Fiberglass adhesion to aluminum?
Old January 6th 06, 04:45 AM posted to rec.aviation.homebuilt
Default Fiberglass adhesion to aluminum?
I've got some slight cracking in my aluminum nosebowl and have stop
drilled them twice.
I'm considering backing the cracks with fiberglass in hopes to keep the
vibration down.
How well does fiberglass adhere to aluminum?
What system is better.
I have easy access to the West system chemicals.
Any hints? Alodine first?
Thanks
Dave
Old January 6th 06, 05:59 AM posted to rec.aviation.homebuilt
If a fiberglass patch on an aluminum backplate stays on for one entire
trip around the pattern, I'd be flat out amazed...
Old January 6th 06, 04:39 PM posted to rec.aviation.homebuilt
On Fri, 06 Jan 2006 05:59:37 GMT, Richard Lamb
Properly preped it'll stay on as well as the paint, better in some
cases. Without a good degrease and prep I doubt it'd stay on past the
run up. :-)) Many of our "plastic" planes have Aluminum to
glass/resin bonds.
www.rogerhalstead.com
Old January 6th 06, 06:00 PM posted to rec.aviation.homebuilt
glass/resin bonds.
I know, Roger, but....
Someone who is actually building a plastic plane should step up to the
microphone and tell how those metal plates are installed.
I know of no structural design that has aluminum plates "glued" on to
glass.
My best guess is that they get "bonded in" by covering them with more
layers of glass. - in effect, the metal is burried inside the glass.
That's not he case here.
Richard (the skeptical cave) Lamb
Old January 7th 06, 04:56 AM posted to rec.aviation.homebuilt
On Fri, 06 Jan 2006 18:00:32 GMT, Richard Lamb
glass/resin bonds.
As for the three methods described below you will find photos at
http://www.rogerhalstead.com/G3_file.../glasair11.htm along
with some description. As you'll note, these are not just "slapped"
in. :-))
It depends on which part and where.
Typically, you'll find captive nuts like the K2000-4 (If I remember
the number correctly) both pop riveted in place and then have the
"ears" glassed in with two layers of cloth and resin. The "glass
serves as much to keep from losing the captive nuts as it does
structurally. Lose one of those suckers and it means cutting a hole
in the horizontal stab, glassing in a new K2000-4, and then patching
the stab so it looks like you never had to bore a hole in it.
The backing plates for the engine mount attach bolts (which are held
under considerable compression) are of 0.10" SS. The face and edges
are thoroughly sanded and these are bonded on the face and sides to
the engine mount attach point reinforcements using a resin and mill
fiber mix. For six attach points there are a total of 96 individual
lay-ups just for the reinforcements, plus six more two layer lay-ups
used for forms.
The third method which is *similar* to what he's asking about is the
fuel tank filler neck. There the outer ring is set into a tight
fitting opening just a tad forward of the windshield. This pieces is
held entirely by a resin and mill fiber mix. which is built up around
the neck. This is in an area which would receive pretty much the same
kind of stresses as the cowl crack and receives a lot of stress from
expansion and contraction of the machined Aluminum filler neck and
cap.
*However* how I've seen a cowl patched, and the only way I've seen it
done was to first, "stop drill" the crack. Then a small "doubler" was
made out of Aluminum about the same thickness as the cowl. As the
crack included the leading edge of the cowl where the edge is rolled
back and extended back about 2 inches. ( Of course the thing would
never crack where it's easy to fix)
(Yah ever try to type with a lap full of a 16# cat? At least he
didn't have his claws out when he jumped up.)
Slight distraction there.
At any rate, The entire area was thoroughly cleaned, sanded, cleaned
again, the doubler fitted, then flush riveted in, and finally the
whole thing was glassed over on the inside with two layers of glass
and resin. The glass was a last resort as the doublers were refusing
to hold.
Hmmmm... Good thing I'm not writing and this has a back space key.
He just knocked over the waste basket. I think I have a cat who wants
some attention.:-))
glass.
Nor do I, but didn't he ask about patching a cowl crack? It is
structural, but only for vibration and a slight wind load. Of course
it does depend on where in the cowl as well and I'd still want to use
a doubler..
Old January 6th 06, 06:29 AM posted to rec.aviation.homebuilt
wrote in message ...
drilled them twice.
vibration down.
How about welding it? Just a suggestion (since I haven't seen the part or
the cracks). I didn't see that suggested and I can't help but wonder 'why
not'.
Just glass-bead blast that area and have it TIG'd up. I've seen some folks
successfully 'Heli Arc' some very delicate material. A character by the name
of Vince Wyatt used to weld little stick figures (about 2" tall) onto the
top of his Copenhagen cans at Todd Shipyard in the early 70's. I'd keep an
eye on how much bead (mass) is added to one side. Possibly add to the other
side to balance.
Does that sound feasible?
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 04:23 AM
