks are made of a multi layer fabric.
The water gets between the layers and cannot really be patched
successfully. At least I was not able to do it. I would patch the obvious
hole and then it would leak somewhere else. Patch that and it would leak
somewhere else yet! You may have better luck than I had...
The best answer is a set of Smiley bags. They can be purchased new ($400US
20 years ago. I have no idea what they cost today) or you can get a used
set out of an ASW-20 like I did. Many of the installations are quite
similar regardless of glider manufacturer. Smiley bags are really tough --
a great product.
The other issue with the PIK factory bags, at least in the PIK-20d that I
had, is that they hold WAY too much water. Mine held 50 gallons, and the
glider was 50 pounds under max. gross weight without the pilot and chute!
I don't recommend partially filling the tanks in a PIK. Wing dropping will
be a serious problem, in my experience. Other gliders with partial ballast
are no problem, but not so a PIK! Get bags that, when full, put you at the
wing loading that you desire.
-Bob Korves
Old December 3rd 05, 01:35 AM posted to rec.aviation.soaring
bags these days.
I think it is vinyl impregnated...
-Bob Korves
Old December 5th 05, 02:32 PM posted to rec.aviation.soaring
fabric.
I'd second that assessment. You can get various types of internal leaks
that cause the water to sit between layers and into that extra bladder
that seems to be built into the root end. Seems to be aimed at keeping
partial loads from shifting around too much. YOu end up with
un-dumpable water and uneven loads. But they look so nice and are so
nicely engineered, I just threw mine out a month ago - from UH's old PIK
circa early 80s. Thanks Hank.
Old December 3rd 05, 05:21 PM posted to rec.aviation.soaring
P.Corbett wrote:
Happy holidays all:
bags these days.
Paul
Thanks to Uniform Hotel and Bob Korves. The info is much appreciated.
Paul
ZZ
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
Schempp-Hirth water Ballast Cap vent Mod Paul M. Cordell Soaring 11 May 25th 05 10:33 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 05:21 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
