First time I've stumbled across one of these:
Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack |
"Montblack" wrote in message ... First time I've stumbled across one of these: Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack Interesting, delta P between two sources, one more or less pointing forward and one more or less pointing downward. I suppose the indicator has a pressure diaphragm inside it linked to the needle... I want an AOA indicator for the BD4 someday... Hmmmmmm....... |
..Blueskies. wrote:
"Montblack" wrote in message ... First time I've stumbled across one of these: Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack Interesting, delta P between two sources, one more or less pointing forward and one more or less pointing downward. I suppose the indicator has a pressure diaphragm inside it linked to the needle... I want an AOA indicator for the BD4 someday... Hmmmmmm....... A couple of years ago Kitplanes had an article about and AOA sytem that used 2 ports flush with the wing surface near the wing tips. It's a simplified version of a system the military has been using for decades. The military version uses a conical probe sticking out of the side of the fuselage. There are two sets of slots a few degrees part facing towards the front of the airplane. These slots are ports that send air pressure to two sensing chambers. Here's where they decided to get complicated: the cone is then driven until the chamber measure equal pressure. The cone's position is then transmitted to an indicator. Obviously the system isn't for single engine tractor airplane. The 3.125" indicator is a tad big for most homebuilts, but does contain switches for stall warning and AOA indexer lights. It seems to me some enterprising electronics genius should be able to design a simple system that does all this in solid state. Dan, U.S. Air Force, retired |
"Dan, U.S. Air Force, retired" wrote in message ... .Blueskies. wrote: "Montblack" wrote in message ... First time I've stumbled across one of these: Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack Interesting, delta P between two sources, one more or less pointing forward and one more or less pointing downward. I suppose the indicator has a pressure diaphragm inside it linked to the needle... I want an AOA indicator for the BD4 someday... Hmmmmmm....... A couple of years ago Kitplanes had an article about and AOA sytem that used 2 ports flush with the wing surface near the wing tips. It's a simplified version of a system the military has been using for decades. The military version uses a conical probe sticking out of the side of the fuselage. There are two sets of slots a few degrees part facing towards the front of the airplane. These slots are ports that send air pressure to two sensing chambers. Here's where they decided to get complicated: the cone is then driven until the chamber measure equal pressure. The cone's position is then transmitted to an indicator. Obviously the system isn't for single engine tractor airplane. The 3.125" indicator is a tad big for most homebuilts, but does contain switches for stall warning and AOA indexer lights. It seems to me some enterprising electronics genius should be able to design a simple system that does all this in solid state. Dan, U.S. Air Force, retired I'd also like an electronic AOA indicator. There are several probes that work on three pressure pickups like (http://www.cgmasi.com/aviation/index.html). In sailplanes we can just tape a couple of yarns of the side of the canopy and mark the inside with grease pencil. bildan |
"Bill Daniels" bildan@comcast-dot-net wrote in message ... "Dan, U.S. Air Force, retired" wrote in message ... A couple of years ago Kitplanes had an article about and AOA sytem that used 2 ports flush with the wing surface near the wing tips. It's a simplified version of a system the military has been using for decades. The military version uses a conical probe sticking out of the side of the fuselage. There are two sets of slots a few degrees part facing towards the front of the airplane. These slots are ports that send air pressure to two sensing chambers. Here's where they decided to get complicated: the cone is then driven until the chamber measure equal pressure. The cone's position is then transmitted to an indicator. Obviously the system isn't for single engine tractor airplane. The 3.125" indicator is a tad big for most homebuilts, but does contain switches for stall warning and AOA indexer lights. It seems to me some enterprising electronics genius should be able to design a simple system that does all this in solid state. Dan, U.S. Air Force, retired I'd also like an electronic AOA indicator. There are several probes that work on three pressure pickups like (http://www.cgmasi.com/aviation/index.html). In sailplanes we can just tape a couple of yarns of the side of the canopy and mark the inside with grease pencil. bildan Here is an electronic version: http://advanced-control-systems.com/AOA/aoa.htm Two pickups; one on the top of the wing and one on the bottom... |
..Blueskies. wrote:
"Bill Daniels" bildan@comcast-dot-net wrote in message ... "Dan, U.S. Air Force, retired" wrote in message ... A couple of years ago Kitplanes had an article about and AOA sytem that used 2 ports flush with the wing surface near the wing tips. It's a simplified version of a system the military has been using for decades. The military version uses a conical probe sticking out of the side of the fuselage. There are two sets of slots a few degrees part facing towards the front of the airplane. These slots are ports that send air pressure to two sensing chambers. Here's where they decided to get complicated: the cone is then driven until the chamber measure equal pressure. The cone's position is then transmitted to an indicator. Obviously the system isn't for single engine tractor airplane. The 3.125" indicator is a tad big for most homebuilts, but does contain switches for stall warning and AOA indexer lights. It seems to me some enterprising electronics genius should be able to design a simple system that does all this in solid state. Dan, U.S. Air Force, retired I'd also like an electronic AOA indicator. There are several probes that work on three pressure pickups like (http://www.cgmasi.com/aviation/index.html). In sailplanes we can just tape a couple of yarns of the side of the canopy and mark the inside with grease pencil. bildan Here is an electronic version: http://advanced-control-systems.com/AOA/aoa.htm Two pickups; one on the top of the wing and one on the bottom... That's the system I waas thinking of. Dan, U.S. Air Force, retired |
... "Dan, U.S. Air Force, retired" wrote in message ... .Blueskies. wrote: "Montblack" wrote in message ... First time I've stumbled across one of these: Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack Interesting, delta P between two sources, one more or less pointing forward and one more or less pointing downward. I suppose the indicator has a pressure diaphragm inside it linked to the needle... I want an AOA indicator for the BD4 someday... Hmmmmmm....... A couple of years ago Kitplanes had an article about and AOA sytem that used 2 ports flush with the wing surface near the wing tips. It's a simplified version of a system the military has been using for decades. The military version uses a conical probe sticking out of the side of the fuselage. There are two sets of slots a few degrees part facing towards the front of the airplane. These slots are ports that send air pressure to two sensing chambers. Here's where they decided to get complicated: the cone is then driven until the chamber measure equal pressure. The cone's position is then transmitted to an indicator. Obviously the system isn't for single engine tractor airplane. The 3.125" indicator is a tad big for most homebuilts, but does contain switches for stall warning and AOA indexer lights. It seems to me some enterprising electronics genius should be able to design a simple system that does all this in solid state. Dan, U.S. Air Force, retired I'd also like an electronic AOA indicator. There are several probes that work on three pressure pickups like (http://www.cgmasi.com/aviation/index.html). In sailplanes we can just tape a couple of yarns of the side of the canopy and mark the inside with grease pencil. bildan Light :-) Simple :-) Reliable :-) But, won't work for single engine tractor airplanes :-( |
"Montblack" wrote: First time I've stumbled across one of these: Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack Hey, most of you old guys are even older than I am. Didn't they used to hang AOA indicators on the wing struts of biplanes? A little flat plate that moved a big needle around a graduated arc as it was pushed by the relative wind? Sort of like a weathervane. Or was that just an airspeed indicator I'm thinking of? |
I downloaded a homebuilt version of a AOA some time ago. If you want it
contact me and I will I will attach a copy and send it to you. "Montblack" wrote in message ... First time I've stumbled across one of these: Lift Reserve Indicator http://home.hiwaay.net/~sbuc/journal/liftreserve.htm "One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the 1970's and has been offered in a couple of different variations since then. There is considerable controversy over just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since the LRI would fit in the same space as the little AI and was in the pilot's angle of vision." http://www.liftreserve.com/ Company website - InAir Instruments Montblack |
The last vane-type indicator I witnessed was hanging on the strut of a
New Standard DB-25 (circa 1926). It was an airspeed indicator and appeared to function quite well from my perspective in the forward-left front seat. Orville Wright used a vane-type device in the autopilot system he invented. While this was the world's first functional autopilot, it never became popular. Sperry's gyroscopic autopilot system hit the market shortly after, and was superior. I'm not familiar with any vane-type AOA indicators that could be mounted on a strut, but that doesn't mean that they didn't exist. If anyone knows of one, I'd like to see it. Harry |
| Thread Tools | |
| Display Modes | |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 08:50 PM |
| Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 05:08 PM |
| New theory of flight released Sept 2004 | Mark Oliver | Piloting | 70 | October 10th 04 11:50 PM |
| Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 11:55 PM |
