At http://www.taylorcraft.info/tcraft/proj207.jpg we see a restored tailsection. The bushing appears to have first been welded to a plate, and the plate in turn welded to the tailpost. Is that what was done? Is this done to help with alignment of the bushing? - Mike |
Mike wrote:
At http://www.taylorcraft.info/tcraft/proj207.jpg we see a restored tailsection. The bushing appears to have first been welded to a plate, and the plate in turn welded to the tailpost. Is that what was done? Is this done to help with alignment of the bushing? - Mike That's one reason. It is a lot easier to assemble (weld) the bushings jigged up solid on the bench. How would you align and clamp up the bushing to the tailpost and still be able to reach the weld area? Often this apporach is taken on new construction just because it provides a bit of space to allow for fabric without binding. If the bushing were dammaged somehow and needed to be replaced, this also spreads the new weld to the tailpost out over solid tube. Not to worry. It looks like a good repair (from here anyway). Richard |
Thanks Richard - not my project, just trying to learn from others
restorations - Mike |
"Mike" wrote in message
ups.com... At http://www.taylorcraft.info/tcraft/proj207.jpg we see a restored tailsection. The bushing appears to have first been welded to a plate, and the plate in turn welded to the tailpost. Is that what was done? Is this done to help with alignment of the bushing? - Mike I would guess that the objective was to reinforce the tube where it is going to get localized loads. The extra thickness should help reduce the tendancy to "kink" at the point that the load from the rudder is applied up in the middle of the span of the tube. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
This looks like one of the three rudder hinges attached to the vertical
stab. And some nice repair work where rust does its damnedest to keep you from flying. The 4130 steel part you call a "bushing" is supposed to contain a pressed in oilite bronze bushing inside, for easy turning of the rudder. When the bushing wears out, you just press it out and replace it with a new one, which I have done on occasion. T-Craft owner since the '80's.. |
| Thread Tools | |
| Display Modes | |
| Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 10:32 PM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Partnership Question | Harry Gordon | Owning | 4 | August 17th 03 12:23 AM |
