I have another KAP 140 question for the group. Is there a way to have a
dual axis w/ pre-select model of the KAP140 act as though it is only a single axis? Sometimes I want to engage the AP in heading mode but take care of pitch myself. Engaging the AP in heading mode makes the AP automatically go into vertical speed mode. When on a VOR approach (or other non-precision approach) it would be nice to have the AP track a course or heading, but I don't trust it to level off at the step down fixes in a timely manner. During cruise, though, I might use altitude hold while I am busy briefing the approach, getting ATIS, etc... I can't figure out how to get one without the other. Is there a way to do this? Thank you. |
"News" wrote:
I have another KAP 140 question for the group. Is there a way to have a dual axis w/ pre-select model of the KAP140 act as though it is only a single axis? No, with the KAP 140, either you are flying the airplane or the autopilot is flying the airplane. When the autopilot is flying, you should not attempt to control the airplane with the yoke in either axis. It controls the horizontal. It controls the vertical. Do not adjust your set. Whether you trust the autopilot to fly an approach, or whether you should, is a matter for philosophical debate. I've always hand-flown all of my approaches in actual. I've practiced with it under simulated conditions where I've been impressed that the autopilot can do a fine job for me, unless I misconfigure it -- in which case the resulting deviation can be extremely disorienting. |
The badly mistyped response I raised on the KAP140 reference the ILS is that
many installations have a relay/switch that slects either NAV1 or GPS as the source for the HSI and hence the KAP140. In most installations the tuning of an ILS/LOC frequency AUTOMATICALLY forces the switch/relay into NAV mode. If you have a real ILS frequency tuned you smoothly intercept and track the localiser if you are lined up in the area, if its a not real frequency it stays in nav mode but drifts on in pace not really knowing where its going! Personally twice I've had a helpful co-pilot collegaue tune in an ILS to get the dne distance only to find the plane doing a beautiful intercept! In VFR conditions with everybody watching very amusing, other times? peter "Craig Prouse" wrote in message ... "News" wrote: I have another KAP 140 question for the group. Is there a way to have a dual axis w/ pre-select model of the KAP140 act as though it is only a single axis? No, with the KAP 140, either you are flying the airplane or the autopilot is flying the airplane. When the autopilot is flying, you should not attempt to control the airplane with the yoke in either axis. It controls the horizontal. It controls the vertical. Do not adjust your set. Whether you trust the autopilot to fly an approach, or whether you should, is a matter for philosophical debate. I've always hand-flown all of my approaches in actual. I've practiced with it under simulated conditions where I've been impressed that the autopilot can do a fine job for me, unless I misconfigure it -- in which case the resulting deviation can be extremely disorienting. |
I've been partially following this thread over the last few days, but I
must say that I wish the 140 would allow a pure wing leveler or HDG mode capability without the VS control. I must admit that I (now know that I) hadn't completely RTFM'd before using it in a 172SP, and got caught by surprise that I was getting VS control as well as HDG control. I know I should've briefed the manual more, but in my defense the single-axis Bendix/King APs that I'd seen before do (by the very fact that they're single-axis) behave differently. My "logic" thought that the dual-axis 140 would behave the same when I pressed the same button. Doh! But that's OK, I'm now flying an SR20 with the Meggitt 55X which behaves the way I think it should 8^) . Dave Blevins On Mon, 20 Oct 2003 05:19:02 GMT, Craig Prouse wrote: "News" wrote: I have another KAP 140 question for the group. Is there a way to have a dual axis w/ pre-select model of the KAP140 act as though it is only a single axis? No, with the KAP 140, either you are flying the airplane or the autopilot is flying the airplane. When the autopilot is flying, you should not attempt to control the airplane with the yoke in either axis. It controls the horizontal. It controls the vertical. Do not adjust your set. Whether you trust the autopilot to fly an approach, or whether you should, is a matter for philosophical debate. I've always hand-flown all of my approaches in actual. I've practiced with it under simulated conditions where I've been impressed that the autopilot can do a fine job for me, unless I misconfigure it -- in which case the resulting deviation can be extremely disorienting. |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 08:29 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
