Cambridge Vario Front Glass
Old December 17th 05, 06:11 PM posted to rec.aviation.soaring
Default Cambridge Vario Front Glass
I have care and feeding of an older model Cambridge electric vario. The
front glass has been cracked, and I need to try to find a replacement.
The only ID my AME can find on the casing is the following part number:
500-1119-9005 If anyone can identify the model number and, more
importantly, where I might source a new front glass for it, I'd greatly
appreciate it.
Thanks in advance,
Sandy Stevenson.
Old December 17th 05, 06:50 PM posted to rec.aviation.soaring
Hi Sandy,
I suggest you give Cambridge a call at (662) 280-7610 (USA).
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
"Sandy Stevenson" wrote in message
appreciate it.
Thanks in advance,
Sandy Stevenson.
Old December 17th 05, 07:47 PM posted to rec.aviation.soaring
Your variometer is a vintage Cambridge CVS40, 50 or CVS60 depending on the
display being in Knots, feet or M/S (all are the same, just different
markings on the dial).this variometer is quite "vintage" from the late
1960's to mid 70's....and may not be worthy of your efforts to repair but if
you give me a call I have a few of these here that are non-functional
(probably could be repaired....but..why?? ..) if you'll pay the postage,
I'd be happy to send you one for free that you can scavenge the glass face
plate from ....
tim
Wings & Wheels
www.wingsandwheels.com
appreciate it.
Thanks in advance,
Sandy Stevenson.
Old December 18th 05, 05:22 PM posted to rec.aviation.soaring
Tim/Santa,
Let me be the first.....
I have a few cracks on my poor old glider, do you have a spare you can
mail me?
Thought I'd get you while the spirit of Christmas is upon you!
Best regards and Merry Christmas!
Bob
Old December 18th 05, 11:33 PM posted to rec.aviation.soaring
there's your spare parts!)
tim
Please visit the Wings & Wheels website at:
----- Original Message -----
Newsgroups: rec.aviation.soaring
Sent: Sunday, December 18, 2005 9:05 AM
Subject: Wanted: budget audio vario
It looks as if my CAV50 is on its way out, so I'd like to replace it.
Since the glider is, alas, not worth much now, I am therefore in the
market for something economical at 80mm. Has anyone out there got
something suitable going spare?
Ian
Tim/Santa,
mail me?
Bob
Old December 20th 05, 06:03 AM posted to rec.aviation.soaring
Hi Bob,
You do realize that the offer is for the recipient to pay the freight
to receive a component whose internals may no longer be entierly
functional, but whose external appearance is still clear and good
looking?
Therefore you've just offered to pay the freight to clear out some of
his fuselage and wing components which still look good but are
structurally unsound?
Bob, such a wonderful Christmas gift!
I had no Idea you were so generous!
Cheers,
Sandy Stevenson.
Tim/Santa,
mail me?
Bob
Old December 18th 05, 06:18 PM posted to rec.aviation.soaring
Hi Tim,
Great offer. Ours must be a CVS40, since it's calibrated in knots.
It has been working just fine, except that the cracked glass has been
pushed in and has pinned the needle to the backing. The cracks have
also become so extensive as to make it almost impossible to read.
I'm going to just double check that we can get the front glass off
without removing ithe vario completely, then I'd be happy to take you
up on your offer.
Cheers,
Sandy Stevenson.
Old December 18th 05, 11:31 PM posted to rec.aviation.soaring
you're quite welcome..........I've had many variometers apart in the past
just to see what each is made like and most are quite simple to open and
examine.the CVS40/50 types are actually very easy.there should be (if they
haven't fallen out) 3 self taping screws in the rear of the case.just remove
these and the guts will all come out from the rear.....actually, replacing
the case with glass intact is the easiest way to fix yours if the glass is
not free the from the case.....just let me know if you need this one
best regards
Tim
Hi Tim,
up on your offer.
Cheers,
Sandy Stevenson.
Old December 18th 05, 04:33 AM posted to rec.aviation.soaring
appreciate it.
Thanks in advance,
Sandy Stevenson.
I had the same problem and just cut out a new face from sheet
plexy/polycarb the same thickness. Belt sander or grinder to round the
corners...Easy, quick, cheap, looks fine and works good. Make sure you
don't take the whole instrument apart to get the face off. It comes
off the front without even having to remove the unit from the panel.
At least mine did.
Old December 18th 05, 06:21 PM posted to rec.aviation.soaring
Thanks for the suggestion. We had thought of just having the glass
cut, but couldn't find anyone locally with a drill fine enough to
replicate the hole for the attachement screw.
The plexy may be easier to do, so that is much appreciated.
Best Regards,
Sandy Stevenson.
Old Cambridge Vario Wiring Stewart Hamey Soaring 3 November 10th 05 11:40 PM
Old Cambridge Vario Wiring Stewart Hamey Soaring 1 November 2nd 05 09:01 PM
Old Cambridge Vario Wiring Stewart Hamey Soaring 0 October 31st 05 12:08 AM
FS: Cambridge & Ball Vario Tim Hanke Soaring 3 October 1st 05 01:30 PM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
