Lifespan of a parachute canopy?
Old January 11th 06, 04:20 PM posted to rec.aviation.soaring
Default Lifespan of a parachute canopy?
Does anyone know when our 17 year old emergency parachute
canopy will pass its use-by date? Indeed, is there
a definite lifespan, or is it down to the discretion
of the packer?
The 'chute has always been stored indoors in a dark
dry cupboard.
Also, has anyone had any experience of having a new
canopy fitted?
Old January 11th 06, 05:04 PM posted to rec.aviation.soaring
of the packer?
dry cupboard.
canopy fitted?
Lifespan depends on regulations of the country, e.g.
in Germany the lifespan of emergency parachutes is set to 15 years.
I am going to sell 3 chutes for my club right now which ended in 2005.
I am expecting 100 or up to 150 euros for each.
People often use them as decoration or for group gymnastic/dancing.
--Peter Hermann(49)0711-685-87244
--Nobelstr.19 Raum 0.030, D-70569 Stuttgart IHR Hoechstleistungsrechnen
--http://www.ihr.uni-stuttgart.de/ Fax 0711-89238279
Old January 11th 06, 05:57 PM posted to rec.aviation.soaring
In the USA, there isn't really any life span of canopies set for by
the FAA. However, some manufacturers are limiting their life span of
canopies, or harness/containers systems. For example, National limits
their life span to 15 years, Paraphernalia Softie is doing the same,
but Strong Enterprises rigs are good to use as long as they pass the
canopy/canopy fabric tests. On the other hand, Performance Designs
wants to see reserve canopies in their factory after 40 repack cycles.
If the canopy passes the tests they will return it back to you and you
are good to go. Having said that, me as a rigger, I am not repacking
parachutes that are older than 15 years. And in general, if I remember
correctly, the PIA (Parachute Industry Association) also agrees that 15
years is the "life span" of a canopy but I am not quite positive on
that. I'll check with them and let you know. The problem with
parachutes is not the age alone. There is some other factors playing
important role in the fabric degradation. The main factor is the repack
cycle. According to the FAA, if your canopy is made of synthetic fibers
the repack cycle is 120 days and 60 days in a case on natural fibers
but that is history. The main degradation of fabric comes from handling
and repacking the canopy. When the rig is due for a repack the canopy
is pulled out of container or deployment bag in a case of sport
parachute. Then the rigger inspects the whole system, let the canopy
dry up and if everything is a OK it goes back into the container or
deployment bag. This insertion into the deployment bag or container is
the biggest stress for the fabric. And then you fly in it. You sit on
it. It works in some cases as a cushion. And after your are done
flying, you leave it in the direct sunlight, high temperatures and then
when you put your glider away in the trailer the poor rig is being
cooked. In some cases people will take them home....well, at list they
were attempting that, because the rig rides in a trunk of your car in
heat and cold. There is a push from the industry with the FAA to change
the repack cycle to 180 days. That will help with multiple issues. I
jumped a main sport parachute that sit in a deployment bag for over 2
years. It worked just fine. Still, I believe that a good parachute is
worth spending the money and it is worth of having and flying with it.
Old January 13th 06, 05:14 PM posted to rec.aviation.soaring
Do the manufacturers give a reason for this, such as discovering
parachutes that are no longer safe after 15 years, or industry tests
that shows fabric deteriorates in a manner that can't be found by
inspection? Or is this simply a convenient way to limit their liability?
Without knowing more, I see no reason to buy anything but a Strong
parachute. Why buy a parachute that's worthless (or maybe unsafe) after
15 years?
From what you say below, there are many stress factors on a parachute,
and the implication is the industry (or at least some of it) doesn't
know to test for potential problems. What puzzles me is these packing an
usage stresses don't seem very demanding for synthetic fabrics. Sport
parachutes get much more handling and use (jumping a parachute seems
like far more stress than using it as a cushion!), so it's hard to
understand why our chutes should degrade significantly in 15 years.
Eric Greenwell
Washington State
USA
Old January 11th 06, 06:29 PM posted to rec.aviation.soaring
Thanks for this. I must admit to being against very
regular repacking of emergency parachutes - I think
once a year is plenty as long as I know it is not abused
(eg allowed to get wet) and stored well.
Martyn
At 18:00 11 January 2006,
set for by
life span of
National limits
doing the same,
as they pass the
Designs
40 repack cycles.
back to you and you
am not repacking
if I remember
also agrees that 15
years is the 'life span' of a canopy but I am not quite
positive on
with
factors playing
of synthetic fibers
on natural fibers
comes from handling
repack the canopy
of sport
let the canopy
the container or
bag or container is
in it. You sit on
your are done
and then
rig is being
at list they
of your car in
the FAA to change
issues. I
bag for over 2
good parachute is
and flying with it.
Old January 11th 06, 06:30 PM posted to rec.aviation.soaring
Martyn
set for by
life span of
National limits
doing the same,
as they pass the
Designs
40 repack cycles.
back to you and you
am not repacking
if I remember
also agrees that 15
positive on
with
factors playing
of synthetic fibers
on natural fibers
comes from handling
repack the canopy
of sport
let the canopy
the container or
bag or container is
in it. You sit on
your are done
and then
rig is being
at list they
of your car in
the FAA to change
issues. I
bag for over 2
good parachute is
and flying with it.
Old January 13th 06, 07:17 PM posted to rec.aviation.soaring
See this link to an article that includes the Strong
company's view that there need be no specific limit
to the life of a properly maintained and stored Strong
canopy:
http://www.strongparachutes.com/Pages/Articles.html
set for by
their life span of
National limits
is doing the same,
as they pass the
discovering
or industry tests
be found by
their liability?
but a Strong
maybe unsafe) after
15 years?
on a parachute,
of it) doesn't
is these packing an
fabrics. Sport
a parachute seems
so it's hard to
in 15 years.
40 repack cycles.
back to you and you
I am not repacking
if I remember
also agrees that 15
quite positive on
with
factors playing
of synthetic fibers
on natural fibers
comes from handling
a repack the canopy
case of sport
let the canopy
the container or
bag or container is
in it. You sit on
your are done
rig is being
at list they
of your car in
the FAA to change
multiple issues. I
bag for over 2
a good parachute is
and flying with it.
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Old January 13th 06, 08:04 PM posted to rec.aviation.soaring
canopy:
Very interesting read. It jibes with the practice and beliefs of many
glider pilots, including myself (I own a Strong parachute that is about
25 years old). It jibes with my knowledge of synthetic fabrics, which I
don't believe are harmed by temperatures in the -20 to 120 deg F range,
which they experience while my parachute is happily nestled in the
cockpit, in the trailer, in my driveway.
I was unable to find any reference to a 15 year service life (or any
life limitation) on the National or Softie websites, using a Google
search for "life". Can someone point me to where this information is?
The only reference I could find to "40" on the Performance Designs site
was a requirement in the "PD Series Ram-Air Reserve Parachute Owners
Manual" to check the permeability of the fabric after 40 repacks (other
factors could also trigger this), with the recommendation (not
requirement) to return it to the factory for testing. This does not
sound like a life limitation in any way.
In fact, returning the parachute to the manufacturer every 10 years or
so seems like a good idea. I did that with my Strong when it was 15
years old. They did some minor upgrades, which were included in the
repacking fee.
Eric Greenwell
Washington State
USA
Old January 13th 06, 09:03 PM posted to rec.aviation.soaring
Eric,
Why don't you come by my house and I will show you some canopies
ranging from 10 to 20 years of age that I pulled out of different rigs.
Maybe then you would comprehend some of the issues related to
parachutes. But I kinda doubt it. I am tired of you attacking me and my
position on parachute issues, I did not know that you had such a vast
knowledge about parachutes without being a rigger or at least having a
few jumps behind your belt. Keep in mind that a glider broke apart in
flight near Reno and that was exactly the same type of glider that you
fly and own. So, having said that, think about what is on your back
next time you go fly. But again, I doubt it. Your confidence in your
opinions is amazing. And then again, you fly your German bird that you
paid for a big chunk of money and you have a problem buying a parachute
every 15 years? It is absolutely beyond me. I don't sell parachutes, I
don't have any interest in limiting a life of a canopy especially your
canopy. And I don't even like to pack anymore because of people like
you.
Jacek Kobiesa
Lifespan of a parachute canopy? Martyn Johnson Soaring 15 January 18th 06 11:12 PM
Duo Discus canopy problems David Starer Soaring 4 June 20th 04 11:09 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Redundant canopy latching John Soaring 5 March 16th 04 12:50 PM
FS: SECURITY 150 PARACHUTE PACK W/O CANOPY Tim Hanke Home Built 0 July 21st 03 05:59 PM
