You know that life is good, when your garbage bin contains 12 empty quarts
of aeroshell W100, and 6 empty MGD bottles. Today I installed the oil "quick change" valve, then went flying for 30 minutes, then changed the oil. Oh that makes it SO much easier! No safety wire, no "channeling" the oil to a container. I have 3/8" tubing connected to the valve so I just fed it into a milk jug. Jug full, pinch tubing, next jug, etc. Hardly even needed a rag! Then this evening I took Nicole back to Abilene. I invited my Vietnamese friend to go along. It was a smooth starry flight. Filed IFR both ways but just got flight following on the way back so I could let Paul fly. I had a six-pack on ice back at the hanger for our debriefing. We cleaned up the plane. I showed him how "safety wiring" works, and we discussed some politics-- that Tytler quote*. He has some rather uplifting views of America, refugeed at 14 from Saigon in '75 just two weeks before it fell. We noted that flying to Abilene and back and enjoying a six-pack with a friend-- with nobody's permission-- were examples of great American freedoms. Like he put it, "It doesn't get any better than this". Just felt like sharing... Cheers, John Clonts Temple, Texas N7NZ *Sir Alex Fraser Tytler, in 1801: "A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury, with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship." |
Be sure to remove the 3/8 tubing after draining. A classic accident
some years ago pushed the quickdrain open on gear retraction (or whatever). Nice to hear. |
of aeroshell W100, and 6 empty MGD bottles. Or when you show up at the airport 9am on a Sunday when it's 600 and 1/4 and there's already 6 other guys hanger flying and drinking coffee, but not a single airplane is pulled from the hanger. A nice reminder that flying is really about the people, not the airplanes. Jim |
"JC" == John Clonts writes:
JC *Sir Alex Fraser Tytler, in 1801: JC "...with the result that a democracy always JC collapses over loose fiscal policy, always followed by a JC dictatorship." I think we're there now, all in the same administration. |
![]() "Bob Fry" wrote in message ... "JC" == John Clonts writes: JC *Sir Alex Fraser Tytler, in 1801: JC "...with the result that a democracy always JC collapses over loose fiscal policy, always followed by a JC dictatorship." I think we're there now, all in the same administration. Please stop trying to degrade the post to an off-topic political rant. GA flying in the US is by far the most unrestrictive and accessible in the world. Enjoy it, protect it, and appreciate it. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
world. Enjoy it, protect it, and appreciate it. Bravo! For once, a positive statement about flying. Thanks, Marco. I needed that. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2006-01-30, John Clonts wrote:
I have 3/8" tubing connected to the valve so I just fed it into a milk jug. Jug full, pinch tubing, next jug, etc. Hardly even needed a rag! The quickdrain is great. Beware that if you leave it open for a while, eventually the oil will drain around the outside of it and down the outside of your tube. I've left mine to drain overnight before and had that happen. I've got a few gallons of used oil in the hangar in buckets since I don't drink enough milk to put it all out for recycling. ![]() these days I need to schlep it over to the big oil recycling tank at a nearby airport. -- Ben Jackson http://www.ben.com/ |
![]() Ben Jackson wrote: The quickdrain is great. Beware that if you leave it open for a while, eventually the oil will drain around the outside of it and down the outside of your tube. I've left mine to drain overnight before and had that happen. How can this happen? I bought a clear piece of poly tubing from the hardare store that I put on the quick drain and then go home and finish the job the next day. Never once in 9 years of changing oil has oil somehow got onto the outside of the tubing. I've got a few gallons of used oil in the hangar in buckets since I don't drink enough milk to put it all out for recycling. ![]() these days I need to schlep it over to the big oil recycling tank at a nearby airport. See if there's somebody you know that uses an oil burner to heat their shop or garage. I have a 55 gallon drum in the hangar that friends around the airport come and put their waste oil in. When it gets about 3/4 full i call my buddy and he comes and gets it. |
On 2006-01-30, Newps wrote:
How can this happen? I bought a clear piece of poly tubing from the hardare store that I put on the quick drain and then go home and finish the job the next day. Never once in 9 years of changing oil has oil somehow got onto the outside of the tubing. Not sure since I haven't seen the inside of the valve, but the part you push up and lock to drain it is the smaller cylinder. The oil normally drains through it into the tubing, but apparently it *can* seep around the top of the plunger part when it's locked open. Maybe it's a sign of a problem with the valve, which I hadn't considered. -- Ben Jackson http://www.ben.com/ |
I've had that happen also. It seems to come out of the slot in the quick
drain that the "handles" extend through, only when they are pushed up and locked. I don't get a lot, just enough that make me wipe the tube off when I'm done. Jim |
'Iraq War Conceived in Israel' author on Current Issues Television tonight... | [email protected] | Naval Aviation | 0 | November 10th 05 06:09 PM |
Fun ATC/Top Gun MNF intro tonight | Montblack | Home Built | 9 | September 15th 05 11:43 PM |
Fun ATC/Top Gun MNF intro tonight | Montblack | Owning | 9 | September 15th 05 11:43 PM |
DC-9 runs into parked Airbus at MSP tonight | Montblack | Piloting | 8 | May 12th 05 11:06 PM |
Tonight Show | Toks Desalu | Piloting | 6 | March 18th 04 03:05 AM |
