"scratchy" radio transmission
Old December 31st 05, 09:26 PM posted to rec.aviation.homebuilt
Default "scratchy" radio transmission
I am looking for ideas here; ATC says my radio transmissions sound
'scratchy' or 'staticy' as little as 15 miles out on callup. I have
been going nuts trying to find the cause. The aircraft has 2
independant radios, 2 antenna systems (one on top of the fuselage, one
underneath). One radio replaced as an update recently. Both radios have
been checked out by the factories recently and pronounced fine (one
Narco Mk12D and one Icom). Been through the wiring and grounds several
times and found nothing. Tried different headsets (note: the voice
sideband through the headset sounds perfect). ATC said no difference
with alternator shut off. Reception is always perfect. Complaints seem
to pick up more in the cold weather. Don't know if its important but
maybe once or twice each summer I get alot of static in the headset
that seems to disapate in a minute or two, but never in the winter.
If I were generating a large static charge in the dry winter air
wouldn't it effect my reception? Some days I get complaints even when
taxiing for takeoff. Any ideas what to try next without going on an
expensive fishing expedition?
Old January 1st 06, 12:12 AM posted to rec.aviation.homebuilt
Jim,
Could be lots of things, but I'd be willing to bet a cold beer that
its in the audio input path to your radio, and not between the radio
and the antenna given that you receive fine.
Here's a few thoughts that _might_ help:
Loose/broken wire in mic - Try a different microphone
Oxidation in mic jack - Clean both the male and female jacks
Loose/broken wire between mic jack and radio
Cold solder joint in either mic, jack, etc
PTT switch starting to oxidize internally
Good luck finding the problem.
Don W.
Old January 1st 06, 01:15 AM posted to rec.aviation.homebuilt
If it was a broken/loose wire in the mic circuit I would think I would
not get a good sidetone in the headset. Have seriously cleaned both of
the mic jacks but now that you mention it I'll bet it could be the PTT
button (duh!). I probably need to make a debounce circuit or something
if possible. At least I could try taking a passenger to try the rear
xmit button. Thanks for the "wake up call".
Old January 1st 06, 02:20 AM posted to rec.aviation.homebuilt
If, as you have told us, the sidetone is clear and loud, then the odds of it
being in the microphone/jacks/PTT switch are nearly zero. My bet is an RF
problem of some sort.
And why would you consider some sort of "debounce" circuit? DO you have a
clue what a debounce circuit does?
Old January 1st 06, 06:51 AM posted to rec.aviation.homebuilt
It is odd that he has a clear "sidetone", receives fine, and yet the
transmission is scratchy (apparently on both radios?). Also that both
radios apparently benchcheck fine.
Jim, do you have an audio mix panel, and if so does the mic input go
to it before splitting to the radios? Also, I read your original post
pretty quickly and didn't notice the part where you said you were
hearing the sidetone okay. That eliminates a lot of potential failure
points.
Another thought: Do you have an "intercom" that both mics and the PTTs
connect to before the mic audio gets to the radios? If so, the intercom
could be the culprit. There are so many ways that your aircraft could
be wired up that its hard for me to think of all of them. You could
probably get to the bottom of it all pretty quickly with an oscilloscope
if you have one and know how to use it.
RST, if both radios have the same static problem (with their different
RF XMIT sections, T/R switches, and antennas), it is not very likely an
RF problem.
OTOH, it could be a DC voltage problem, as in the DC voltage supply to
the radios is too low, causing the transmit power to be less than it
should.
Jim, have you tried both radios and verified that ATC hears them both as
scratchy?
Don W.
Old January 1st 06, 08:12 AM posted to rec.aviation.homebuilt
Bought a homebuilt once. Both radio antennas had been installed the same
way - with the cardboard drilling pattern glued to the aluminum - then left
there, and the antenna installed over the top of it. No ground plane.
The SWR was OK (1.8:1), believe it or not. It worked out to 10 miles or
so - then things started getting weak and scratchy.
Even a fancy Anritsu test set I borrowed from work showed no great problem.
But when I removed those drill patterns, things started working fine.
Old January 1st 06, 01:34 PM posted to rec.aviation.homebuilt
points.
intercom
oscilloscope
RF problem.
should.
as
scratchy?
No audio mix panel. Mic goes to the intercom then goes through a DPTT
switch (to deliver Mic to either radio but not both at the same time
and same with the PTT and audio output). When the intercom is turned
off the mic input bypasses it straight to the radios and it is the
'radio' sidetone I hear clearly from both radios, not the intercom's.
ATC verifies both radios sound the same. I used to suspect the landing
gear getting in the way but as I said I have one antenna on the bottom
and another on top. Since I'm always headed to the facility on callup I
even had the whacky idea that the metal prop was getting in the way so
I would turn the plane 90 degrees and call again. Needless to say, no
difference.
I am also leaning to checking the DC supply circuits again. Thanks.
Old January 1st 06, 01:15 PM posted to rec.aviation.homebuilt
A friend at work told me it is like an electronic switch that "locks on
and off" to prevent a poor or intermittant connection. Maybe I don't
have a correct clue about it but I have the utmost confidence someone
will straighten me out on the subject. Thats why I came here; to learn.
Old January 1st 06, 12:37 AM posted to rec.aviation.homebuilt
Knowing what kind of aircraft it is would help a bit.
Old January 1st 06, 01:08 AM posted to rec.aviation.homebuilt
Full metal jacketed RV-4
MX385 Radio removal Marty from Florida Owning 3 May 24th 13 08:26 AM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
