vfr corridors through class B airspace
Old October 22nd 03, 12:40 AM
Default vfr corridors through class B airspace
Do I read the aim right that the special flight rules airspace over
top of LAX is actually still classified as a VFR corridor?
And secondly, are there any other vfr corridors in the US?
Stan
Old October 22nd 03, 01:41 AM
Peter R.
snip
The Hudson river below 1,100 feet MSL (next to Manhattan, New York City)
and San Diego at 3,500 feet, which takes you right over the San Diego
airport into the San Diego Bay are two very scenic VFR corridors.
Peter
Old October 22nd 03, 02:17 AM
'Vejita' S. Cousin
Not sure about LAX but here in Seattle Class B KSEA has one. Their are
two runways at SEA (16R and 16L, var 20E) and the corridor runs east to
west directly over the center of the runway.
I've never actually used it thou
Old October 22nd 03, 04:30 AM
Bob Gardner
Not exactly the same thing, Vejita...SEA has "transition routes," not
corridors.
Bob Gardner
"'Vejita' S. Cousin" wrote in message
Old October 22nd 03, 04:41 PM
Dan Luke
The Interstate 10 VFR corridor through Houston.
Dan
C172RG at BFM
Old October 22nd 03, 05:29 PM
Ron Natalie
wrote in message ...
Not that are Special Flight Rules. A lot of class B's that are formed from
overlaps of multiple primary airports have area that is just excluded (without
restriction) from the class B. An example is NY where there is a tunnel
down the Hudson (the chart does have some notations about traffic advisories)
and DC which has two tunnels (one between IAD and DCA, which unfortunately
is now eaten up by the stupid-assed no-fly zone and one between DCA and BWI
which is only partially eaten, but inside the ADIZ). Several others have sort of
notches cut out of their edges for non-Class B transition.
Old October 24th 03, 12:32 AM
But I don't think these are true "vfr corridors". The aim 3.5.5.b
describes corridors as "a hole through class b airspace", and shows
such in figure 3-5-2 (at least in my 2001 aim). LAX is just this way.
From what I see of dca area from March 2002 jepp chart, these two
corridors are "under" class b, not "through". Same for Houston, which
I have Jul 1999 Jepp info.
It appears LAX has the only true vfr corridor, unless someone has
other examples
Stan
On Wed, 22 Oct 2003 12:29:38 -0400, "Ron Natalie"
Old October 24th 03, 08:33 AM
Jeff
LAX's is called a "Special Flight Rules Area", not a VFR corridor, some parts of the SFRA require
ATC comminucation, the one over the top of LAX does not. This is per my current JeppGuide.
San Diego specifically says VFR corridor.
other examples
Stan
Old October 22nd 03, 11:04 PM
Jeff
They are VFR transition routes, you still need to contact LAX prior to
entering and so forth, I have the LA terminal chart that shows the route
and gives the procedures for using it. But you just cant go fly the
route, you need permission first.
Stan
Old October 23rd 03, 12:22 AM
Craig Prouse
Those are different routes altogether. The SFRA passes directly over LAX
between Santa Monica and Long Beach. It does not require ATC approval or
even ATC contact. You're right, however, that the LA TAC shows the route
and gives the procedures for using it. In fact you have to have the TAC in
your possession legally to fly the route.
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
airspace G Jim Anglin Home Built 8 February 22nd 04 11:29 PM
Airspace Privacy over your house !!!!!!!!!!!!!!!!!!!!!!! Fitzair4 Home Built 26 December 12th 03 12:48 AM
Decent below MDA, Legal? Roy Smith Instrument Flight Rules 59 October 4th 03 10:04 AM
Special Use Airspace on GPS Jeff Doran Instrument Flight Rules 3 August 11th 03 01:23 PM
