"Bravo8500" wrote in message om... In a recent FAA sponsored seminar that I attended, a retired Tower Controller mentioned in his presentation that IMC flight in Class G airspace without a clearance was actually legal as long as the aircraft and pilot were both instrument qualified. In other words if I wanted to I could take my current IFR rating, hop into a current IFR aircraft, and fly all I wanted to in IMC as long as I remained in Class G (uncontrolled) airspace. No clearance is required, no clearance is even available, but you still must adhere to the instrument flight rules. I had never really thought of being able to do this so it was a little shocking to hear. After I got home that afternoon, I thought to myself that if that were the case, then when I'm at MDA on my local uncontrolled airport's NDB approach, and I don't see the runway but can see directly underneath me, I could legally slip down below MDA to try to bust out. Why? At MDA, I'm below the 700 foot floor of the Class E airspace which puts me in Class G. This would be the case at almost all uncontrolled airports that have published instrument approaches. Does this sound right? It sounds right as long as you have VFR conditions at the MDA and remain in VFR conditions to your destination. You can't fly along within 700 feet of the surface in IMC in Class G airspace, FAR 91.177 still applies in Class G airspace. |
"Steven P. McNicoll" wrote
It sounds right as long as you have VFR conditions at the MDA and remain in VFR conditions to your destination. You can't fly along within 700 feet of the surface in IMC in Class G airspace, FAR 91.177 still applies in Class G airspace. But with regard to the original question, wouldn't the following apply: (a) Operation of aircraft at minimum altitudes. Except when necessary for takeoff or landing, no person may operate an aircraft under IFR below -- Bob Moore |
"Robert Moore" wrote in message . 6... But with regard to the original question, wouldn't the following apply: (a) Operation of aircraft at minimum altitudes. Except when necessary for takeoff or landing, no person may operate an aircraft under IFR below -- I should have been more clear. You'd have to cancel IFR upon reaching VMC at the MDA and continue VFR to your destination. |
Controller mentioned in his presentation that IMC flight in Class G airspace without a clearance was actually legal as long as the aircraft and pilot were both instrument qualified. Yes, but not really. The NTSB has ruled such activty as "Careless or reckless", and violated pilots for it. |
Greg, where can we view this ruling by the NTSB?
Do you or anyone have references to actual situations where pilots have been violated using "careless and reckless" due to operating in imc in uncontrolled airspace? thanks, Stan On Mon, 08 Sep 2003 06:06:41 GMT, Greg Esres wrote: In a recent FAA sponsored seminar that I attended, a retired Tower Controller mentioned in his presentation that IMC flight in Class G airspace without a clearance was actually legal as long as the aircraft and pilot were both instrument qualified. Yes, but not really. The NTSB has ruled such activty as "Careless or reckless", and violated pilots for it. |
Sure, but I think the point here (definitely a "don't try this at
home" but an interesting theoretical point) is that if upon reaching MDA, still in IMC, you cancel IFR (very quickly!) then you would still be legal. Whether this is wise is altogether a different point. However if it is C&R then logically so is ANY uncontrolled IMC in class G. Which is fine by me, I find the idea horrifying, even if it is commonplace in the UK. John "Roy Smith" wrote in message ... In article , wrote: Greg, where can we view this ruling by the NTSB? Do you or anyone have references to actual situations where pilots have been violated using "careless and reckless" due to operating in imc in uncontrolled airspace? The issue is not operating in IMC in uncontrolled airspace. The OP's question revolved around descending below the MDA on an instrument approach without having the runway environment in sight. That's illegal. |
"John Harper" wrote in message news:1063025978.731057@sj-nntpcache-3... Sure, but I think the point here (definitely a "don't try this at home" but an interesting theoretical point) is that if upon reaching MDA, still in IMC, you cancel IFR (very quickly!) then you would still be legal. It wouldn't be legal if the Class E floor is 700 AGL, as I believe it was in the scenario provided here. The FARs still apply in Class G airspace, including the one on minimum IFR altitudes. Ya gotta be at least 1000 feet above the highest obstacle within 4 miles, and ya can't do that where controlled airspace begins at 700 feet above the ground. |
if upon reaching MDA, still in IMC, you cancel IFR (very quickly!) then you would still be legal. No. In uncontrolled airspace, I believe you still must be on an IFR flight plan to operate IFR. You just don't need a "clearance" since no separation is provided. I'm away from my FARs right now; I could be wrong (and will no doubt discover it quickly if so ![]() Jose (for Email, make the obvious changes in my address) |
| Legal question | PMA | Home Built | 9 | January 14th 05 04:52 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 12:55 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 11:43 PM |
| Database update at Landings | Dr. Guenther Eichhorn | Home Built | 0 | May 11th 04 11:25 PM |
