Showing metal at 1,100 hours
Old December 16th 05, 04:36 PM posted to rec.aviation.owning
Default Showing metal at 1,100 hours
I've put over 1,000 of the 1,100 hours on this new O-360-C4f. Changed
the oil religiously. I didn't baby the engine but didn't abuse it
either. Always hangered etc.
My last oil analysis showed a doubling of iron 47.9ppm to 101.0ppm with
36 hours on the oil. Everything else normal. We did the filter and we
found very fine iron filings or dust with a magnet. How much - hard to
tell. No chunks though.
We're thinking cam and lifter.
My mechanic is playing it safe - called Signature and Mattituch who
recommended no more flying, split the case, and fix or overhaul.
I want some second opinions. I could fly 10 more hours and take another
look. We could pull a cylinder and check the cam I'm told.
I've read about Second OilPINION and Howard Felton - a knowledgeable
analysis of the metal seems like money well spent. Is he still in
business? Anyone know anyone else who can do this?
Any other factors? My exhaust manifold/heat exchanger broke and I flew
for 10 to 36 hours with it broken. Parts 'banging' around under the
cowling etc. Discovered it during oil change. I did let it sit without
running for 60+ days - a first for this aircraft.
Thoughts?
Maulesitter.
Old December 16th 05, 04:46 PM posted to rec.aviation.owning
Hey MD, I don't have any advice, but ... sorry to hear that. I feel your pain.
Dave
Old December 16th 05, 04:47 PM posted to rec.aviation.owning
Thoughts?
Maulesitter.
Have you EVER done a cold start with no preheat below 32 degF? or maybe
even higher temps with summer weight oil?
Old December 16th 05, 04:51 PM posted to rec.aviation.owning
Another airplane on our field with 360 just lost the cam and lifter
last month and it caused big time damage while they piddled around
with, "well, lets fly it a while and look at the filter again."... The
lifter spalled off chunks shortly after that decision and the pistons
picked the debries up on the skirts and scored the cylinders... His
'repair' on a 700 hour engine is now $10K....
Pull a cylinder and borescope the cam... Not a lot of bucks or downtime
to do this and you can make an informed decision, not a guess...
denny
Old December 17th 05, 09:53 PM posted to rec.aviation.owning
That seems to be the most rational move to make at this point.
Old December 18th 05, 01:13 AM
clipclip clipclip is offline
Junior Member
First recorded activity by AviationBanter: Nov 2005
as others have said, it's definitely a good idea to take a look at tha cam and lifters. but make sure you examine all of them - one can take a turn for the worst, while the other ones may not show much damage initially.
frank
Old December 16th 05, 05:11 PM posted to rec.aviation.owning
http://www.sacskyranch.com/camshaft.htm
Some cam pics and comments.
I'd pull a cylinder and do some looking. I've been told by our AI that once
cams start spalling, they don't stop and the chunks usually get bigger.
"Maule Driver" wrote in message
news
Thoughts?
Maulesitter.
Old December 16th 05, 11:24 PM posted to rec.aviation.owning
Maulesitter,
You do not need to pull a cylider to look at the cam.
Just pull the rocker arms, push rods, tubes and lifters. You can peer in
the hole with a flash light and mirrow.
Michelle
with 36 hours on the oil. Everything else normal. We did the filter
and we found very fine iron filings or dust with a magnet. How much -
hard to tell. No chunks though.
another look. We could pull a cylinder and check the cam I'm told.
flew for 10 to 36 hours with it broken. Parts 'banging' around under
the cowling etc. Discovered it during oil change. I did let it sit
without running for 60+ days - a first for this aircraft.
Thoughts?
Maulesitter.
Old December 17th 05, 12:48 AM posted to rec.aviation.owning
Like Michelle said!
Or pull the jug , right rear, and have a boo at the cam & lifters.
With Lyc's it is most often the back 2-3 lobes..
Dont 'ask.....
It WAS a 2700 hr engine tho.....
Dave
On Fri, 16 Dec 2005 23:24:45 GMT, Michelle P
Maulesitter,
Michelle
Thoughts?
Maulesitter.
Old December 17th 05, 02:01 AM posted to rec.aviation.owning
Maulesitter,
Michelle
Unless it's one of the few Lycomings running around with
automotive-style barrel lifter bodies, the engine has mushroom lifter
bodies. The portion that rides on the cam lobe has a larger o.d. than
the rest of the body (and the corresponding hole in the crankcase).
TC
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
First 2 1/2 hours PPL(H) today! Simon Robbins Rotorcraft 42 September 25th 05 12:54 AM
KA6E and Foka 4 comparable metal ships - Laister Nugget LP15 Matthieu Soaring 18 June 7th 05 01:20 AM
Metal fatigue in Lycoming engines limiting its TBO? Wolfgang Home Built 11 November 7th 04 01:46 PM
