I picked up an old Narco Com IIA radio.
I'd like to wire it up at home in the garage so I can listen to the traffic and approach control flying overhead. I've searched the internet high and low looking for documentation that would identify the connections on the back. I can't find any, not even at narco's web site. There is a clone (tray compatible) radio by TKM (the MX-11) but I can't find any connection diagrams for that either. Does anybody have something that would list the connections for this radio, or at least know a web site that might tell how to hook it up? I'm assuming I'll need Pwr (+12V), ground, and speaker connections. Obviously no transmit. Thanks, Rod (remove "-delete-" from address if replying via email) |
COM 11A Pinout:
1-Ground 2-Mic Ground 3-Phones 4-Mic Key 5-Speaker 6-Speaker and Phones Ground 7-Audio In 8-Low Level Audio Out 9-Mic Audio 10-Dimmer Light 13+14 14V Input Hope that helps. I have a maintenance manual if you need one... Ron Webb "Rod" wrote in message ... I picked up an old Narco Com IIA radio. I'd like to wire it up at home in the garage so I can listen to the traffic and approach control flying overhead. I've searched the internet high and low looking for documentation that would identify the connections on the back. I can't find any, not even at narco's web site. There is a clone (tray compatible) radio by TKM (the MX-11) but I can't find any connection diagrams for that either. Does anybody have something that would list the connections for this radio, or at least know a web site that might tell how to hook it up? I'm assuming I'll need Pwr (+12V), ground, and speaker connections. Obviously no transmit. Thanks, Rod (remove "-delete-" from address if replying via email) |
Cool, thanks.
Looking at the unit from the back, pin 1 (card edge connector) on the left? I don't know if I need a maint. manual, but it wouldn't hurt to have one in my library. What do you want for it? I can't use the radio in an airplane unless it's checked and approved my the mfg. I think the default freq tolerance spec is not within current requirements. thanks, - rog In article , "RTW" wrote: COM 11A Pinout: 1-Ground 2-Mic Ground 3-Phones 4-Mic Key 5-Speaker 6-Speaker and Phones Ground 7-Audio In 8-Low Level Audio Out 9-Mic Audio 10-Dimmer Light 13+14 14V Input Hope that helps. I have a maintenance manual if you need one... Ron Webb "Rod" wrote in message ... I picked up an old Narco Com IIA radio. I'd like to wire it up at home in the garage so I can listen to the traffic and approach control flying overhead. I've searched the internet high and low looking for documentation that would identify the connections on the back. I can't find any, not even at narco's web site. There is a clone (tray compatible) radio by TKM (the MX-11) but I can't find any connection diagrams for that either. Does anybody have something that would list the connections for this radio, or at least know a web site that might tell how to hook it up? I'm assuming I'll need Pwr (+12V), ground, and speaker connections. Obviously no transmit. Thanks, Rod (remove "-delete-" from address if replying via email) |
Note: If your aircraft radio has more than 700 channels, it is acceptable
for use after 1/1/97. Below is a PARTIAL list of radio that have been type accepted by the FCC as meeting the 30 PPM frequency tolerance (some with less than 700 channels). Aircraft radios type accepted to an even tighter tolerance are acceptable, but may not necessarily be listed below. So long as your radio does not appear on the list of unacceptable radios, however, you may continue to use it. National Aeronautical Corp a.. b.. COM11A is on the list of acceptable radios. http://wireless.fcc.gov/aviation/goodlst.html It is good to go. No need for a radio shop check. "Rod" wrote in message ... Cool, thanks. Looking at the unit from the back, pin 1 (card edge connector) on the left? I don't know if I need a maint. manual, but it wouldn't hurt to have one in my library. What do you want for it? I can't use the radio in an airplane unless it's checked and approved my the mfg. I think the default freq tolerance spec is not within current requirements. thanks, - rog In article , "RTW" wrote: COM 11A Pinout: 1-Ground 2-Mic Ground 3-Phones 4-Mic Key 5-Speaker 6-Speaker and Phones Ground 7-Audio In 8-Low Level Audio Out 9-Mic Audio 10-Dimmer Light 13+14 14V Input Hope that helps. I have a maintenance manual if you need one... Ron Webb "Rod" wrote in message ... I picked up an old Narco Com IIA radio. I'd like to wire it up at home in the garage so I can listen to the traffic and approach control flying overhead. I've searched the internet high and low looking for documentation that would identify the connections on the back. I can't find any, not even at narco's web site. There is a clone (tray compatible) radio by TKM (the MX-11) but I can't find any connection diagrams for that either. Does anybody have something that would list the connections for this radio, or at least know a web site that might tell how to hook it up? I'm assuming I'll need Pwr (+12V), ground, and speaker connections. Obviously no transmit. Thanks, Rod (remove "-delete-" from address if replying via email) |
