Established on the approach - Checkride question
Old September 29th 03, 04:28 PM
endre
Default Established on the approach - Checkride question
I did my instrument checkride the other day and passed...
Question for this group.
I was being radar vectored for the SHN NDB approach. I was cleared in
the following way: Cessna 61786 14 miles from NDB descend and maintain
2000 until established.
The problem: I was outside the 10 mile ring on the plate, established
on the inbound course, no way to tell when I would be inside 10 mile.
However, I would need to descend to 1400 before the NDB to have a
chance to descend to MDA of 900.
What would you all do?
Endre
Old September 29th 03, 05:02 PM
Aarfy
I'd look at my GNS430 and start descending to 1400' at CARRO or 10nm from
the NDB.
My read of the plate says that on the approach course you need to be at
1900' 10nm from the NDB. If you don't have an approach-ready GPS then I
guess there's 2 ways to go:
1. Calculate/estimate your ground speed, and use a timer to figure out when
you've traveled 4nm to be within 10nm, begin descent to 1400'.
2. Ask ATC to give you a heads-up when you're 10nm out, begin descent to
1400'.
Then again, maybe I'm reading the plate wrong.....
"endre" wrote in message
om...
Endre
Old September 29th 03, 05:13 PM
Greg Esres
I would first point out that that the 10 mile ring is irrelevant. The
ring depicted on NACO charts is NOT the procedure turn area. It
merely says everything is to scale inside the ring. Common
misunderstanding, but an instrument instructor should be slapped
around if he teaches it.
The only "10 nm" that comes into play is the one on the profile file
that says "remain within 10 nm". The protected area for a PT is NOT
a circle; more like an egg.
Old September 29th 03, 06:32 PM
McGregor
Well, is the 10 nm ring irrelevent if he's already on the inbound course?
If he's getting "vectors to final" then he's not expected to make a PT.
Presumably he's going to be close to or on the final approach course when
ATC clears him 14 miles out.
There is another IAF 9.7 nm out and slightly left of course at CARRO which
allows you to descend to 1400 (and skip the PT). Even if it weren't there,
I'd be tempted to descend to 1400 inside 10nm. If you're on the final
approach course and inside the PT limits... why not?
Anyway, I'd start a timer after ATC said "cleared for the approach." If
you're going 120 knots wait for 2 minutes and then begin your descent to
1400 feet.
If you're good at trigonometry (I'm not, I'm not even sure I can spell it)
then you could use the OLM VOR for a DME fix. It's 18.2 to the NDB, and 90
degrees right of the 317 radial is 047, which is pretty close to (the
reciprocal of) your inbound course... so using Pythagorus's theorem you can
solve for the DME reading you need to see from OLM while on the inbound
course to know you're 10 (or 9.7) miles out. I get 20.6 - a nice thing to do
on the ground so you don't have to do square roots in your head while flying
an approach.
"Greg Esres" wrote in message
Old September 29th 03, 06:59 PM
Greg Esres
If you're on the final approach course and inside the PT limits...
why not?
That's fine, but my point is that the 10 nm is given to you on the
profile view, not the 10 nm ring, which has nothing to do with the PT.
Trivial distinction?
I don't think so. We had an approach that had no PT, yet some
instructors were teaching that an a/c could descend within 10 nm of
our FAF, because of the 10 nm ring.
Old September 29th 03, 06:11 PM
David Megginson
(endre) writes:
in the following way: Cessna 61786 14 miles from NDB descend and
maintain 2000 until established.
Since you were being vectored and not flying a full procedure, I'd
guess that you were OK to descend as soon as you intercepted the
inbound course, but if in doubt I would have asked ATC to clarify (as
I often do -- better embarrassed than dead). In my real-life IFR
flying so far, I've noticed that ATC often vectors me onto the
approach path far out beyond the PT limits -- once so far that I could
just barely pick up the localizer (in night IMC no less) -- and that
they intend for me to follow any altitude instructions as soon as I'm
on the course, even if I won't be inside PT limits for another 10
minutes or more.
Even if my experience is unusual (or U.S. ATC works differently, and
"established" means explicitly "inside PT limits"), they still gave
you the information you needed -- you were 14 nm from the NDB, and
with a 90 kias approach speed, 3 minutes (4 with a strong headwind)
should have been good enough to ensure that you were inside the 10 nm
circle.
All the best,
David
Old September 29th 03, 06:27 PM
Greg Esres
I'd guess that you were OK to descend as soon as you intercepted the
inbound course,
Argh! No! The PILOT must know when he's established and within the
protected area. All you've intercepted is a navaid, not a segment of
the approach, until you've reached the start of that segment.
I'm on the course, even if I won't be inside PT limits for another 10
minutes or more.
What ATC intends is irrelevant. If they want you at the published
altitude before you reached the point where that altitude applies,
then they're got to clear you down to it, using their MVAs.
Failure to understand this concept has killed some people in the past,
including at least 1 airliner, TWA 514.
See the AOPA article:
http://www.aopa.org/asf/asfarticles/sp9806.html
Old September 29th 03, 06:47 PM
Gary L. Drescher
inbound course,
Is it well-defined where the approach segment begins when you're vectored
for SHN NDB-A? (There's an IAF at CARRO, but it's a bit to the side of the
approach course.)
--Gary
Old September 29th 03, 06:53 PM
Greg Esres
vectored for SHN NDB-A?
Yes, in theory. ;-) You're on the final approach segment where the
initial segment intersects the final approach course at (or within)
the 10 nm limit stated in the chart.
How you would detect this on a vectors to final outside this limit is
point of the original poster. I never waste NDB approaches by doing
vectors to final, so I haven't given any thought to the issue. ATC
probably ought not to do what they did, but I'm not aware of any rules
stating such.
Old September 29th 03, 07:47 PM
Gary L. Drescher
I see why it's a sensible practice to construe it that way, but is it
officially defined that way somewhere?
--Gary
The perfect approach Capt.Doug Home Built 25 December 3rd 04 03:37 AM
Newbie Question, really: That first flight Cecil Chapman Home Built 25 September 20th 04 05:52 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
