"Direct when able"
Old August 29th 03, 05:46 AM
Mitchell Gossman
Default "Direct when able"
When instructed to fly a heading then "Direct XYZ when able", does a
controller expect a call when you are in fact able and will be turning
on course? Usually it is a trivial turn since the heading they give is
a good guess for direct course.
I've had conflicting experience. One time after being told the above,
I responded "I'm able to go direct now" and his ackowledgement had a
"who cares? Just do it" tone to it.
Just a few days ago, I made the 8 degree turn to navigate directly to
the VORTAC, and when the shift change at approach took place, the new
controller asked what my heading was, whether I was picking up the
VORTAC, and when I told him that I was navigating direct, he seemed
surprised.
Mitchell Gossman
St. Cloud, Minnesota
Old August 29th 03, 06:49 AM
Michael 182
Don't know if there is a "right way", but I just fly the heading until I can
navigate direct. I've never updated the controller when I'm heading direct
to the waypoint unless he requested it.
Michael
"Mitchell Gossman" wrote in message
m...
on course?
Old August 29th 03, 08:59 PM
JerryK
I usually tell them before I make the course change. It might be a few
minutes before I am able to go direct and letting the controller know helps
ensures everyone is on the same page.
jerry
m...
surprised.
Mitchell Gossman
Old August 30th 03, 02:10 PM
Allan9
VOR/VORTAC/TACAN NAVAID's
Normal Usable Altitudes and Radius Distances Class
Altitude
Distance
(miles)
T
12,000 and below
25
L
Below 18,000
40
H
Below 14,500
40
H
14,500 - 17,999
100
H
18,000 - FL 450
130
H
Above FL 450
100
Altitude and distance limitations need not be applied when any of the
following conditions are met:
a. Routing is initiated by ATC or requested by the pilot and the following
is provided:
1. Radar monitoring.
2. As necessary, course guidance unless the aircraft is /E, /F, /G, or
/R equipped.
NOTE-
1. Para 4-4-1, Route Use, requires radar monitoring be provided at FL
450 and below to aircraft on random (impromptu) RNAV routes.
Para 5-5-1, Application, requires radar separation be provided for these
routes at FL 450 and below.
2. When a clearance is issued beyond the altitude and/or distance
limitations of a NAVAID, in addition to being responsible for maintaining
separation from other aircraft and airspace, the controller is responsible
for providing aircraft with information and advice related to significant
deviations from the expected flight path.
Old August 31st 03, 04:35 AM
Bob Gardner
I tell my readers (and anyone else who will listen), that "when able" also
means "when you can proceed without hitting anything." Simply getting a good
needle is not the whole story. ATC has no responsibility for keeping you out
of the trees until you reach their MIA.
Bob Gardner
m...
surprised.
Mitchell Gossman
Old August 31st 03, 02:18 PM
Paul Tomblin
The other day I was north of Syracuse and I asked for direct Rochester
(instead of flying down to Syracuse and following V2). The controller
cleared me "direct when able", and when the GPS showed that I would just
barely miss the restricted area (R-5203?), I turned. But evidently that
was too close for her, because a few minutes later she turned me 45
degrees off my course for a few minutes before she let me turn back.
I wonder if I should have said something to her about seeing the
restricted area on my GPS?
Paul Tomblin , not speaking for anybody
Simulated editor war, conducted by seasoned professionals in a controlled
environment. Don't try this at home.
-- Christian Bauernfeind
Old September 3rd 03, 11:32 PM
Steven P. McNicoll
"Paul Tomblin" wrote in message
The book is a bit vague on that.
FAA Order 7110.65N Air Traffic Control
Chapter 9. Special Flights
Section 4. Special Use and ATC Assigned Airspace
9-4-2. SEPARATION MINIMA
Unless clearance of nonparticipating aircraft in/through/adjacent to a
Prohibited/Restricted/Warning Area/MOA/ATCAA is provided for in a Letter of
Agreement (LOA) or Letter of Procedure (LOP), separate nonparticipating
aircraft from active special use airspace by the following minima:
a. Assign an altitude consistent with para 4-5-2, Flight Direction, and
4-5-3, Exceptions, which is at least 500 feet (above FL 290-1000 feet)
above/below the upper/lower limit of the Prohibited/Restricted/Warning
Area/MOA/ATCAA.
REFERENCE-
FAAO 7210.3, Prohibited/Restricted Areas, Para 2-1-16.
b. Provide radar separation of 3 miles (En route Stage A/DARC, FL 600 and
above - 6 miles) from the special use airspace peripheral boundary.
c. Clear aircraft on airways or routes whose widths or protected airspace
do not overlap the peripheral boundary.
d. Exception. Some Prohibited/Restricted/Warning Areas are established for
security reasons or to contain hazardous activities not involving aircraft
operations. Where facility management has identified these areas as outlined
in FAAO 7210.3, Facility Operation and Administration, vector aircraft to
remain clear of the peripheral boundary.
NOTE-
Nonparticipating aircraft refers to those aircraft for which you have
separation responsibility and which have not been authorized by the using
agency to operate in/through the special use airspace or ATCAA in question.
Clearly, if the controller is vectoring you around SUA then 3 miles is the
minimum. If you're on an airway that clears the SUA then you're deemed to
be clear of the SUA without regard to how close you actually are to the SUA
boundary. But if you're proceeding via your own navigation direct to a fix
is just being clear of the SUA boundary good enough?
Old October 21st 03, 01:19 AM
Hankal
probably only if you had filed /I or /G . . .then you are telling her
you have an IFR capable GPS =
I just did a 1500 mile XC. Filing 172/U
I received at least 4 transmissons. Direct to Savana, Columbia St. Augustine.
Controller never queried if able.
I do have a VFR GPS with me, which helps me.
Hank N1441P
Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN ChuckSlusarczyk Home Built 105 October 8th 04 12:38 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
Need Info - Flying to Calgary (CYYC) Dave Johnson Instrument Flight Rules 1 August 17th 03 03:51 AM
Reflections on first trip to Canada from US Mike & Janet Larke Instrument Flight Rules 1 August 9th 03 12:57 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
