OK...a 1976 PA 28 151..
After a few minutes of running, the port guage will start to fall towards E. It is showing 3/4 now (fuel at tabs), and will sag to 1/4 within about 15 min, while I am operating on the starboard (other) tank. Shut down for a few hours, guage resumes normal (correct) indication. We have checked / replaced, tank grounds, sender, wiring to guage. I think the guage terminals handle 12 V to the left terminal (looking at it from under the panel) (starboard terminal) , The other to the tank sender (port terminal).. (grounding this terminal when the fault is present will cause a "full" indication). From what I recall, there is a "ground" connection internal in the guage. Anybody know how this is grounded? I suspect a bad connection here somewhere.. Driving me up the wall..of course every time I attack the problem, meter in hand, it works fine. ![]() Anybody any ideas? Suggestions or test procedures? Dave |
Dave wrote:
OK...a 1976 PA 28 151.. After a few minutes of running, the port guage will start to fall towards E. It is showing 3/4 now (fuel at tabs), and will sag to 1/4 within about 15 min, while I am operating on the starboard (other) tank. Shut down for a few hours, guage resumes normal (correct) indication. We have checked / replaced, tank grounds, sender, wiring to guage. I think the guage terminals handle 12 V to the left terminal (looking at it from under the panel) (starboard terminal) , The other to the tank sender (port terminal).. (grounding this terminal when the fault is present will cause a "full" indication). From what I recall, there is a "ground" connection internal in the guage. Anybody know how this is grounded? I suspect a bad connection here somewhere.. Driving me up the wall..of course every time I attack the problem, meter in hand, it works fine. ![]() Anybody any ideas? Suggestions or test procedures? Dave Sounds like the float is filling up or becoming saturated...... Michelle |
-----Original Message----- From: Michelle ] Posted At: Wednesday, March 01, 2006 5:52 AM Posted To: rec.aviation.owning Conversation: Need help with fuel guage please! Subject: Need help with fuel guage please! Dave wrote: OK...a 1976 PA 28 151.. After a few minutes of running, the port guage will start to fall towards E. It is showing 3/4 now (fuel at tabs), and will sag to 1/4 within about 15 min, while I am operating on the starboard (other) tank. Shut down for a few hours, guage resumes normal (correct) indication. We have checked / replaced, tank grounds, sender, wiring to guage. I think the guage terminals handle 12 V to the left terminal (looking at it from under the panel) (starboard terminal) , The other to the tank sender (port terminal).. (grounding this terminal when the fault is present will cause a "full" indication). From what I recall, there is a "ground" connection internal in the guage. Anybody know how this is grounded? I suspect a bad connection here somewhere.. Driving me up the wall..of course every time I attack the problem, meter in hand, it works fine. ![]() Anybody any ideas? Suggestions or test procedures? Dave Sounds like the float is filling up or becoming saturated...... Michelle [Jim Carter] Wouldn't that tend to move from reliable to unreliable and then stay there or get worse? Why would shutting down tend to reset everything if it was a float? I has to be something that is deteriorating electrically over a period of time while the power is applied. Then when power is removed the charges bleed down and return to normal until the next time power is applied. I don't know the circuit but it sure sounds like there is a capacitor somewhere that is applying a charge to the circuit until the power is removed and the bleed resistor does its job. |
Dave writes:
OK...a 1976 PA 28 151.. After a few minutes of running, the port guage will start to fall towards E. .... Shut down for a few hours, guage resumes normal (correct) indication. We have checked / replaced, tank grounds, sender, wiring to guage. What about engine grounds? Battery grounds? I think the guage terminals handle 12 V to the left terminal (looking at it from under the panel) (starboard terminal) , The other to the tank sender (port terminal).. (grounding this terminal when the fault is present will cause a "full" indication). From what I recall, there is a "ground" connection internal in the guage. Anybody know how this is grounded? I suspect a bad connection here somewhere.. Well, that's a fair guess. Especially since it looks like the sender resistor is "0 ohms == full; many ohms == empty"... Driving me up the wall..of course every time I attack the problem, meter in hand, it works fine. ![]() Tape a spare DVM under the panel, near the gauge. This threat should scare it into working.... But let's do an obvious test. Can you swap the leads to the two tanks; so the left shows on the right gauge and vice versa? [Assuming such can be done legally and safely, of course -- can you placard it or such?] That will reduce it to gauge vs sender resistor+wiring+grounds. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
But let's do an obvious test. Can you swap the leads to the two tanks; so the left shows on the right gauge and vice versa? [Assuming such can be done legally and safely, of course -- can you placard it or such?] That will reduce it to gauge vs sender resistor+wiring+grounds. On the Cherokee 140 you can swap the gauge/sender with a simple swap of 2 wires on a barrier strip under the rear seats. Check the Service manual to see if there is a similar setup in the Warrior. The barrier strip is probably behind the baggage area or under it. Good Luck, Mike |
Mike Spera writes:
But let's do an obvious test. Can you swap the leads to the two tanks; so the left shows on the right gauge and vice versa? [Assuming such can be done legally and safely, of course -- can you placard it or such?] That will reduce it to gauge vs sender resistor+wiring+grounds. On the Cherokee 140 you can swap the gauge/sender with a simple swap of 2 wires on a barrier strip under the rear seats. Check the Service manual to see if there is a similar setup in the Warrior. The barrier strip is probably behind the baggage area or under it. That's a good first step, and if the problem moves, it's clear it's outbound of there. But if it does not move, you must go back and swap wires at the gauges to be sure. I too think it's the sender, but... many fuel gauges have a crude voltage regulator inside, and if that is what's drifting.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Thanks all, but note in my post, the sender has been replaced with
new, the rsistance is exactly on spec, and no dead spots in it's operation.. The fuel level has no effect on the fault..the guage literally "goes to sleep" when ever it feels like it, usually after about 15 mins, then occassionally, during flight, "wakes up" and reads correctly for a few minutes.. then away it goes.. (down).. Switching wires to the guages is a bear of a job under the panel, but I may do it back under the seat, just to be sure.. Anybody know where to get a wiring diagram/component location info on the WArrior? my CD manual is a bit lacking here... Dave On Thu, 2 Mar 2006 23:53:40 +0000 (UTC), David Lesher wrote: Mike Spera writes: But let's do an obvious test. Can you swap the leads to the two tanks; so the left shows on the right gauge and vice versa? [Assuming such can be done legally and safely, of course -- can you placard it or such?] That will reduce it to gauge vs sender resistor+wiring+grounds. On the Cherokee 140 you can swap the gauge/sender with a simple swap of 2 wires on a barrier strip under the rear seats. Check the Service manual to see if there is a similar setup in the Warrior. The barrier strip is probably behind the baggage area or under it. That's a good first step, and if the problem moves, it's clear it's outbound of there. But if it does not move, you must go back and swap wires at the gauges to be sure. I too think it's the sender, but... many fuel gauges have a crude voltage regulator inside, and if that is what's drifting.... |
Dave wrote:
: Thanks all, but note in my post, the sender has been replaced with : new, the rsistance is exactly on spec, and no dead spots in it's : operation.. : The fuel level has no effect on the fault..the guage literally "goes : to sleep" when ever it feels like it, usually after about 15 mins, : then occassionally, during flight, "wakes up" and reads correctly for : a few minutes.. then away it goes.. (down).. : Switching wires to the guages is a bear of a job under the panel, but : I may do it back under the seat, just to be sure.. : Anybody know where to get a wiring diagram/component location info on : the WArrior? my CD manual is a bit lacking here... Some PA28's (like my mechanic's T-Arrow) have a strange sending unit setup. IIRC, there are two per tank, and they must be *insulated* from the tank. Putting the wrong washers on the sending unit will ground them and cause weird readings (like 1/2 full when full, etc). I haven't followed the details of this thread, but that might be worth looking into. Swapping wires at the disconnect under the rear seat sounds like an easy way to check. If you do go under the panel, I seem to remember something a bit weird about how the gauges were wired in mine. The service manual should have the schematic all laid out. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
| Thread Tools | |
| Display Modes | |
| Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 08:04 PM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 07:13 PM |
