Hi All,
I am fitting my homebuilt with instruments and radios, and wanted to add a Direction Finder. I wanted a doppler type, but with small antennas in a 4 point aray with a small dimension or distance between the antennas. Am I really far out of reason, or is this an achievable goal? Charlie |
ccwillwerth wrote:
Hi All, I am fitting my homebuilt with instruments and radios, and wanted to add a Direction Finder. I wanted a doppler type, but with small antennas in a 4 point aray with a small dimension or distance between the antennas. Am I really far out of reason, or is this an achievable goal? Charlie Hi Charlie There are many kits out there that will do this. Here is one. http://www.ramseyelectronics.com/cgi...ction&key=DDF1 Of note is most require an FM receiver and aviation uses AM signals. Although the transmitted signal doesn't need to be FM it can be SSB CW AM or FM but it might be hard to get a receiver that will receive using FM on the aviation band. Although if you can get schematics of your receiver you should be able to modify it for FM reception (add a coax connection to one of the many FM demodulators kits (I think this Ramsey company has one) just make sure they both use the same IF) I wouldn't try this with your active aircraft receiver. John |
Thanks John, but the ramsey units require huge antennas and to great a
spread between them. I have looked at them on several occassion, but can't see how I could make them work. Charlie "UltraJohn" wrote in message ink.net... ccwillwerth wrote: Hi All, I am fitting my homebuilt with instruments and radios, and wanted to add a Direction Finder. I wanted a doppler type, but with small antennas in a 4 point aray with a small dimension or distance between the antennas. Am I really far out of reason, or is this an achievable goal? Charlie Hi Charlie There are many kits out there that will do this. Here is one. http://www.ramseyelectronics.com/cgi...ction&key=DDF1 Of note is most require an FM receiver and aviation uses AM signals. Although the transmitted signal doesn't need to be FM it can be SSB CW AM or FM but it might be hard to get a receiver that will receive using FM on the aviation band. Although if you can get schematics of your receiver you should be able to modify it for FM reception (add a coax connection to one of the many FM demodulators kits (I think this Ramsey company has one) just make sure they both use the same IF) I wouldn't try this with your active aircraft receiver. John |
ccwillwerth wrote:
Thanks John, but the ramsey units require huge antennas and to great a spread between them. I have looked at them on several occassion, but can't see how I could make them work. Charlie Actually Charlie you can use an electrically shortened antenna and the spacing for them is only 1 1/2 to 2 feet so it should not be a huge problem. The below link is another site with a df kit the link actually goes to the antenna page which is quite interesting. John http://www.silcom.com/~pelican2/MINI_INTRO.html |
Doppler sometimes does not work well if there are reflections - but the
aircraft has an advantage over ground vehicles so it could have a better success rate. Because the signal is line of sight, you can reduce the length of the antenna and still have an adequate signal, although you will have a reduced range. Rubber ducks can be used, although flexing can affect directivity. Another option is to install a number of directional antennas and switch between them. The aircraft has an advantage in that it can be rotated fairly easily. With a good signal indicator, you could home in on the hunted signal. I have one of the Ramsay Dopplers and normally use it on the ground for Search and Rescue. We search in rugged terrain and I have not found it as useful as a directional antenna. Years ago a friend of mine built a Doppler to use in a hidden transmitter hunt. Soon after the start, he realized it was not working, but he had left all of his other direction finding gear at home. He got his handy talkie with rubber duck out and drove around finding the strongest signal. He would drive behind buildings to determine directivity - since the building would make the signal weakest if it was directly in the path. He was first to arrive at the hidden transmitter, proving that it is the operator rather than the equipment that is key in direction finding. Colin |
Thanks Colin,
I like the Picco Doppler Mini Antenna of the system John sent info on. I could bury it in the wooden wing with dual band rubber duck antennas. The problem is that once it is in, access would be difficult to accomplish. I will be covering the wing during the summer. I gusee I could try it out before then. Thanks for the input. Charlie "COLIN LAMB" wrote in message nk.net... Doppler sometimes does not work well if there are reflections - but the aircraft has an advantage over ground vehicles so it could have a better success rate. Because the signal is line of sight, you can reduce the length of the antenna and still have an adequate signal, although you will have a reduced range. Rubber ducks can be used, although flexing can affect directivity. Another option is to install a number of directional antennas and switch between them. The aircraft has an advantage in that it can be rotated fairly easily. With a good signal indicator, you could home in on the hunted signal. I have one of the Ramsay Dopplers and normally use it on the ground for Search and Rescue. We search in rugged terrain and I have not found it as useful as a directional antenna. Years ago a friend of mine built a Doppler to use in a hidden transmitter hunt. Soon after the start, he realized it was not working, but he had left all of his other direction finding gear at home. He got his handy talkie with rubber duck out and drove around finding the strongest signal. He would drive behind buildings to determine directivity - since the building would make the signal weakest if it was directly in the path. He was first to arrive at the hidden transmitter, proving that it is the operator rather than the equipment that is key in direction finding. Colin |
![]() "ccwillwerth" wrote I like the Picco Doppler Mini Antenna of the system John sent info on. I could bury it in the wooden wing with dual band rubber duck antennas. The problem is that once it is in, access would be difficult to accomplish. I will be covering the wing during the summer. I gusee I could try it out before then. Thanks for the input. A few extra access panels could make things much better, no? -- Jim in NC |
Hi Jim, Yes, I will have the panels, but when you try to pull a 9" diameter
object through a 4" hole, something groans. I want to build the device, and make the electronic antenna rotor in a box small enough to get through the hole. If the antennas are mounted to the groundplane via BNC or something, I will be able to try different versions, but the groundplane will have to be permanent. Charlie "Morgans" wrote in message ... "ccwillwerth" wrote I like the Picco Doppler Mini Antenna of the system John sent info on. I could bury it in the wooden wing with dual band rubber duck antennas. The problem is that once it is in, access would be difficult to accomplish. I will be covering the wing during the summer. I gusee I could try it out before then. Thanks for the input. A few extra access panels could make things much better, no? -- Jim in NC |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
"New helicopters join fleet of airborne Border Patrol" | Mike | Rotorcraft | 1 | August 16th 04 09:37 PM |
Boeing $241.8 million contract ballistic missile-hunting Airborne Laser | Larry Dighera | Military Aviation | 1 | May 29th 04 12:05 PM |
Coalition casualties for October | Michael Petukhov | Military Aviation | 16 | November 4th 03 11:14 PM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
