Seaplane crash details
Old February 2nd 06, 10:26 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default Seaplane crash details
I tried to post some bitmap images with this but it didn't come up on my
server. Anyways..
Concerning the Chalks seaplane crash in Miami, fatigue features were
observed in the lower spar cap of the rear spar of the inboard end of the
right wing, bisecting 2 offset drilled holes.
D.
Old February 2nd 06, 10:31 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Capt.Doug" wrote in message
server. Anyways..
D.
Capt,
This is a non-binary newgroup so most servers will strip the attachments.
You might try alt.binaries.pictures.aviation as a place to post them.
Regards,
Jay Beckman
PP-ASEL
Chandler, AZ
Old February 2nd 06, 11:24 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Jay Beckman" wrote in message
news:ujkEf.24545$jR.8402@fed1read01...
Or just post them to http://www.tinypic.com and then post the resultant URL
here... That's probably a better solution since that way, the photos stay
around... The photos in a binary newsgroup get flushed out eventually when
new ones come in, dependent upon the amount of traffic in the newsgroup...
Old February 2nd 06, 04:03 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
On Thu, 02 Feb 2006 09:26:20 GMT, "Capt.Doug"
server. Anyways..
D.
Send them to me.
I've got the web space to share them.
I'm not a lawyer, I'm just an engineer that is interested in metal
fatigue and aging aircraft.
In particular, I'm going to buy an old 7AC or L-16.
Mike Weller
Old February 2nd 06, 05:16 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Mike Weller" wrote in message Send them to me.
They are on the way.
D.
Old February 2nd 06, 05:32 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mike;
If you're interested in 7AC's I think Todd Pattist bought one recently. You
might want to check with him on whatever fabric tests he did.
Dudley Henriques
server. Anyways..
D.
Send them to me.
Mike Weller
Old February 2nd 06, 10:24 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
("Dudley Henriques" wrote)
You might want to check with him on whatever fabric tests he did.
[Mike Weller]
I believe Steven P. McNicoll flys a 7AC.
Montblack
Old February 2nd 06, 11:58 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
I think you're right. McNicoll does fly a Champ!
Good luck with your quest. The Champ is a fine old bird.
DH
"Montblack" wrote in message
[Mike Weller]
Montblack
Old February 2nd 06, 06:19 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mike Weller wrote:
my server. Anyways..
the right wing, bisecting 2 offset drilled holes.
Send them to me.
In case you hadn't seen it, there are a couple of articles on the Flight
International web site, with photos of the cracking and some short
discussion:
http://tinyurl.com/brcwy
http://tinyurl.com/9kslp
Old February 2nd 06, 05:27 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
server. Anyways..
D.
This scenario is almost the same scenario that killed a friend of mine in
his F8F Bearcat. As these old airplanes age, even with constant care, it's
extremely difficult to assess the actual wearing down process on a specific
spot taking accumulated stress over time.
Sooner or later, subjected to the dynamics involved with in-flight forces,
all parts will deteriorate as we all know.
Finding that "sweet spot" that defines total runout time for every piece of
an airplane can be a daunting task. You can inspect, you can magnaflux, you
can estimate a failure mode through a computer model, but in the end,
something can and usually will give somewhere.
What's insidious in all this is that when these failures happen, they come
in two different scenarios. The first is obvious; a total failure of a part
which is instantly catastrophic such as was the case with my friend's
Bearcat where the wing sheared off the airplane coming out of a normal loop
at normal g, or the failure of a minor part which isn't instantly
catastrophic, but however instantly changes the entire failure model for
parts down the line that are affected by the minor part's failure.
It's a tough call on these old airplanes, and something that will be talked
about and debated by those involved in flying older airplanes without
finding a definitive answer ad infinitum.
Total replacement of a part based on an estimated failure span is good, but
even with that in place, considering the astronomical cost of doing this,
flying these old airplanes past their projected airframe runout I think will
always be a crapshoot.
Dudley Henriques
Intersting tidbit about the Miami seaplane crash and fuel reserves xyzzy Instrument Flight Rules 5 December 24th 05 12:43 PM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 06:58 PM
American Lake SPB Closing C J Campbell Piloting 23 December 27th 04 04:26 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 01:05 AM
Details on Baron Crash in Memphis? Greg Esres Piloting 0 July 11th 03 05:37 PM
