Rotax vs. Jabiru
Old January 4th 06, 11:52 PM posted to rec.aviation.homebuilt
Default Rotax vs. Jabiru
As I continue to research, the Zodiac XL and the Sonex are on the short
list. Both offer a couple of engine options including Rotax 912
(variations) and the Jabiru 3300. Real-world performance doesn't seem
like it would be that much different, at least on paper.
I hope this isn't a religious issue. I'm interested in opinions on both
the Rotax and Jabiru options.
TIA.
Old January 4th 06, 11:58 PM posted to rec.aviation.homebuilt
TIA.
Or if I opt for a Zodiac XL, would it be better to use a Conti O-200?
Old January 5th 06, 03:02 AM posted to rec.aviation.homebuilt
I think it pushes it above the weight for LSA designation. Check on that.
Jim in NC
Old January 5th 06, 03:29 PM posted to rec.aviation.homebuilt
I'm not sure if your talking about the 'built' version or E/AB version.
If it's the experimental version you can set the gross weight where you
like. Just limit it to the LSA requirement and your good to go. You will
lose some useful load which you can trade off with smaller tanks and less
range if you need the weight.
John
Old January 5th 06, 05:16 PM posted to rec.aviation.homebuilt
("UltraJohn" wrote)
Could you ex"pound" on this - set the gross weight where you like?
Thanks
Mont ....blue, yeah, that's it - Montblue
Old January 5th 06, 05:44 PM posted to rec.aviation.homebuilt
"Montblack" wrote in
("UltraJohn" wrote)
version. If it's the experimental version you can set the gross
weight where you like. Just limit it to the LSA requirement and your
good to go. You will lose some useful load which you can trade off
with smaller tanks and less range if you need the weight.
Thanks
As the builder/manufacturer of an ambuilt-experimental you can
absolutely set the max gross weight anywhere you like... Who is to tell
you that a kit that others have built and set at, say 1450lbs is
mandatory for you to do the same.... Of course, a ramp check when you
and your 200lb friend climb out and pull out pull out 200Lbs of camping
gear that's 150lbs over your gross weight will be a problem....
S-LSA and kit E-LSA are regulated as to the min usefull load to combat
just this issue... but ambuilt expermimental is not.
-- ET :-)
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Old January 6th 06, 12:27 AM posted to rec.aviation.homebuilt
Montblack wrote:
("UltraJohn" wrote)
Thanks
Yes Montred (hey if you can do it I can) ;-)
You can set the gross weight for E/AB where you like. You might/should have
some documentation as to what the pane can actually maxout but you
certainly can set it lower for safety sake.
The speeds are another story. You can't easily 'set' the max continous etc
etc but you could put an electronic (or otherwise) limiter on the engine to
keep the speed within limits and/or adjust the prop pitch/diameter to limit
airplane (or prop/engine) speed. Now if you have a 250 kt plane it might be
difficult to limit it! My plane which I'm slowly (very slowly) working on
original specs are 180 mph cruise (yeah right) realistic most cruise at
140-150 so proping it down with a climb prop takes care of it easily the
problem is stall speed mines about 3 mph high so I need mods to lower the
stall down.
The whole point is E/AB has a lot of leeway!
Also the AMD CH601XL is SLSA (the one Jim Pellien is selling is ELSA)and it
has a Cont O-200 they lost 70lb useful load because of the engine weight
but it still has the 1320lb gross.
John
Sorry for the rambling post!
Old January 5th 06, 03:05 AM posted to rec.aviation.homebuilt
More people are badmouthing Jubiru, than are badmouthing the Rotax 4
strokes.
YMMV.
Jim in NC
Old January 5th 06, 04:40 AM posted to rec.aviation.homebuilt
I've only got 120 trouble free hours on my 912ULS, so I'm no first hand
expert, but, the 912 was recently changed from TBO of 1200 hours to
1500. That seems like a fairly good endorsement for reasonablely good
field experience.
tom
Engine sound of Rotax 912 JK Home Built 12 May 22nd 05 02:47 PM
ROTAX 275 questions Eric Greenwell Soaring 0 January 6th 05 02:43 AM
Jabiru and Rotax engines Marco Rispoli Home Built 14 July 16th 04 07:23 AM
RV-9A's wing with Rotax 914? Shin Gou Home Built 26 March 7th 04 08:56 PM
Jabiru V Rotax reliability? Joe Home Built 11 September 5th 03 11:09 AM
