Does anyone know of any guidelines regarding the minimum safe distance
between oxygen equipment (tanks, high pressure lines, low pressure lines) and fuel system equipment (tanks, lines, valves)? Thanks! |
From AC 43 13-1B Acceptable Methods, Techniques, and Practices
8-30b Fuel Systems b. Routing. Make sure that the line does not chafe against control cables, airframe structure, etc., or come in contact with electrical wiring or conduit. Where physical separation of the fuel lines from electrical wiring or conduit is impracticable, locate the fuel line below the wiring and clamp it securely to the airframe structure. In no case should wiring be supported by the fuel line. 11-126. FLAMMABLE FLUIDS AND GASES. An arcing fault between an electrical wire and a metallic flammable fluid line may puncture the line and result in a fire. Every effort must be made to avoid this hazard by physical separation of the wire from lines and equipment containing oxygen, oil, fuel, hydraulic fluid, or alcohol. Wiring must be routed above these lines and equipment with a minimum separation of 6 inches or more whenever possible. When such an arrangement is not practicable, wiring must be routed so that it does not run parallel to the fluid lines. A minimum of 2 inches must be maintained between wiring and such lines and equipment, except when the wiring is positively clamped to maintain at least 1/2-inch separation, or when it must be connected directly to the fluid-carrying equipment. Install clamps as shown in figure 11-10. These clamps should not be used as a means of supporting the wire bundle. Additional clamps should be installed to support the wire bundle and the clamps fastened to the same structure used to support the fluid line(s) to prevent relative motion. "Lakeview Bill" wrote in message ... Does anyone know of any guidelines regarding the minimum safe distance between oxygen equipment (tanks, high pressure lines, low pressure lines) and fuel system equipment (tanks, lines, valves)? Thanks! |
DG-400 Oxygen Bottle Problems | [email protected] | Soaring | 23 | September 8th 05 10:43 PM |
Tired of bumping along to Oshkosh? | Rich S. | Home Built | 43 | August 10th 05 04:55 AM |
Fuel contamination and other basic survival instincts | Greg Farris | Piloting | 17 | July 14th 05 10:45 PM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
FAA to order fuel tank modifications on 3,800 commercial airplanes | Larry Dighera | Piloting | 2 | February 22nd 04 02:49 PM |
