Safety Pilot Qualification?
Old November 18th 03, 04:38 PM
Richard
Default Safety Pilot Qualification?
I'm sure this has be hashed over many times, but I can't find it now. In
the current issue of "IFR" (December, 2003), an editorial answer to a
reader's question contained the following - (referring to a safety pilot
requirements):
".... if you use a safety pilot and write that safety pilot's name in your
logbook, we'd highly suggest that you treat that safety pilot as a required
crewmember........... If the airplane is high performance, complex, or
tailwheel, that safety-pilot-required-crewmember should have those
additional endorsements, too."
For many years I have been under the impression that a safety pilot must
possess at least a private pilot certificate with category and class ratings
appropriate to the aircraft being flown. In my case, (182-RG), I don't
think that a safety pilot has to have any of the above additional
endorsements. Has something changed, or have I just been wrong all these
years?
Thanks in advance!
Old November 18th 03, 04:57 PM
Ron Natalie
"Richard" wrote in message t...
requirements):
I have written the editor who published a correction, which is still wrong.
years?
No Paul Berge just isn't that good of an editor. The safety pilot does not need
to meet the endorsement requirements unless he is going to be pilot in command.
A safety pilot can be, but isn't necessarily pilot in command.
Old November 18th 03, 11:13 PM
Kobra
your
required
Notice it says "should have those..." It doesn't say is required to.
Sounds like a recommendation not the law.
Kobra
Old November 19th 03, 01:06 AM
Robert Henry
"Kobra" wrote in message
Yes, but the phrasing attaches significance to the fact that the safety
pilot's name is written in the logbook when there is no correlation between
the two concepts. For example, consider this: If you type on a computer
keyboard to send a message, you should treat the message as confidential.
Old November 19th 03, 02:44 AM
John T
"Robert Henry" wrote in message
news:Amzub.27981$HD3.24074@lakeread06
If you type on a computer keyboard to send a message, you should
Especially if you send the message to a USENET server...
John T
http://tknowlogy.com/tknoFlyer
_______________
Old November 19th 03, 03:04 AM
Robert Henry
"John T" wrote in message
ws.com...
Exactly.
Old November 22nd 03, 02:02 AM
Ron Rosenfeld
On Tue, 18 Nov 2003 16:38:33 GMT, "Richard" wrote:
a safety pilot must
And also a current medical certificate.
Old November 22nd 03, 03:40 AM
Casey Wilson
I've been following this thread all along. It seems to me the simple answer
at the very beginning is that the "safety pilot" must be legal to fly the
airplane, period.
Old November 22nd 03, 12:32 PM
Ron Rosenfeld
On Sat, 22 Nov 2003 03:40:41 GMT, "Casey Wilson"
airplane, period.
Then you have inferred the wrong conclusion.
For example, to act as a safety pilot, you do NOT need to be current to
carry passengers.
If the aircraft requires an endorsement such as tail-dragger,
high-performance, complex -- the safety pilot does NOT require that
endorsement.
Old November 22nd 03, 06:31 PM
Ron Natalie
"Casey Wilson" wrote in message ...
airplane, period.
Your simple answer is wrong. The safety pilot only need posess a private (or better) pilot
certificate with category and class ratings and a medical. He is not required
to meet the specific pilot in command requirements (currency, BFR, HP/complex
endorsements) etc... unless he is specifically serving in that role.
Here are the only two rules that apply to safety pilot qualifications:
91.109
(b) No person may operate a civil aircraft in simulated instrument flight unless -
(1) The other control seat is occupied by a safety pilot who possesses at least a private
pilot certificate with category and class ratings appropriate to the aircraft being flown.
61.3(c)
(1) Except as provided for in paragraph (c)(2) of this section, a person may not act as pilot in command or in any
other capacity as a required pilot flight crewmember of an aircraft, under a certificate issued to that person under
this part, unless that person has a current and appropriate medical certificate...
Nowhere does it say he has to be "qualified to fly the plane." His role is to provide the
see-and-avoid vigilance that the hooded pilot can not provide.
Pilot Error? Is it Mr. Damron? Badwater Bill Home Built 3 June 23rd 04 04:05 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 05:39 AM
Share time in Sacramento - Safety pilot needed J Instrument Flight Rules 0 September 26th 03 01:55 AM
Logging instrument approaches Slav Inger Instrument Flight Rules 33 July 27th 03 11:00 PM
