I am new to IFR (pilot a long time just working on rating now, not sure how much I will use it but hope too).
I am restoring an old plane and doing a completely new panel, which I need to spec out in about 6 months. I would like to keep the plane light, but still... I need some help in deciding whether to get a 530 with a backup 430 - or something else. Maybe the 480 though I have seen the debates. Perhaps a mx20 or Avidyne 500? What about an HSI for the panel? sandel? One thing I really do want is an active tcas and a display that i can instantly identify target location on. I will also add a stec autopilot. What would you put in? I don't have that much space. A 530 would fit in the center below the throttle quadrant, but any other nav/comm would go on the right side of the plane. In liu of a 530, I could put a mx20 like box in the center, but the nav/comm would need to be on the right side. thanks for the help. |
You didn't say what make/model "old plane" but consider
factors... 1. Electrical loads and power available, including backup battery power; 2. Panel space; 3. Budget 4. Ease of use, system integration. A quality avionics shop will be able to assist in designing and fabrication of a new panel and do a proper electrical system survey. Also, you will want to consider other systems, such as pneumatic and the engine in general. You might want to get the rating before you finalize the new panel, you'll have a better idea of what and where to spend your money. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "freestone" wrote in message ... | | I am new to IFR (pilot a long time just working on rating now, not sure | how much I will use it but hope too). | | I am restoring an old plane and doing a completely new panel, which I | need to spec out in about 6 months. | | I would like to keep the plane light, but still... | | I need some help in deciding whether to get a 530 with a backup 430 - | or something else. Maybe the 480 though I have seen the debates. | | Perhaps a mx20 or Avidyne 500? | | What about an HSI for the panel? sandel? | | One thing I really do want is an active tcas and a display that i can | instantly identify target location on. | | I will also add a stec autopilot. | | What would you put in? I don't have that much space. A 530 would fit | in the center below the throttle quadrant, but any other nav/comm would | go on the right side of the plane. In liu of a 530, I could put a mx20 | like box in the center, but the nav/comm would need to be on the right | side. | | thanks for the help. | | | -- | freestone |
A dehavilland Beaver. 70amp alternator.
as restoration going on i will need to spec the panel out in late summer or so. will Garmin update the 530's with better resolution, waas, airways, etc? Not planning on doing serious IFR in this plane, but I do need to get above coastal clouds and also will be going into backcountry. Use on the west coast, up and down it. Panel space is always tight. Budget can be flexible, but I do want to preserve a lot of the authenticity of the beaver, yet I want to have good situational awareness. Room as mentioned in the center for either a 530 or something like an mx20, and room in front of right seat for another nav/com, transponder, etc. Will have an active tcas in the plane - and would like a nice display perhaps a sandel hsi to display it on seperate from garmin or so display which gets cluttered. maybe a dedicated 3 inch hazard display instead. ease of use and "future proofing" of course is nice. thanks for the advice, Quote:
As to what Garmin will do, ask Garmin. They can even help
you with selections for what you want. You may want to have more electrical power, perhaps a second generator and battery, with a load shedding bus. You could just have the Beaver completely refurbed stock and use a Garmin 396 . All IFR is serious. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "freestone" wrote in message ... | | A dehavilland Beaver. 70amp alternator. | | as restoration going on i will need to spec the panel out in late | summer or so. will Garmin update the 530's with better resolution, | waas, airways, etc? | | Not planning on doing serious IFR in this plane, but I do need to get | above coastal clouds and also will be going into backcountry. Use on | the west coast, up and down it. | | Panel space is always tight. | | Budget can be flexible, but I do want to preserve a lot of the | authenticity of the beaver, yet I want to have good situational | awareness. Room as mentioned in the center for either a 530 or | something like an mx20, and room in front of right seat for another | nav/com, transponder, etc. | | Will have an active tcas in the plane - and would like a nice display | perhaps a sandel hsi to display it on seperate from garmin or so | display which gets cluttered. maybe a dedicated 3 inch hazard display | instead. | | ease of use and "future proofing" of course is nice. | | | thanks for the advice, | | | Jim Macklin Wrote: | You didn't say what make/model "old plane" but consider | factors... | 1. Electrical loads and power available, including backup | battery power; | 2. Panel space; | 3. Budget | 4. Ease of use, system integration. | | A quality avionics shop will be able to assist in designing | and fabrication of a new panel and do a proper electrical | system survey. Also, you will want to consider other | systems, such as pneumatic and the engine in general. | | You might want to get the rating before you finalize the new | panel, you'll have a better idea of what and where to spend | your money. | | | -- | James H. Macklin | ATP,CFI,A&P | | -- | The people think the Constitution protects their rights; | But government sees it as an obstacle to be overcome. | some support | http://www.usdoj.gov/olc/secondamendment2.htm | See http://www.fija.org/ more about your rights and duties. | | | | "freestone" wrote | in message ... | | | | I am new to IFR (pilot a long time just working on rating | now, not sure | | how much I will use it but hope too). | | | | I am restoring an old plane and doing a completely new | panel, which I | | need to spec out in about 6 months. | | | | I would like to keep the plane light, but still... | | | | I need some help in deciding whether to get a 530 with a | backup 430 - | | or something else. Maybe the 480 though I have seen the | debates. | | | | Perhaps a mx20 or Avidyne 500? | | | | What about an HSI for the panel? sandel? | | | | One thing I really do want is an active tcas and a display | that i can | | instantly identify target location on. | | | | I will also add a stec autopilot. | | | | What would you put in? I don't have that much space. A | 530 would fit | | in the center below the throttle quadrant, but any other | nav/comm would | | go on the right side of the plane. In liu of a 530, I | could put a mx20 | | like box in the center, but the nav/comm would need to be | on the right | | side. | | | | thanks for the help. | | | | | | -- | | freestone | | | -- | freestone |
All you really need is a radio, an IFR GPS, and a VOR with a
glideslope. You don't really NEED marker beacons, DME or ADF. Couple your all electric autopilot to either your GPS or your VOR head. With a GPS and an autopilot, you don't really need an HSI (they are expensive). Back all this up with a handheld radio (with it's own outside antennae) and a handheld GPS (with it's own antennae) and you have a modern, redundant, easy to fly panel. Just use the GPS to fly enroute and when you get there, fly the ILS. The VOR backs up the GPS and the GPS backs up the VOR. Loose vacuum and you still have the autopilot. Loose electic and you still have your vacuum instruments and your handhelds. What a setup! |
Why not a hinged panel? | Jay Honeck | Owning | 22 | March 7th 05 11:15 PM |
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) | Heiko Brandstaedter | Simulators | 0 | October 7th 04 02:42 PM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
Air Force Academy Review Panel Releases Report | Otis Willie | Military Aviation | 0 | September 19th 03 03:45 AM |
Air Force Museum forms review panel | Otis Willie | Military Aviation | 2 | August 29th 03 04:41 PM |
