Ideas for a commercial long x-c?
Old December 6th 05, 06:55 AM posted to rec.aviation.piloting
Default Ideas for a commercial long x-c?
I fly out of Hawthorne CA (KHHR) and would like to hear some ideas for a
250-mile cross country. This is to fulfull the long x-c requirement forr
the commercial license. I went up to Oakland this past summer, so I was
thinking something more easterly.
I'll be in a Cessna 172RG. I'm just going to fly out and back, departing
Hawthorne in the afternoon so the return leg will be at night and count
towards my 5 solo night hours.
Old December 6th 05, 10:33 AM posted to rec.aviation.piloting
Phoenix or Las Vegas, if the weather is good.
"Yossarian" wrote in message
. 97.142...
some ideas for a
requirement forr
summer, so I was
back, departing
night and count
Old December 6th 05, 01:32 PM posted to rec.aviation.piloting
I was gonna suggest LV also. Take a lot of quarters!
Old December 6th 05, 02:41 PM posted to rec.aviation.piloting
Yeah, do two different W&B worksheets. One for the amount of quarters
you'll be taking with you, and another for the amount you'll be taking
back!
Old December 6th 05, 04:54 PM posted to rec.aviation.piloting
Thanks for the suggestions. Unfortunately Las Vegas is only 203 miles
so it isn't far enough. Phoenix is 317 which is a little far... I'm
looking for something just over 250. I don't have charts for that area
yet, I gotta stop by the airport after work today.
back!
Old December 6th 05, 05:13 PM posted to rec.aviation.piloting
So, land further away, and then come back to Las Vegas, if that's your goal.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old December 6th 05, 05:37 PM posted to rec.aviation.piloting
On 6 Dec 2005 08:54:40 -0800, "Yossarian"
wrote in . com::
Unfortunately Las Vegas is only 203 miles so it isn't far enough.
Mesquite (67L) is about the right distance*, and a nice, modern, well
lit field near a VORTAC (located between KLAS and St. George).
http://www.airnav.com/airport/67L
http://www.airnav.com/depart?http://...0512/SW4TO.PDF
TAKE-OFF MINIMUMS AND (OBSTACLE) DEPARTURE PROCEDURES
MESQUITE, NV
MESQUITE
TAKE-OFF MINIMUMS: Rwy 1, 900-3, or std. with a min.
climb of 620' per NM to 2400.
DEPARTURE PROCEDU Rwy 1, climbing left turn,
Rwy 19, climbing right turn. All aircraft climb direct
MMM VORTAC. Aircraft departing MMM R-149 CW
R-220 climb on course. All others continue climb via
MMM R-196 to 6100 and reverse course to cross MMM
VORTAC at or above: R-221 CW R-270 and R-331 CW
R-060, 6100; R-271 CW R-330, 7300; R-061 CW
R-150, 8300.
24 NOV 2005 to 22 DEC 2005
* From KHHR- Jack Northrop Field/Hawthorne Municipal Airport
To 67L- Mesquite Airport:
272.6 nautical miles NE
Initial true course: 049
There won't be a full moon until the 15th:
http://aa.usno.navy.mil/data/docs/RS_OneYear.html
Old December 7th 05, 02:19 AM posted to rec.aviation.piloting
Try StGeorge UT...
when I did my long x-c for the commercial.. I launched from VGT and
"repositioned" to Mesquite NV. And started my "official" x-c from there.
Mesquite to SanDiego Gillespie field did the trick.
Maybe you can go south first.. land.. regroup and start your 250nm x-c from
the southern point to VGT or Mesquite or St George. Then return to
Hawthorne.
BT
back!
Old December 7th 05, 01:34 PM posted to rec.aviation.piloting
Add a few land marks in between that'll make the trip long enough and
more interesting, instead of flying direct. :)
Old December 6th 05, 05:33 PM posted to rec.aviation.piloting
. 97.142...
Prescott, AZ (KPRC) ?
Not quite as far as Phoenix (but almost...)
Kingman, AZ is 231nm if flown direct but I bet you could bend your route
around some getting out of SoCal airspace and stretch it to 250.X ..
Jay Beckman
PP-ASEL
Chandler, AZ
Is MDHI going to make it? Matt Barrow Rotorcraft 55 June 12th 05 05:04 PM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 02:40 PM
Another Addition to the Rec.Aviation Rogue's Gallery! Jay Honeck Home Built 125 February 1st 04 05:57 AM
Another Addition to the Rec.Aviation Rogue's Gallery! Jay Honeck Piloting 129 February 1st 04 05:57 AM
