Twenty years!
Old February 13th 06, 08:00 PM posted to rec.aviation.soaring
Default Twenty years!
I was poking around on the Web looking for information about wave
soaring, and I happened to notice that in a few days it'll be the 20th
anniversary of Bob Harris' 17 February 1986 wave flight to 49,009 feet
absolute, with a height gain of some 39,900 feet.
What I remember most about the flight and its aftermath was feeling a
bit dismayed about the reported airspace violations, and how it seemed
to put the sport of soaring in a bad light.
However, these days I'm much more inclined to recognize Harris'
fortitude, dedication, and airmanship. He spent literally years
preparing for the flight, preparing for conditions that probably only
come along every five or twenty years.
Yeah, technically, he bent a rule here and there, and I don't condone
that. But these days I feel a heck of a lot less inclined to be casting
the first stone. If it'd been me up there with almost literally
once-in-a-lifetime conditions, I can't say for sure I'd have done any
different.
So, here's to you, Bob Harris, holder of the sailplane absolute world
altitude record for twenty years. Congratulations!
Thanks, and best regards to all
Bob K.
Old February 13th 06, 08:30 PM posted to rec.aviation.soaring
Bob, are you aware the Grob 102 that he flew on that little adventure is
hanging in a prominent place
at the Udvar-Hazy Air & Space Museum located at Dulles Airport?
It is placed so you can stand almost eye level on one of the upper levels
with it about 20 feet in
front of you.
There are at least 7 or 8 sailplanes/gliders on display at the museum
including the Shuttle.
Gale Winnett
Old February 14th 06, 05:55 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Thanks for the history lesson, Bob, certainly a fantastic acheivement!
Old February 14th 06, 06:09 AM posted to rec.aviation.soaring
Bob Lamson's pressurized glider. High flier, but not a world record
setter. IIRC, the flight life was pretty limited. There were attempts
in the lee of Mt. Rainier in Washington state, but nothing in excess of
40,000ft achieved.
Perhaps better comments will follow.
Frank Whiteley
Old February 14th 06, 06:07 PM posted to rec.aviation.soaring
Earlier, Bruce Hoult wrote:
So what is the pressurized metal sailplane hanging in the Museum of
Flight at "Boeing Field" in Seattle?
As others point out, it's Bob Lamson's Alcor. It's actually not metal,
but rather fiberglass and wood. Weise's book has a lot of great info on
Alcor's history.
The Alcor itself is a pretty fascinating ship. It's one of those
testaments to dedication and ingenuity that find their way into
forgotten corners of museums. it's sort of sad to see it hoisted way
out of sight.
Tony Burton flew Alcor in Canada to explore the climatology of the
Chinook Arch that often spans Calgary. He came down to the Tehachapi
SHA convention several years ago and gave a presentation on the Chinook
project. He'll tell you that he was chosen on the basis of fitting into
Alcor's undersized cockpit, but it's clear from the book and also his
presentation that he's also a damn good pilot and engineer.
If I recall correctly, Alcor's pressurization system is based on an A14
oxygen system in which the mask valves are turned around; the pilot
breathes in oxygen-rich air from the cabin and exhales overboard
through the hose. The cockpit was originally designed around a fairly
small pilot, but apparently turned out even smaller than intended, so
they actually stretched the cockpit laterally after the fuselage was
finished. But even so, it's said to be a tight fit for anyone over
about 5ft7".
I believe that the weak link in the Alcor's pressurization system was
the canopy seal; I think that the Chinook engineers never got it
working and so the Chinook flights were all unpressurized. That's sort
of as you'd expect; even with a pressure differential of only 3" of
mercury (about 1.5 psi) the separation force on the canopy is going to
be several hundred pounds, and it's hard to achieve a good seal under
the distortion you get from the pressure differential. Add to that the
distortion caused by the different thermal characteristics of the
various materials, and it becomes a very tough problem indeed.
Bob K.
Old February 14th 06, 07:22 PM posted to rec.aviation.soaring
"Bob Kuykendall" wrote in message
snip----
Bob K.
Sealing a conventional canopy would be difficult but there might be another
way. Gary Sutherland's MOBA
(http://esoaring.com/pastarticleprojects.htm#moba) has a cockpit that opens
with the entire forward fuselage shell sliking forward relative to the seat
and the rest of the fuselage. That design could use a simple O-ring at the
separation line. Once properly sealed, the energy required to maintain
pressuration isn't too bad.
Bill Daniels
Old February 14th 06, 09:50 PM posted to rec.aviation.soaring
Earlier, Bill Daniels wrote:
...Gary Sutherland's MOBA...
Exactly! That's been a feature of all of my back-of-the-envelope
sketches for pressurized sailplanes, ever since I saw the MOBA in one
of Stan Hall's articles. The circular opening keeps the seal perimeter
to a minimum, and it would be very easy to seal using a conventional or
inflatable sealing ring. And you could even use a simple eighth-turn
thread to latch it with very few moving parts.
However, one major issue with that arrangement is emergency egress.
That's got pyrotechnics written all over it...
Thanks, Bob K.
Old February 14th 06, 06:06 AM posted to rec.aviation.soaring
In article .com,
different.
I don't know the details of this flight, but here in NZ we seem to be
having huge numbers of problems with gliders being denied access to
airspace. Even Terry Delore and Steve Fossett have problems with this
-- see Terry's book. It doesn't seem to matter that the glider may be
on a world record attempt, or that the pilot has thousands of hours
experience, or that a C152 with someone on thir first cross-country
would be allowed into that airspace, or that the conflicting traffic is
one flight due to arrive in an hour's time -- or even no traffic at all.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old February 15th 06, 05:27 AM posted to rec.aviation.soaring
airspace.
Harris was denied access to the airspace also. He went ahead and flew
anyhow. He had his pilot certificate suspended.
Isn't it nice to know that the world record is an illegal flight.
Any flight that breaks his record may also have to be an illegal flight.
Or the honest pilot will have to stay on the ground.
Great sport record flying.
Duane
Good for another 2 years! Jim Burns Owning 7 November 19th 05 03:27 PM
Ten Years of Flying Jay Honeck Piloting 20 February 19th 05 02:05 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
We have done auto tows in the past few years Joe Allbritten Soaring 2 March 5th 04 03:45 AM
