Hi All
I have a King KY195B TSO radio. It uses a Telex 66T , amplified dynamic Microphone. It works well, but I want to change the microphone to a boom mic. (This is in a sailplane) The question is whether an electret mic will work. Any suggestions? -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
Only if you've got the little amplifier with it that converts the electret
mic to the aviation standard. Jim "Bruce" wrote in message ... Hi All I have a King KY195B TSO radio. It uses a Telex 66T , amplified dynamic Microphone. It works well, but I want to change the microphone to a boom mic. (This is in a sailplane) The question is whether an electret mic will work. Any suggestions? -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
Speaking of amplified microphones...I was over at your web site and saw
the article from Oct. 1985 on using a transformer to convert a commercial headset into one compatible for use in a plane. (KP85OCT.PDF) I was thinking of doing this with a cheap active noise cancelling headset. The boom mike is the issue. Is there one available? I was looking for something cheap to be used as a spare headset, or to be used by an extra passenger in the plane. Thanks, Paul RST Engineering wrote: Only if you've got the little amplifier with it that converts the electret mic to the aviation standard. Jim |
The earphones have never been the problem; the microphones always a problem.
Jim "Paul Dowgewicz (Remove Caps in Address)" wrote in message news:FrWCf.327844$0l5.277087@dukeread06... The boom mike is the issue. Is there one available? |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Radio Connector Question | Slick | Soaring | 1 | May 10th 04 11:06 AM |
Vertex VXA-150 Pro V handheld radio question | Alan Meyer | Soaring | 2 | April 24th 04 01:42 PM |
Radio silence, Market Garden and death at Arnhem | ArtKramr | Military Aviation | 4 | February 12th 04 12:05 AM |
Radio Question | Wizardo | General Aviation | 4 | July 25th 03 01:24 PM |
