DG-300 water bag valve Q.
Old February 28th 06, 06:02 AM posted to rec.aviation.soaring
Default DG-300 water bag valve Q.
Okay, the valves at the wing root for the ballast bags have lost there
"spring" . In other words, they wont stay shut. I can pull on the
valve push rod slightly and get a good seal, but it leaks when I
release it. Is there a spring inside that push rod boot, that can be
adjusted/replaced, or is the boot itself adjustable to provide the
required tension on the seal? any help is always appreciated... GAP.
Old February 28th 06, 03:20 PM posted to rec.aviation.soaring
They can be replaced. If thet are anything like mine (DG-600 1989)
they were steel springs and they rusted/rotted out. Replace them with
stainless steel springs. Industrial hardware store.
LS4 Water valve control rod wanted Frank Soaring 3 February 21st 06 05:04 PM
O-360 sticking valve update [email protected] Owning 19 January 31st 06 01:04 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
WTB: ASW 27A water valve Peter Van Camp Soaring 0 April 28th 04 10:37 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
