Sticking yoke
Old February 20th 06, 04:06 AM posted to rec.aviation.owning
Default Sticking yoke
When doing steep turns, I noticed that there is a little resistance to pitch
changes on the yoke. It seems it binds a little in the bearing through the
panel. Does anyone have a suggestion for the type of lubricant I could use
on this? Do they make anything for this purpose?
Old February 20th 06, 04:29 AM posted to rec.aviation.owning
If its really sticking you need to have it looked at. Its not likely a
lube issue, its probably an issue with something mechanical (bell
crank, etc). My Mooney requires 100 hr control tubes lube. When
controls need lube they certainly do not stick, they just feel
"heavier" in general.
-Robert
Old February 20th 06, 05:14 AM posted to rec.aviation.owning
pitch changes on the yoke. It seems it binds a little in the bearing
through the panel. Does anyone have a suggestion for the type of lubricant
I could use on this? Do they make anything for this purpose?
A shot of silicone spray on the yoke shafts every 10 - 20 hours will keep
everything nice and loose.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 20th 06, 11:17 PM posted to rec.aviation.owning
At the risk of disagreeing with Jay, I would not use a silicone spray. The
carrier for the silicone oil has destroyed more plastic than I care to tell.
I used silicone spray on the heater control levers on my car when they
started binding. Worked great, until all of the levers broke off within a
week of each other. Used it on plastic ski boots. Looked great and the snow
didn't stick. I dropped one onto concrete and it shattered into several
pieces.
My control yoke goes through a plastic bushing. Personally, I don't use
silicone spray on anything other than metal. I would try dry graphite, if
the bearing is black, or talcum powder, if the bearing is white and
completely free of oil or grease. If you use the silicone and the shaft
moves through a plastic bearing, spray it on the metal and let the carrier
evaporate before sliding it back and forth.
"Jay Honeck" wrote in message
news:bfcKf.809772$xm3.486405@attbi_s21...
lubricant I could use on this? Do they make anything for this purpose?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 21st 06, 03:43 AM posted to rec.aviation.owning
The carrier for the silicone oil has destroyed more plastic than I care to
tell.
Interesting -- I've never heard that before. Having your yoke come off in
your hands could ruin your whole day.
Anyone else experienced this nasty side effect of silicone sprays?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 21st 06, 03:55 AM posted to rec.aviation.owning
In article t%vKf.811830$xm3.579900@attbi_s21,
tell.
yes - not with any plastic on an aircraft. But I've seen silicone destroy
some plastic years ago.
Bob Noel
Looking for a sig the
lawyers will hate
Old February 22nd 06, 07:13 PM posted to rec.aviation.owning
I have used a teflon spray. But it may have the same carrier characterists.
tell.
Old February 20th 06, 03:04 PM posted to rec.aviation.owning
Probably don't use an oil based lube. It may cause the bushing in there
to swell. I use a clear synthetic grease, then wipe off excess after
working it around lots. A silicone lube should be okay too.
Old February 21st 06, 11:35 PM posted to rec.aviation.owning
"soxinbox" wrote in message
My yoke goes through a plastic-like bushing and the co-pilot side squeaked
like heck. It was loud, sharp and would rattle my teeth. I asked my
mechanic if I could just give it a shot of WD40 or silicone spray. He said
not to use any liquid-like spray. Not because it destroyed plastic, but
because it would attract dirt and get all sticky and gummed up eventually.
He recommended graphite powder.
I tried the graphite and it didn't work. Frustrated, I sprayed WD40 in
there and haven't heard a peep since. I will now have to keep an eye on the
bushing.
Kobra
Old February 22nd 06, 05:13 AM posted to rec.aviation.owning
"Kobra" writes:
bushing.
WD40 is a lousy lubricant. It's not supposed to be one...
You can look at the LPS series, there are various grades.
I also have a no-name silicon spray with a KS number,
but doubt you can find it easily...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
O-360 sticking valve update [email protected] Owning 19 January 31st 06 01:04 PM
Beech dual yoke w/rams horns/color preference Dan Karshin Aviation Marketplace 1 March 28th 04 05:04 PM
CH yoke and peddals? Tlewis95 Simulators 8 December 2nd 03 11:58 AM
CH Product Yoke with IP Trainer 6.5 Sanjay Kumar Instrument Flight Rules 2 October 10th 03 07:47 AM
CFS-1 and CH Yoke / Pedals Andy & Lucinda Simulators 3 September 4th 03 01:14 PM
