Cessna landing light switch; solved!
Old January 15th 06, 10:58 PM posted to rec.aviation.owning
Default Cessna landing light switch; solved!
I had asked if anyone knew of a replacement Cessna landing light switch
that would turn on the taxi light and landing light separately (not
both on the second pull-out notch so as to ease the electrical load
during low RPM). I had given up and was going to take Denny's advice to
remove the existing switch to be replaced with whatever I could find,
not necessarily certified, that would work. Well guess what; the
existing switch had an extra unused post on it. Seems Cessna, in its
apparent wisdom, made the switch configurable to either setup. All I
had to do was put the taxi light lead on the other post and I had just
what I was looking for. Why can't all problems be this easy?
Old January 15th 06, 11:33 PM posted to rec.aviation.owning
I guess I missed that post. My 67 182 had a split landing/taxi light
switch. They look just like the split master/alternator switch except
they aren't red. You can get those from Cessna or any number of other
places.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 10:14 PM
Cessna landing gear legs Reserve MET! Bill Berle Home Built 1 February 23rd 04 01:31 AM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 07:51 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Aviation Marketplace 0 February 19th 04 07:51 PM
