Misleading Notam
Old December 1st 03, 05:49 PM
Greg Esres
Default Misleading Notam
One of our local pilots misunderstood a common Notam, as shown below.
He thought the "ADD: From Shelby to RW 17: 3.52 degrees" meant add
3.52 degrees to the final approach course.
How reasonable do you think his interpretation?
(BTW, the notam just adds a descent gradient to a NP approach.)
FDC 3/0143 M01 FI/T GENERAL DEWITT SPAIN, MEMPHIS, TN. VOR RWY
16, ORIG...CHANGE ALL REFERENCES TO RWY 16/34 TO RWY 17/35.
ADD: FROM SHLBY TO RW 17: 3.52 DEGREES, TCH 31. ADD NOTE: VGSI
AND DESCENT ANGLES NOT COINCIDENT.
Old December 1st 03, 07:29 PM
Larry Fransson
I can see where one might interpret it that way. But what the "ADD" means is
that you should ADD that note to the chart. That 3.52 degrees is the "glide
path" angle from SHLBY to the missed approach point.
If there was a change to the final approach course, that would have been
explicitly stated.
Old December 2nd 03, 12:28 AM
Bob Gardner
Gotta agree with Larry. The whole thing smacks of vertical descent path, not
lateral alignment. Poorly written, for sure. Should at least have had
quotation marks surrounding the phrase between "From" and "degrees."
Bob Gardner
"Greg Esres" wrote in message
Old December 2nd 03, 12:52 AM
Mike Granby
Hmmmm. Just how accurate is this guy's DG?
Headings in one hundredths of a degree???
Mike Granby, PP-ASEL,IA
Warrior N44578
http://www.mikeg.net/plane
Old December 2nd 03, 01:45 AM
Greg Esres
What about descent angles to within one hundredths of a degree?
Old December 2nd 03, 02:16 PM
Ron Natalie
"Greg Esres" wrote in message ...
They are consistantly listed in approach plates to that precision. Even
when they are exactly 3 degrees, the notation looks like:
GS 3.00
Old December 2nd 03, 03:46 PM
Gary L. Drescher
That makes more sense. A hundredth-degree change in descent angle is
(barely) perceptible on the ASI or VSI. A hundredth-degree change in
heading is not perceptible on the HI or MC.
--Gary
Old December 2nd 03, 04:08 PM
Roy Smith
I'd like to see a pilot or VSI which can notice the difference between
500 fpm and 502 fpm.
Old December 2nd 03, 04:23 PM
Ron Natalie
"Roy Smith" wrote in message ...
It's not even that much.
However, the charts always show the glideslope to the 100th. They never
show headings to that accuracy. If he'd actually looked hard at the chart
as to what they were changing, the fact that the elevation (which is depecited
on the chart in the same location) also changed would have been a big clue.
Old December 2nd 03, 04:39 PM
Gary L. Drescher
You're right, it would have been more accurate for me to say a *few*
hundredths of a degree. But that still justifies more than one decimal
place of precision. A few hundredths of a degree change of descent angle
moves the VSI needle almost as much as a one-degree heading change moves the
HI (and courses are routinely specified with single-degree precision).
--Gary
Carefull of NOTAMS on NavCanada website Ross Magnaldo Instrument Flight Rules 4 October 10th 03 11:46 PM
ILS Notam question John Clonts Instrument Flight Rules 6 August 22nd 03 11:53 PM
"GPS Unreliable" NOTAM Robert Henry Instrument Flight Rules 20 July 23rd 03 01:00 AM
