Cessna air vents
Old December 29th 05, 06:32 PM posted to rec.aviation.owning
Default Cessna air vents
Hello everyone. It's getting a little chilly around here now; I have seen
the "ventubes" that are being sold for $75 apiece. Has anyone simply taped
over the inlet in the wing root? I was thinking of giving this a try,
seeing that there is no real need for cold air ventilation at this time of
year.
Matt
Old December 29th 05, 07:16 PM posted to rec.aviation.owning
year.
The problem is, just putting plain old duct tape on the vents isn't
legal. To make it legal, what you need to do is get a FAA 337 form
and a roll of STC duct tape. Use the STC duct tape to tape the 337
form over the vent and you're good to go.
Old December 29th 05, 08:25 PM posted to rec.aviation.owning
Rather than tape on the outside, try taping over the outlets on the
inside of the cabin. Another option is stuffing a bit of foam into
the outlets inside the cabin. I went the foam route on the
outlets in the cherokee -- they're close to the floor. Which means
in nice, sunny weather, the body and head are nice and warm, and
the feet are icicles...
Old December 29th 05, 08:40 PM posted to rec.aviation.owning
year.
Use the clear packing tape, nobody at a distance, can see it...
Old December 29th 05, 10:54 PM posted to rec.aviation.owning
Does the term "red rubber ball" have any help here?
"Matt" wrote in message
m...
taped over the inlet in the wing root? I was thinking of giving this a
try, seeing that there is no real need for cold air ventilation at this
time of year.
Matt
Old December 29th 05, 11:06 PM posted to rec.aviation.owning
Have you considered having a cockpit fire?
Old December 29th 05, 11:43 PM posted to rec.aviation.owning
Yes, but I find that gathering the kindling before the flight is a bit of a
hassle.
I would prefer to just minimize the cold air entering past the vents.
Old December 30th 05, 02:58 AM posted to rec.aviation.owning
Matt wrote:
: "Brien K. Meehan" wrote:
: Have you considered having a cockpit fire?
: Yes, but I find that gathering the kindling before the flight is a bit of a
: hassle.
Try dumping the 100LL from the fuel samples into a can full of sand and
igniting it. It should keep you nice & warm...
: I would prefer to just minimize the cold air entering past the vents.
The flight school that I went to has a large number of beat-up 152's.
They duct tape the air intakes at the wing root each year. It works great.
Aaron C.
Old December 30th 05, 04:02 AM posted to rec.aviation.owning
Ah, okay. It's just as well, since those vents might be really, really
handy to use if you actually did have a fire in the engine compartment
or instrument panel, and you wouldn't be able to they were taped shut
from the outside. Now, just don't have an unintentional fire, and
you'll be all set.
Old December 30th 05, 03:17 PM posted to rec.aviation.owning
you'll be all set.
Open the window?
Michelle
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Piloting 1 November 4th 03 12:57 AM
