Plexiglass protective paper
Old December 12th 05, 07:08 PM posted to rec.aviation.homebuilt
Default Plexiglass protective paper
Anybody had any experience Peeling Protective Paper from
Plexiglass??---When it's old & dried out---everything I've used to try
to soften the old glue also softens the plexi & leaves it with an
orange-peel finish. I have several 12" sq pieces, the center will
finally come once you get out there, but the edges are no-luck.
Thanks in advance
Jerry
Old December 12th 05, 07:15 PM posted to rec.aviation.homebuilt
Thanks in advance
Jerry
Try either denatured alcohol or rubbing alcohol. They will soften the
adhesive and will not harm the plexiglass.
Remve "_" from email to reply to me personally.
Old December 13th 05, 12:30 AM posted to rec.aviation.homebuilt
"Ken Moffett" wrote
Do not use denatured alcohal to soak off paper from Plexiglas. I've had it
craze very badly from exposure to alchol. I had a Plexiglass cylinder that
some one filled with ethonal, and in a short time it fractured all over
and
fell apart.
Rubbing alcohol is methanol. Big difference from ethanol. That said, I
have no idea if methanol will harm plexi.
Jim in NC
Old December 13th 05, 02:03 AM posted to rec.aviation.homebuilt
and
fell apart.
I
Also "denatured" alcohol at the local hardware store can be denatured
with just about anything of which the BATF approves - like acetone,
toluene, and other solvents. Makes for some costly surprises if you
don't test first..........
Leon McAtee
Old December 21st 05, 03:59 AM posted to rec.aviation.homebuilt
Use Mineral spirits. Make up a little tray out of an old picture frame
fill with mineral spirits. Place plexi in there and cover with another
piece of polyethethelene to reduce evaporation. Should soften enough to
peel the paper off.
If that doesn't work blast it with a pressure washer
Old December 13th 05, 04:32 AM posted to rec.aviation.homebuilt
Most rubbing alcohol is isopropyl alcohol but it can also be denatured
alcohol (ethanol with some bitter substance added to decrease the chances of
it being drunk). I am not aware of any rubbing alcohol having methanol.
Methanol is very toxic - causes blindness and death. Methanol is commonly
used as an antifreeze in windshield washer fluid (note the poison labels).
Jerry in NC
"Morgans" wrote in message
it
that
and
fell apart.
Jim in NC
Old December 19th 05, 10:30 PM posted to rec.aviation.homebuilt
Unfortunately the additives used to denature ethanol are
not merely bitter, they are toxic, typically methanol,
or ketones. At one time sulphuric acid was used.
Ethanol denatured with methanol is sometimes still used as
rubbing alcohol. I have some at home. (google for 'surgical spirits')
But you are right, typical rubbing alcohol is 70% isopropynol
with the balance being water.
FF
Old December 12th 05, 10:55 PM posted to rec.aviation.homebuilt
Thanks in advance
Jerry
Kerosene
"jerry wass" wrote in message
Thanks in advance
Oh, you poor sole! BTDT !!!
The only thing I have had any luck with, is getting a beer or three, putting
some music on, and getting ready to have lots of patience. If you have more
money than time, get a new piece.
Some very hot water and a big squirt of liquid dishwashing detergent may
help to loosen the bonds a little, but expect no miracles.
I have never tried cigarette lighter fluid on plexi. Does it mess with the
finish? That is always my solution to weaken old glue. Also "goof off"
glue remover may help, but I have never tried it on plexi. It is in the
painting section at hardware stores.
Jim in NC
Jim in NC
Paper Cutter Mike Rapoport Home Built 3 August 23rd 05 07:10 PM
SSA CRC Mandatory ELT Position Paper Posted - SRA Site Ken Kochanski (KK) Soaring 9 January 18th 05 03:52 AM
You can now buy inkjet decal paper by the sheet Charlotte Gaisford Home Built 0 November 8th 04 01:59 PM
Tracking the Elusive Tracing Paper Veeduber Home Built 18 August 30th 04 12:53 PM
Looking for sand paper rolls and adhesive Roger Halstead Home Built 9 August 8th 03 08:58 AM
