Low and high altitude airways
Old September 4th 03, 11:37 PM
"K. Ari Krupnikov" wrote:
I've never flown a jet airway (and probably never will, except on an
airliner), but here's a question. There are fewer J routes than V, and
they connect fewer navaids. So it can happen that your destination is
quite far from the nearest high-altitude navaid or interaction. Do you
still file direct from the closest high-alt waypoint, go direct to a
nearby navaid, or use low-altitude routes for your arrival?
Ari.
If the destination is a major airport there will usually be a
high-altitude VOR in the proper position. Or, there will be a STAR
routing which, although it may use low-alitude VORs, it has been flight
inspected to be useable at the altitudes expected.
For flights into remote areas that may not have a nearby high VOR (unusal,
but possible) filing of a Victor airway for the last 200 miles, or so, is
acceptable, or even "the radials of V-999."
Old September 5th 03, 01:18 AM
JerryK
About 40% of my flying is above FL180. I usually just file direct from the
end of the DP to point along the approach, or perhaps a point from which I
believe the approach will begin. Thus far I have never been give a
clearance with a jet airway. However, I file /G and I am based on the West
Coast. People that I know in the NE seem to get jet airways in their
clearance. However, they very seldom fly the airway that far. They are
usually cleared direct early in the procedure.
As far as filing goes, the people I know in the NE will file the jet airway
to the nearest point to the expected approach or as close as they can, and
then file either direct or Victor airway from that point to the destination,
or a waypoint near the destination.
jerry
"K. Ari Krupnikov" wrote in message
Ari.
Old September 5th 03, 01:52 AM
Steven P. McNicoll
Any/all of the above, and STARs as well.
