Anyone had fuel tank air vent icing up?
Old March 1st 06, 07:58 PM posted to rec.aviation.ifr
Default Anyone had fuel tank air vent icing up?
Years back, a local flight school had a Trinidad TB-20. The
owner of the flight school told me this story. A rental pilot
called him up during a flight and stated that his wings were collapsing.
The advice was to get the airplane on the ground as quickly as possible.
The cause was blockage of the fuel vent(s) from ice I believe, which
caused the deformamtion of the sheet metal sections of the wings where
the fuel tank(s) were located. It did quite a bit of damage to the wing.
Ronnie
"Peter" wrote in message
Is there any known case of the above happening, on an aircraft flying
below say FL200?
On a known-ice aircraft, the vents are normally heated.
One reads a fair number of stories of pilots picking up a huge amount
of ice (inches) but not (that I have seen) of engine failures caused
by vacuum in the tanks.
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
