Missed approach procedure...
Old November 7th 03, 11:54 PM
Default Missed approach procedure...
If the missed approach on the IAP says something like:
heading of 270 to 4000
Intercept the XXX VOR R-180
Direct to XXX VOR
What should you do if you get to R-180 before you get to 4000?
Keep climbing on 270 to 4000?
Turn and track the R-180 while climbing?
The IAP has no minimum climb gradient specified.
What minimum climb gradient is assumed if none is specified?
Old November 8th 03, 02:39 AM
ArtP
On Sat, 08 Nov 2003 02:01:13 GMT, "Greg Goodknight"
"ArtP" wrote in message
Direct to XXX VOR
Follow the procedure (keep climbing on 270 until 4000 feet then turn
back to intercept the radial. It is possible that unless you are at
4000 you may not want to be on that radial.
I think it far more likely that ATC will expect the pilot to remain on the
specified course and if an obstruction was a problem there would be a
minimum gradient specified or a minimum crossing.
According to the AIM (Instrument Departures) a climb gradient
would only be specified if a climb of greater than 200 feet per
nautical mile were required. Without an indication of a climbing turn
via I would continue on the specified heading until the specified
altitude were reached.
I would interpret the above missed instruction as "climb and maintain 4000,
maintain heading of 270 to intercept the 180 radial inbound..." without a
second thought.
Take a look at FQD LOC RWY 1 for an example of a climb then a
climbing turn. Take a look at RWI VOR/DME 22 for an example of a climb
via an intercepted radial (the method you are describing). Take a look
at RDU NDB RWY 5R for another example.
Perhaps an example from "nospam" of an actual plate would be more
instructive.
I agree.
Old November 8th 03, 04:10 AM
Greg Goodknight
Direct to XXX VOR
Perhaps if you found just one missed approach, or any procedure that
specifies passing through a radial and doubling back after a specified
altitude without the benefit of any course guidance; remember, the
hypothetical was just flying a heading until the radial was intercepted. I
can't imagine a course reversal ever being implied in free space.
The hypothetical seemed flawed to me, hence my request for an real example
from "nospam". If I was faced with the actual wording posed and ATC was not
available, I would not be playing FAR Bingo, I'd fly the course specified
and not invent a new one because of a possibility of an implied altitude
problem.
-Greg
4000,
second thought.
instructive.
I agree.
Old November 8th 03, 04:45 AM
instructive.
Take a look at the ILS to RWY 24 and (K)CRQ
This is where I saw the missed. It is not a good example as the missed
takes you out over the ocean and in fact either way you look at it, it
would be safe.
I'm just trying to understand in the general sense what the rules are.
In reading the recent AOPA magazine it had a sumary of accidents in
CA and one was someone getting a radar vector and assuming that he
could let down to the crossing altitude of the next segment.
He did this at night and it was fatal.
I understand that not understanding the subleties of what the rules
are for flying IFR can also be Fatal so I'm just trying to understand.
Another approach with a similar missed that is unlclear:
KCNO ILS RWY 26R
Missed:
Climb to 1400 then climbing left turn to 4000 direct PDZ and hold.
Looking at the plate missed seems to be about 4 mi from PDZ.
DH is 836 so at 200ft /mi 1400 gets you to 6 mi from PDZ
Assume that the turn gives you another 200 ft thats 1600 and 6 miles
at 200 per nm that gets you to PDZ and 2800.
The missed specifies 4000
So what do you do hold at PDZ and climb to 4000?
Again in this specific case it looks like that would be safe.
Old November 8th 03, 05:16 AM
ArtP
would be safe.
I would climb to 3000 then I would do the turn. If they wanted you to
turn before you reached 3000 they would have specified a climbing turn
or do what they did below (specify an altitude straight ahead and then
a climbing turn). When they specify a climb altitude before the turn,
you are expected to be at that altitude before you start the turn.
KCNO ILS RWY 26R
Missed:
I would fly 255 until I reached 1400 feet. I would then do a
climbing left turn direct to PDZ. If by the time I got to PDZ I was
not at 4000 I would enter the hold and continue to climb until I
reached 4000.
Old November 8th 03, 06:31 AM
Greg Goodknight
instructive.
Had to look in the old logbook. Haven't flown there since 6/27/1974. Wonder
if it's changed much.
would be safe.
You transcribed the meaning incorrectly. It says "Climb to 3000 via heading
245 and OCN R-145 to OCN VORTAC", which is, in essence, what I said I would
do. It doesn't say climb to 3000 on a heading of 245 and tben intercept. It
gives you a route (heading 245 and OCN R-145 to OCN) and an altitude
(3000')to climb to.
KCNO ILS RWY 26R
Gee, more of my old stomping grounds. I soloed at Chino on 1/16/1974.
Missed:
This is also crystal clear and not at all similar. You climb to 1400 and
then continue a climb while turning direct to PDZ. There is no possibility
of overshooting a radial that needs to be intercepted.
So keep climbing. Don't worry, SoCal Approach will be asking you about your
climb rate, and the initial climb to 1400 seems to be chosen to get you high
enough.
Yep. Next time in your thought experiments, don't fly a C-150 under IFR with
full fuel and extra passengers in the baggage compartment and you'll climb
faster
yep!
cheers
-Greg
The perfect approach Capt.Doug Home Built 25 December 3rd 04 03:37 AM
DME req'd on ILS (not ILS-DME) approach? Don Faulkner Instrument Flight Rules 13 October 7th 03 03:54 AM
Instrument Approaches and procedure turns.... Cecil E. Chapman Instrument Flight Rules 58 September 18th 03 10:40 PM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
